Samsung 24" power supply BN44-00195A first stage voltage?
  • gsmtechno
    • Oct 2014
    • 24
    • Tunisie
    #101
    Re: Samsung 24" power supply BN44-00195A first stage voltage?
    Originally posted by budm
    But did you check the capacitance of that blue rectangular cap that I ask you to test?
    That is the common failure cap in the 24V power supply section.
    BTW, PS-ON has to be present to turn on the 24V power supply section, you do have that command signal, right?
    I replaced the cm812, ps-on present. i also replace all CAP.
      Next then will have to find out if you get the VCC to SMPS IC for that 24V power supply section.
      • Yannick99
        • Nov 2018
        • 11
        I know it's an old thread... but still, need help. I have a BN44-00195A fixed couple years ago and now new problem. QM801, 802 blown with the 0,22ohm rm801. Also a 100 ohm to the gate of qp801(not in schematic). Replace those parts. Turn on with bulb in serie and this one was turn on.... I tell to myself, i'll try direct. And was working again. 385vdc on big cap, 24v, 5v all was looking fine.
        Reinstall the monitor all was ok and 5 minutes later it wasn't working again. Same mosfet, fuse blown.
        What can be the issue ?
        ______________________________
        https://www.instructables.com/member...instructables/
        • R_J
          • Jun 2012
          • 9588
          So both mosfets QM801 & QM802 blew again? what about QP801? why was the gate resistor bad? What was the marking on the resistor? It is unlikey it went on its own without QP801, RP819 and ICP801s being bad.
          What is the voltage on the large cap now? and do you still have +5v standby?
          • Yannick99
            • Nov 2018
            • 11
            Yes both. QP801 is fine, and the 100 ohm on his gate is was. I dont know why this one blew on first time.
            Now fuse are blew and mosfet are shorted. Must replace that again.
            For the fuse i maybe did an error. It was 100 marking. I put 100 ohm but 100 ohm is 1000 marking. I do not have the priginal resistor but found a picture on internet. I did a red circle.
            https://1drv.ms/u/s!AnKLPDy3pII_vkbe...7DfEy?e=5gE13g
            But a gate have no current so 100 ohm instead 10 dont think it's my main problem.
            Also, my bulb was turned on. Meaning the power supply itself take current without load. I dont know if this is normal ? Without bulb (direct) i had my 385vdc, 24v, 5v like normal.
            • R_J
              • Jun 2012
              • 9588
              If the resistor is marked 100 it is 10Ω NOT 100Ω DP803 zener could be bad
              • Yannick99
                • Nov 2018
                • 11
                Yes, my mistake. I'll check on tomorrow for the zener. Let you know thank you
                • Yannick99
                  • Nov 2018
                  • 11
                  Replaced resistor, check zener = ok.
                  I installed 2 other mosfet. I used irfp460 (to247) just for testing i do not have any 9N50C with me.
                  Now, with no load i pull .1 amp on 120vac.
                  5.2v standby = ok
                  385vdc on cp803 = ok
                  24v output = 22.3vdc i had 24v with 9N50C and i dont have any reason to not have 24vdc again. With no load i dont think that the different mosfet is a problem.
                  Also, at the gate of the mosfet i have 50% of duty cycle. It's huge without any load.
                  At the output of large transformer. Just before the 2 diode. I have 90vdc peak to peak 50% duty cycle. And the other side of diode it's rectified to like i said 22,3vdc.
                  Is possible that transformer itself is short somewhere. The output ohm like 0,2ohm and if i short my probe i read 0,2ohm so... looks short to me! But if this was shorted, i couldn't have 90vdc peak peak... i dont know
                  • Tynan Dill
                    by Tynan Dill
                    Assuming...
                    11-22-2024, 01:46 PM
                    Adjustable Boost Power Supply DC-DC Constant Voltage Current Charging Module
                    I want to know if I could hook up a solar panels to this boost converter would I have any issues doing and I would have issues what would they be
                    https://www.ebay.com/itm/116497313155?var=416785404161
                    Here are some of the description from the eBay seller
                    The main parameters:
                    1. Product name: High-power non-isolated DC boost module power supply.
                    2. Product model: 100A2000W.
                    3. Input voltage: DC12V-60V.
                    4. Input current: 100A (maximum)....
                    05-18-2025, 09:45 AM
                    09-07-2024, 05:50 AM
                  • cheeky2
                    Samsung BN44-00262A H37F1-9SS power supply help finding blown value components!
                    by cheeky2
                    This Samsung combined power supply and inverter was replaced a while ago from a Samsung 37inch LE37B530P7W TV. However I would like to repair this one.
                    I have replaced the Mosfets Q1820 and Q1821 ( FDPF7N50U) which were both blown and the fuse FM802S. The schematic for this power supply that is attached doesn't relate to this power supply as the driving transistors and diodes are D1830, D1831, D1832, D1833, Q1811 & Q1810 are nowhere on the schematic!
                    Does anyone know what the components for D1830, D1831, D1832, D1833, Q1811 & Q1810 should be? I ask as I did change the Mosfets...
                    06-15-2025, 05:12 AM
                  • Jembang
                    coocaa 50S5G smart tv dropped voltage when connecting power supply to mainboard
                    by Jembang
                    good day hoping someone can lend a hand, im repairing smart tv 50 inch, status when turning on back light is dim but you can see the tv logo then slowly fading out to black, i check the supply to tcon, i only read 5+v, must be 12v, i removed lvds cable and check voltage to mainboard turned on its also 5v, then i remove the cable mainboard to power supply, i read 12v in power supply, thinking that the problem is in the mainboard, coz theres 12v in power supply, i also check while turning on checking volts in main board 12v dropping to 5v, im just new repairing in TV, hope someone see my post t...
                    11-01-2024, 09:55 AM
