Seanix monitor
    Seanix monitor
    I just replaced all the caps in a Seanix 700P monitor but still have graphics corruption that is for lack of a better word "dancing".
    Any chance someone has seen this before so I would know what to try next?
    Pic is attached but I can also show a short video capture if someone needs to see one and there is a way to show it without breaking forum rules.
    Re: Seanix monitor
    Check the voltage regulators on the main board. See my sig file below for instructions.
    --- begin sig file ---
    --- end sig file ---
      Re: Seanix monitor
      will do and thank you. will post results.
      Taken when monitor in standby (power light is amber):
      FS8860 -> Line one
      33CJ0093 -> Line two
      pin 1 = 0.000
      pin 2 = 3.289
      pin 3 = 5.11
      84-18 -> Line one
      0417A -> Line two
      pin 1 = 0.000
      pin 2 = 1.792
      pin 3 = 5.11
      Taken when monitor in normal use (power light is green):
      FS8860 -> Line one
      pin 1 = 0.000
      pin 2 = 3.199
      pin 3 = 5.04
      84-18 -> Line one
      0417A -> Line two
      pin 1 = 0.000
      pin 2 = 1.740
      pin 3 = 5.04
      The readings are taken with the monitor powered on and connected to the pc, but with the lcd panel not connected as the boards can't be reached with the panel plugged into everything. Power light is green.
        Re: Seanix monitor
        Anyone?
          Re: Seanix monitor
          Originally posted by Undead View Post
          Anyone?
          You have the results of your tests - if you re read retiredcaps guide on this it tells you how to decide if they are good or not.
          Look up the data sheets and tell us what they say the voltage out should be.
          Post the data sheets save us looking them up.
            Re: Seanix monitor
            Haven't had any luck finding the data sheets.
            Is there a site that has a lot of them? Can't see any manufacturer name on the chips and google doesn't seem to be my friend this time.
            ok I may have found the first one finally:
            http://www.datasheetarchive.com/FS88...datasheet.html
            if I'm reading it right output for this one should be 3.3v
              Re: Seanix monitor
              Ok - here is the one for the 84-18
              http://html.alldatasheet.com/html-pd...1084-18CE.html
                Re: Seanix monitor
                Ah thank you I never would have known that number was the same one
                Looks like the output for the second one should be 1.8V
                  Re: Seanix monitor
                  84-18 -> Line one
                  0417A -> Line two
                  pin 1 = 0.000
                  pin 2 = 1.740
                  pin 3 = 5.04
                  1) The "-18" tells you the output should be 1.8.
                  2) (1.8-1.74)/1.8 = 3.33% out of tolerance.
                  3) Page 3 of the datasheet that selldoor linked says 1.78 to 1.82 is the range with 1.80 being typical.
                  4) You might also want to check the cap that is on the output pin (pin 2) to see if it is bad or pulling down the voltage a bit.
                  5) Now you decide if 33CJ0093 is good or bad.
                    Re: Seanix monitor
                    Well going by the numbers the 33CJ0093 would be 3% out as well.
                    (3.3-3.199)/3/3 = 3.06% out of tolerance.
                    I'll have to wait until I get an ESR meter to check the cap, but I think this one may just be left for parts in case I get another similar one. I get the monitors for free so don't want to spend a whole lot on parts and shipping etc just to find it still has a problem
                    In any event thank you guys very much for all the info, I made a lot of notes and saved the spec sheets as well. I appreciate you all taking the time to help me learn more about this. I always enjoy learning more.
                      Re: Seanix monitor
                      I get my voltage regulators off ebay. Usually 5 or 10 for $1 + free shipping.
                      An example,
                      http://www.ebay.com/itm/221105133435
                      edit: I got a whole variety and some sellers are flexibile in that they will send out a "mix" for the same price of $1 + free shipping.
                        Re: Seanix monitor
                        Well that's a great deal thanks for the info. What the heck was I looking at where they ranged in price from about $9 each up to $16 each....?? Clearly I must have been looking at the wrong thing.
                        Any chance you could recommend an equivalent replacement for the ones I listed?
                          Re: Seanix monitor
                          Post a picture of each so we know what size package they are.
                            Re: Seanix monitor
                            Not the best lighting today but hopefully they will be clear enough.
                              Re: Seanix monitor
                              The pics are better than 90% of the usual out of focus stuff that we get.
                              http://www.ebay.ca/itm/221105133435
                              I having a hard time find the 84-18 TO-252 replacement on ebay. Digikey has it
                              http://www.digikey.com/product-detai...ICT-ND/1301472
                              The difficult part is the 5A output. Most of the 1117-18s on ebay are all SO-223 and 1A output.
                                Re: Seanix monitor
                                BTW, we usually see one bad voltage regulator. It is unusual to see two. Can you double check those readings?
                                  Re: Seanix monitor
                                  Thank you retiredcaps, I peeked on Mouser with the number you provided since I usually deal with them for my caps, and they don't stock them they would have to order and I don't think I quite need their minimum order of 1620 of them lol
                                  I appreciate all your efforts in trying to track it down.
                                  I did double check them last night but I will re-check again now and use a second meter to compare as well.
                                    Re: Seanix monitor
                                    Ok with the mastercraft meter: (the same one I took the original readings with, no I don't have a nice Fluke)
                                    FS8860 -> Line one
                                    pin 1 = 0.00
                                    pin 2 = 3.199
                                    pin 3 = 5.05
                                    84-18 -> Line one
                                    0417A -> Line two
                                    pin 1 = 0.00
                                    pin 2 = 1.748
                                    pin 3 = 5.04
                                    old NRI meter:
                                    FS8860 -> Line one
                                    pin 1 = 0.00
                                    pin 2 = 3.18
                                    pin 3 = 4.99
                                    84-18 -> Line one
                                    0417A -> Line two
                                    pin 1 = 0.00
                                    pin 2 = 1.72
                                    pin 3 = 4.99
                                      Re: Seanix monitor
                                      It's unlikely any of these regulators are 5A - with the input of 5v, to get 1.8v at 5A it would dissipate 3.2 watts * 5A = 15 watts.
                                      That's impossible. At best on that PCB I see about 4 watts of dissipated power, so any 1.5-2A regulator would probably work.
                                      For the 3.3v, it has quite a bit of solder there as heatsink so that's probably 1A+ and actually uses it. A random datasheet for FS8860 says 1A.
                                      Pay attention to this particular one because the pin order is different than the one on most common regulators.
                                      Yours appears to be 1. GND 2. OUT 3. IN with the TAB output
                                      Most regulators are 1. IN 2. GND 3. OUT with the TAB ground.
                                      I didn't compare the pinout of the 1.8v one with other regulators of the same format so this one could also be just as quirky.
                                      PS. See if ca.newark.com can be of help. I don't know if the shipping charges are convenient for you, I think someone on this forum complained about that but I'm not sure.
                                        Re: Seanix monitor
                                        AP1084K18L-13
                                        into mouser search field brings up
                                        http://ca.mouser.com/ProductDetail/D...Y7YI7dCw%3d%3d
                                        $1.78 (754 in stock).
