Re: Samsung 245bw No Power No LED
Seems ok, good, can you connect all the boards up and plug in but do not press power.
On the top right of the power supply is a connector with 24v mentioned.
Set your meter on 200VDC and put the black probe on a ground screw and test each pin
on the connector with the red pin- Do not touch any heatsinks. record results
Pin Designation Actual
1 24v 24.2v
2 24v 24.2v
3 ? 1.79v and so on
Then press the power button and do it again. Only bother to record results if diffferent.
1 24v 24.2v
2 24v 24.2v
3 ? 1.79v and so on
