X93W lcd problem
  • yves67
    • Dec 2012
    • 16
    • France
    Re: X93W lcd problem
    ok, that answer my question, the lamps are independant, not connected in serial mode
    ok, I will connect one lamp at a time from the x93w to the good lcd and see
    thanks
    btw: I have ordered too quickliy the board.... never mind that was not so expensive
    18€
    • selldoor
      Slow Learner
      • 7870
      You can either sell it on though not sure how many machines it will fit
      OR contact the seller and ask how much to cancel - should be ebay relisting fee?
      plus a bit for his trouble.
      You should save a bit on postage.
      • yves67
        • Dec 2012
        • 16
        • France
        Some update
        I have connected the lamps from one to the other, one by one, two by two
        and I went back to the original lcd, which was faulty, but now it is working.....
        I saw a little damage on one wired, due to the fact I moved the wire the problem went away....
        I will do some test tomorrow
        thanks for your messages
        Yves67
        • selldoor
          Slow Learner
          • 7870
          You may be able to resolder the wire - there is a post somewhere on here
          saying how to do it- I will look tomorrow or perhaps other members will chip in while we sleep.
            This may help:
            http://lcdparts.net/howto/troublesho...topSCCFL1.aspx
            I have done many lamp assemblies repair but I am not good at explaining how to do it exactly.
            • yves67
              • Dec 2012
              • 16
              • France
              #26
              q
              • yves67
                • Dec 2012
                • 16
                • France
                #27
                The problem is fixed, I think it was the wires which were a little damaged
                putting them differently it is working
                thanks to all of you
                have a good day
                yves67
                • theone111
                  by theone111
                  3. Problem: TV shuts down
                  07-22-2024, 10:36 AM
                • Zeonalbasta
                  Thinkpad X1 Carbon "LMQ-1MB 12298-2 48.4LY26.021" VCC3M problem
                  by Zeonalbasta
                  i have a problem with thinkpad X1 carbon gen 2 "LMQ-1MB 12298-2 48.4LY26.021"
                  The laptop was turned off because the MOSFET was not transmitting voltage. After checking it turned out that the gate pin on the MOSFET was the problem, because it was producing an inappropriate voltage. and it was discovered that the problem was with the Think engine, so I decided to reprint each pin, and finally the mosfet could work properly. However, there is another problem, even though the voltage has been supplied to the laptop, it still won't turn on, there isn't even an LED indicator. After double...
                  09-13-2024, 01:17 PM
                • Gibon378
                  Problem with stopping audio and video for no reason
                  by Gibon378
                  PC Specs:
                  • CPU: Ryzen 5 1600
                  • GPU: GTX 1080 Palit JetStream
                  • MOBO: ASRock ab350 PRO4
                  • RAM: Crucial Ballistix Sport 2x8GB 3000MHz (XMP 2.0)
                  • PSU: XFX 650W (don't remember what model)
                  • OS SSD: ADATA SP920
                  • OS: Windows 10 21H2
                  Problem description:
                  Hi. I have a problem that has been going on for some time (2-3 years). It's hard to explain what it really is. Sometimes, my computer stops playing music, stops videos (starts buffering on youtube), there is no sound in games and when I minimize the game window and return to the game there is a black screen with window borders...
                  11-19-2022, 09:41 AM
                • perzyk23
                  Lenovo T580 - LCD Panel problem - error 0288
                  by perzyk23
                  Good morning,
                  I have a problem with Lenovo T580, which after error code 0288 suggests a problem with the display. I checked the display and it works on another laptop. I replaced the display cable with a new one. I programmed another BIOS (downloaded from this forum) and I still have the problem of a dead display - there is an image via HDMI, and the system does not detect the built-in LCD at all. The problem appears to be hardware. What can I check to confirm or disprove this? I found many threads on the Internet related to this problem 0288, but without specific solutions. Please advise....
                  10-25-2024, 12:42 AM
                • SDNarcia
                  Dell 15R-5521 keyboard problem (KBC?)
                  by SDNarcia
                  Hello, I have a Dell 15R-5521, with the problem that the Ctrl, Alt, Shitf and Num Lock keys do not work, I tested the keyboard with a keyboard tester and it is functional, I also got another new keyboard and the computer has the same problem with the same keys. Check continuity between the ZIF connector from the keyboard to the KBC and all pins are correct. I cleaned the ZIF connector and the KBC and I still have the same problem. I reinstalled windows just in case, and it didn't work. I updated the BIOS to the latest version A16 and there were no changes.
                  As additional information,...
                  07-20-2024, 10:47 PM
