Samsung 245bw No Power No LED
    Re: Samsung 245bw No Power No LED
    Did the DCV 20 test on the 450v Cap mean its still good? (starting with a lil charge and going to nothing?)
    Edit: Rest of my questions were just answered above as i posted.. thx
      Selldoor> not a single reading on those (im assuming by mains you mean 450v cap)
      Note: im still working with JUST the power board, all ribbons still apart..
        NO...he means the mains socket where the AC comes in
          It is not really a valid test so doesnt mean its good or bad.
            Yes first four from mains socket to bridge
            last two from bridge to Main/Big cap (450v)
            When you say not a single reading do you mean the meter stays on "1"
            or the meter goes to 0.00
            Yes I know you are just on the power board - that is ok.
            Are you up for testing for a mains voltage (400vdc perhaps) at the big cap?
            If you have any sort of RCD socket (Residual-current device) then use that.
            Again just try it with only the power supply - nothing connected to it.
            Make it a short test and unplug straight after but remember not to touch the board for some time after.
            If so, meter on 1000vDC Red probe to positive pin and black probe to
            negative pin of the Big cap.
              ahh oops, thanks..
              Mains socket is labeled N and L
              Black on N, Red on 2 - 1L
              Black on N, Red on 3 - Starts high and very very quckly drops to 001
              Black on L, Red on 2 - 1L
              Black on L, Red on 3 - 1L
              Bridge-Cap Tests - 1L
              No reading meaning 1L (sorry for using two things to describe the same)
                1000 DCV -- Black on Neg, Red on Pos - Plugged in, Power Switch On - Started higher (not sure exactly where) dropped to 168, 2nd try again just 168
                  Well that is great - can barely believe it Ive just typed in that there doesnt seem to be any connection between mains and big cap but
                  clearly there is.
                  Well done - tests should get easier from now on. perhaps someone will take over as I am off to bed.
                    Just check that your probes are plugged firmly into the meter and that the wires to the probes are ok - I used to have one of those and the wire kept pullng off the pin inside the handle.
                      So what might i try next?
                      ..Thanks
                        Ok - nobody playing? Next is still no luck with camera? how about a scanner?
                        Meter on Ohms - Power off- remember the arrow pointing to the bridge? , well follow that and just past the bridge you might find a little red rectangular box.
                        If you do it is a fuse, I think what does it say on it?
                        find its pins on the bottom of the board and test it.
                          Ober, which are the codes in the PSU board ? Most are IP-xxxxx , but can be BNU-xxxx , or other ones. Please, post them and maybe someone can fina a photo to help us help you.
                            Just looked for a photo, and is this not a 68Ω resistor fault ?
                              OBer, does your board look like the middle photo on this page ..
                              https://www.badcaps.net/forum/showth...ighlight=245bw
                                See post 18?
                                  It is the same as the one I have referred to in post 54.
                                    See post 5?
                                      Originally posted by selldoor View Post
                                      See post 5?
                                      I just hate going back and fwd all the time.
                                        hehe, well yes that seems to be the exact same board...
                                          Tested FB802S (Red Fuse Box) 200ohms -- started high dropped to 0.6
