Samsung 245bw No Power No LED
  • Ober
    • Aug 2012
    • 67
    Re: Samsung 245bw No Power No LED
    Did the DCV 20 test on the 450v Cap mean its still good? (starting with a lil charge and going to nothing?)
    Edit: Rest of my questions were just answered above as i posted.. thx
    • Ober
      • Aug 2012
      • 67
      Selldoor> not a single reading on those (im assuming by mains you mean 450v cap)
      Note: im still working with JUST the power board, all ribbons still apart..
      • Rtech
        • Jul 2010
        • 1095
        #43
        NO...he means the mains socket where the AC comes in
        • selldoor
          Slow Learner
          • 7870
          #44
          It is not really a valid test so doesnt mean its good or bad.
          • selldoor
            Slow Learner
            • 7870
            #45
            Yes first four from mains socket to bridge
            last two from bridge to Main/Big cap (450v)
            When you say not a single reading do you mean the meter stays on "1"
            or the meter goes to 0.00
            Yes I know you are just on the power board - that is ok.
            Are you up for testing for a mains voltage (400vdc perhaps) at the big cap?
            If you have any sort of RCD socket (Residual-current device) then use that.
            Again just try it with only the power supply - nothing connected to it.
            Make it a short test and unplug straight after but remember not to touch the board for some time after.
            If so, meter on 1000vDC Red probe to positive pin and black probe to
            negative pin of the Big cap.
            • Ober
              • Aug 2012
              • 67
              ahh oops, thanks..
              Mains socket is labeled N and L
              Black on N, Red on 2 - 1L
              Black on N, Red on 3 - Starts high and very very quckly drops to 001
              Black on L, Red on 2 - 1L
              Black on L, Red on 3 - 1L
              Bridge-Cap Tests - 1L
              No reading meaning 1L (sorry for using two things to describe the same)
              • Ober
                • Aug 2012
                • 67
                1000 DCV -- Black on Neg, Red on Pos - Plugged in, Power Switch On - Started higher (not sure exactly where) dropped to 168, 2nd try again just 168
                • selldoor
                  Slow Learner
                  • 7870
                  #48
                  Well that is great - can barely believe it Ive just typed in that there doesnt seem to be any connection between mains and big cap but
                  clearly there is.
                  Well done - tests should get easier from now on. perhaps someone will take over as I am off to bed.
                  • selldoor
                    Slow Learner
                    • 7870
                    #49
                    Just check that your probes are plugged firmly into the meter and that the wires to the probes are ok - I used to have one of those and the wire kept pullng off the pin inside the handle.
                    • Ober
                      • Aug 2012
                      • 67
                      So what might i try next?
                      ..Thanks
                      • selldoor
                        Slow Learner
                        • 7870
                        #51
                        Ok - nobody playing? Next is still no luck with camera? how about a scanner?
                        Meter on Ohms - Power off- remember the arrow pointing to the bridge? , well follow that and just past the bridge you might find a little red rectangular box.
                        If you do it is a fuse, I think what does it say on it?
                        find its pins on the bottom of the board and test it.
                        • rogfanther
                          • Jul 2006
                          • 458
                          • Brazil
                          #52
                          Ober, which are the codes in the PSU board ? Most are IP-xxxxx , but can be BNU-xxxx , or other ones. Please, post them and maybe someone can fina a photo to help us help you.
                          • Rtech
                            • Jul 2010
                            • 1095
                            #53
                            Just looked for a photo, and is this not a 68Ω resistor fault ?
                            • Rtech
                              • Jul 2010
                              • 1095
                              #54
                              OBer, does your board look like the middle photo on this page ..
                              https://www.badcaps.net/forum/showth...ighlight=245bw
                              • selldoor
                                Slow Learner
                                • 7870
                                #55
                                See post 18?
                                • Rtech
                                  • Jul 2010
                                  • 1095
                                  #56
                                  It is the same as the one I have referred to in post 54.
                                  • selldoor
                                    Slow Learner
                                    • 7870
                                    #57
                                    See post 5?
                                    • Rtech
                                      • Jul 2010
                                      • 1095
                                      #58
                                      Originally posted by selldoor
                                      See post 5?
                                      I just hate going back and fwd all the time.
                                      • Ober
                                        • Aug 2012
                                        • 67
                                        hehe, well yes that seems to be the exact same board...
                                        • Ober
                                          • Aug 2012
                                          • 67
                                          Tested FB802S (Red Fuse Box) 200ohms -- started high dropped to 0.6
                                          • PantherDave
                                            by PantherDave
                                            Hi all!
                                            05-29-2024, 02:01 PM
                                          • GLISIT
                                            by GLISIT
                                            01-16-2025, 02:29 PM
                                          • hill01
                                            Samsung UE75MU7009TXZG Endless Power Cycle
                                            by hill01
                                            Hi everyone and thanks in advance for any help I might get here
                                            My Samsung TV is about 4 years old. The exact model number is UE75MU7009TXZG.
                                            About half a year ago I started seeing occasional green frames pop up while watching movies. I mean literally green frames. Not the image turning green, but the entire screen turning green for a split second. This happened maybe once or twice during a 2 hour movie. So no big deal, but clearly something was not quite right.
                                            Since a few days, the TV won't turn...
                                            11-17-2021, 02:52 PM
                                          • Journey11
                                            Samsung TV won't turn on ... keeps cycling the power relay on & off
                                            by Journey11
                                            Hi All,
                                            First time posting here ... my name is Kevin but my friends call me Journey.
                                            I have a Samsung 75" LCD model UN75RU8000FXZA that I don't remember the original fault other than it wouldn't power up anymore.
                                            After it sat for many month's I decide to look at it again. The motherboard seemed to have power regulation issues. After much fussing I decided to just get a new MB.
                                            It came a few days ago and I installed it now just cycles the power relay on and off ... when on the backlights light up and then dim and then relay kicks off and the whole things starts again....
                                            07-04-2024, 02:44 PM
