Seanix monitor
+ More Options
Posts
  • Undead
    • Mar 2012
    • 64
    Re: Seanix monitor
    Originally posted by mariushm
    It's unlikely any of these regulators are 5A - with the input of 5v, to get 1.8v at 5A it would dissipate 3.2 watts * 5A = 15 watts.
    Pay attention to this particular one because the pin order is different than the one on most common regulators.
    Yours appears to be 1. GND 2. OUT 3. IN with the TAB output
    Most regulators are 1. IN 2. GND 3. OUT with the TAB ground.
    PS. See if ca.newark.com can be of help. I don't know if the shipping charges are convenient for you, I think someone on this forum complained about that but I'm not sure.
    I don't really follow why you say it's impossible when the data sheet has it. I'm still very new to all of this.
    I did notice the ground seemed to be on the left instead of the pin 2 and the tab, but didn't know that it was that unusual.
    Thanks for the newark suggestion, I did look there for other electronic items in the past and the shipping did seem to be a bit steep.
    Originally posted by retiredcaps
    AP1084K18L-13
    into mouser search field brings up
    http://ca.mouser.com/ProductDetail/D...Y7YI7dCw%3d%3d
    $1.78 (754 in stock).
    Sorry retiredcaps I don't mean to frustrate you with my lack of knowledge, the number I put into the search was the AP1084D18L-13 number that you first posted, I don't know enough to know that the AP1084K18L-13 can be used instead. The first one gives a result of:
    http://ca.mouser.com/ProductDetail/D...F4BLLY8A%3d%3d
    which shows not in stock and a minimum order of 1620. I did notice the tab is slightly different in this last link you posted but it doesn't look like a significant difference.
    Thank you for the new link by the way.
    • mariushm
      • May 2011
      • 3799
      Re: Seanix monitor
      Linear voltage regulators work by dissipating the difference of voltage as heat through a heatsink.
      So if the voltage regulator receives 5v and outputs 1.8v like it happens in your case, this means the difference of 3.2 volts needs to be dissipated as heat.
      This means for each 1A of power, the regulator will dissipate 3.2v x 1 A = 3.2 watts of power.
      The regulator IS rated for maximum of 5A, but if you look at page 5 at the bottom of the chart, you can see it has a "Thermal Resistance Junction-to- Case" of 3.5 C per watt
      The chip itself will stop working at 150 C, so let's do some math for 5A, following these formulas, and let's say we want to chip to not exceed 50c (we don't want to cook the capacitors around) :
      Let's use the math from the app note here:
      VOUT = 1.8V
      TJ MAX = 150°C
      θJC of the TO-263 = 3.5°C/W
      θCS ≈ 0°C/W (soldered directly to board)
      Vout = 1.8V
      Pd = (Vin – V out) x I out = [5.1V – 1.8V] x 5A = 16.5 watts
      We're already OVER the maximum power dissipation the chip can do: check the datasheet, in particular the footnotes, the regulation is guaranteed up to 15w
      Maximum temperature rise, ∆T = TJ(MAX) – TA = 150°C – 50°C = 100°C
      Thermal resistance requirement, θJA (worst case):
      ∆T / Pd = 100°C/16.5 = ~ 6.1°C/W
      Heat sink thermal resistance, θSA = θJA – (θJC + θCS)
      θSA = 6.1 – (3.5 + 0) = 3.4°C/W (max)
      So if you look now at the application note at left bottom corner at the graph, you'll see that in order to dissipate those 5A of power, the pcb area would be unrealistically large... the chip simply can't be cooled without better cooling (metal heatsink or fan above it)
      Now look at the picture... you barely have half an inch by half an inch for that 1.8v regulator... it's simply impossible for that chip to output 5A without going to 150c.
      It can probably output 1-1.5A safely with that little heatsink under itself, under the tab
      The chip CAN do 5A, but for that it needs to dissipate less power, to receive LESS input voltage. It needs just 1.4v or more to regulate, so had the chip actually use 1.8v + 1.4v + 0.1v for margin error = 3.3v , it may actually do 5A. But on your board the input voltage is 5V.
      If the input was 3.3v, it would output 1.8v and dissipate only 1.5 watts per A or 7.5 watts at 5A. with some serious pad on both sides of the pcb it would work.
      Which is still more than what your pcb has alloted to this regulator, so even in ideal conditions the regulator wouldn't output 5A like this. It just shows they probably bought these regulators cheaply and didn't really care about the maximum current output.
      If the input was 3.3v and you relax the max temp to about 65c then the whole thing changes:
      Pd = (3.3v - 1.8 ) x 5 = 7.5w
      delta t = 100c
      delta t / pd = 115 / 7.5 = 15.3 c / w
      θSA = 15.3 - 3.5 = 11.8 c / w
      and you'd need about 5000-6000 square mm of pcb to cool it, if it was to output 5A all the time.
      So keeping all this in mind, if you can't find a cheap regulator rated for 5A, pick one that can do 1.5-2A - the regulator physically can't do 5A on that pcb.
      • Undead
        • Mar 2012
        • 64
        Re: Seanix monitor
        Wow that's quite the explanation, I have had to read it several times to even get the basic idea of it. It does seem to make sense if I am following correctly. Thank you very much for taking the time to go into so much detail.
          by momaka
          03-15-2023, 10:17 PM
        • ant3202
          HP 27es - LED monitor - Monitor Flashing On - Off
          by ant3202
          Hi Everyone
          Lately I am experiencing the deja-vu incident on one of the led monitor like this.
          https://www.badcaps.net/forum/troubl...lashing-on-off
          The monitor is HP 27es LED Monitor
          https://h30434.www3.hp.com/t5/Deskto...e/td-p/6804692
          The monitor will randomly blackout and display no signal and will recover again.
          Sometimes need to power and off again to restore the display but...
          03-20-2025, 07:30 PM
        • Rick_1234
          by Rick_1234
          Good evening, gentlemen.
          Things I tried
          06-22-2024, 04:44 PM
          Wise Wing F199 19'' LCD monitor - recapped
          by momaka
          Looking through my repair pictures and notes, it's been a long time since I posted anything in the LCD monitors section. So here goes that.
          I'm dedicating this thread to one of the very first LCD monitors I repaired (if not the first one), which was more than 10 years ago now. The monitor is a Wise Wing, model F199. It's a 19” CFL-backlit LCD. I got it for free off of Craigslist in 2009 from a guy, who said he bought it for cheap from Wallmart and the monitor worked only for a little less than 2 years before quitting.
          When I saw the Craigslist post, I wasn't...
          08-24-2020, 10:58 AM
        • sew333
          Pc shutdown, monitor flickered with no signal after 10 seconds
          by sew333
          My pc:
          10850K stock 4800mhz stock Kraken X73 good temps
          2x16 GB DDR4 GSKILL 3000mhz XMP
          Seasonic Tx-850 Ultra Titanium
          Gigabyte Rtx 3090 Gaming OC
          Aorus Z490 Pro Gaming
          1 TB SSD
          4 weeks ago i launched Metro Exodus Enhanced and during cinematic advertisement part ( 30 fps ), pc just shutdown.
          Also monitor flickered with NO SIGNAL 10 seconds after shutdown. So only monitor and pc was affected.
          Next i pressed only power button, rebooted again and its fine again. Happened once and i cant reproduce.
          Power...
          02-22-2022, 10:27 AM
