X93W lcd problem
  • yves67
    • Dec 2012
    • 16
    • France
    Re: X93W lcd problem
    ok, that answer my question, the lamps are independant, not connected in serial mode
    ok, I will connect one lamp at a time from the x93w to the good lcd and see
    thanks
    btw: I have ordered too quickliy the board.... never mind that was not so expensive
    18€
    • selldoor
      Slow Learner
      • 7870
      You can either sell it on though not sure how many machines it will fit
      OR contact the seller and ask how much to cancel - should be ebay relisting fee?
      plus a bit for his trouble.
      You should save a bit on postage.
      • yves67
        • Dec 2012
        • 16
        • France
        Some update
        I have connected the lamps from one to the other, one by one, two by two
        and I went back to the original lcd, which was faulty, but now it is working.....
        I saw a little damage on one wired, due to the fact I moved the wire the problem went away....
        I will do some test tomorrow
        thanks for your messages
        Yves67
        • selldoor
          Slow Learner
          • 7870
          You may be able to resolder the wire - there is a post somewhere on here
          saying how to do it- I will look tomorrow or perhaps other members will chip in while we sleep.
            This may help:
            http://lcdparts.net/howto/troublesho...topSCCFL1.aspx
            I have done many lamp assemblies repair but I am not good at explaining how to do it exactly.
            • yves67
              • Dec 2012
              • 16
              • France
              #26
              q
              • yves67
                • Dec 2012
                • 16
                • France
                #27
                The problem is fixed, I think it was the wires which were a little damaged
                putting them differently it is working
                thanks to all of you
                have a good day
                yves67
                • doorzon
                  AOC AGON AG273QCG refresh problem picture shifts
                  by doorzon
                  hopefully someone on this board has an idea on how to begin with troubleshooting this problem.
                  The monitor AOC AGON AG273QCG (curved 27" QHD monitor) has problems refreshing every 1 to 2 seconds or so. A line appears in the middle of the screen and the lower half of the screen is shifted to the right.
                  See attached picture.
                  I am leaning towards an issue with bad soldering of the graphics chip, because the problem used to go away after some time (minutes) but now it is here to stay.
                  However, this could also be related...
                  08-12-2023, 02:36 AM
                • Tr0ll
                  by Tr0ll
                  Original T-con:
                  First replacement T-con:
                  10-07-2023, 07:48 PM
                • retrorepair
                  SONY KDL-40P3600 Picture Problem
                  by retrorepair
                  Hello gurus, hope you can assist me...
                  I have a Sony KDL.40P3600, with an issue on the left side of the screen (pictures attached).
                  I think the problem is the panel, but before send it to trash, i would like to get a second opinion.
                  Thanks in advance.
                  10-11-2024, 05:12 PM
                • KYBOSH
                  Samsung UN55MU8000 - Backlight But No Picture Problem
                  by KYBOSH
                  Hello all
                  I pick this up free as a repair project for the holidays.
                  The original symptom was power cycling after 3-4 seconds with a single red light flash.
                  To remedy this I went through and unplugged each component 1x1 and discovered that when the FFC cables were disconnected the backlights stayed on and the TV did not reboot.
                  I tried remove one or the other to see which side of the display was causing the issue (expecting to see half a picture to show) but didn't see anything. But the boot loop only appears when the top FFC cable (right side...
                  12-21-2022, 12:42 AM
                • Chrissygizmo
                  Linsar 75uhd520 picture problem
                  by Chrissygizmo
                  Hi all, I've recently acquired a linsar 75uhd520 TV, there was nothing on the screen when I first got it, now after finding around I've managed to get a picture but it has loads of lines running through it, I've uploaded a Google image of what the picture looked like, i will upload photos of it soon, also, I didn't get a remote with it, I've went through all my remotes trying to get one to work it but had no luck, does anyone know what remote would work this set please??...
                  01-24-2023, 10:20 PM
