IBM L170 17" monitor "2 second on then black"
  • killian6pk
    • Apr 2010
    • 502
    Re: IBM L170 17" monitor "2 second on then black"
    I just checked and it is on that site. Pick IBM from first drop down box and then L170 in the next and hit enter.
    Have you ever stopped to think and then forget to start thinking again?
    As a very wise man once said on this forum: "Of all the things I have lost I miss my mind the most."
      Unfortunately, the diagram does not match his board, the circuits in the manual uses Royer Oscillator setup TYPE with different PWM IC.
      • jetadm123
        • 2169
        #43
        budm- great job on tracing out the board!
          Thanks! you are correct that there are transistors for switching hte PWM IC ON/OFF.
          • ilikesteel
            • Jul 2012
            • 284
            • usa
            #45
            selldoor-budm-killian6pk-rtech,
            wow, amazing what you guys can deduce without having the board in your possession!
            the two 8 legged ic's are marked 4501M with 430162 underneath the 4501M. they do not look like have been electrically compromised.
            do I need to connect the monitor back to a PC to verify the PO signal is being generated via the interface cable? I should do that before trying to jumper the small transistor or transistors budm pointed out in the diagram.
            I did go to the website and looked at the manual for the L170. a more comprehensive manual than the one I found. the diagrams were definitely better. too bad it does not match my circuit board.
            I'll look over the diagrams and study a little more. I'll double check back before I try jumping any components.
            great work guys. will check it tomorrow. I'm in NJ and it's getting late here.
              We need to make sure that the reason the lamps turn off is not due to the Inverter on signal goes away, yes, you do have to connect the cable to running PC.
              The service manual shows that it uses two transistor to turn on/off the inverter PWM IC, but the rest of the circuits are not the same as yours.
              • ilikesteel
                • Jul 2012
                • 284
                • usa
                #47
                budm&company,
                I checked the voltage as indicated in red markings. yes, there was the 13V at the point you referenced. without the jumper in place there was 0 voltage at the indicated mark to turn on transistors. When I put the jumper in The 13V dropped to about 2.7 to 3.5 and kept fluctuating between those voltages.
                The point where you said the transisitor should turn on was 2.76v and also varying between 2.76 and 3.5.
                at no time was the monitor lit up with a screen image. I may try it tonight without any light in the basement coming through the windows.
                thanks again... any more ideas?
                • jetadm123
                  • 2169
                  #48
                  Did you have the power board connected to the main board and video input from a computer to the main board when you made your measurements?
                  • ilikesteel
                    • Jul 2012
                    • 284
                    • usa
                    #49
                    yes, all were connected.....
                    • jetadm123
                      • 2169
                      #50
                      If I understand things correctly, you jumpered the 13V directly to pins 13 and 18 of the BIT3105, which results in the voltage dropping between 2.7-3.5V
                      Unplug your monitor and try checking the transistor switch (that connects pins 13 and 18 to the 13V rail) that budm identified in his photo for a short. It's probably a standard NPN transistor.
                        He need to put jumper in at the location I indicated, there is a current limit resistor that the 13v will have to go through first then it goes through the transistor (PNP) Emitter, the Collector is the output to VCC pin, I hope he did not connect the 13V B+ line directly through the VCC pin of the IC.
                        If the Main B+ in line drops down to 2~3VDC, it sounds like it cannot handle the load.
                        • jetadm123
                          • 2169
                          #52
                          disregard.
                          • ilikesteel
                            • Jul 2012
                            • 284
                            • usa
                            #53
                            the jumper was connected from one end of the resistor (upper end) that has a black and white number on it, 8200, I believe. the other end of the jumper went above the transistor where there was a solder through component and a small round solder spot with no through the board component in it.
                            sound right?
                            getting anxious!
                            thanks guys.
                            • jetadm123
                              • 2169
                              #54
                              Sounds like you correctly jumpered it after the current limiting resistor. With that jumper still in place try measuring the 13V output at the power supply connector that feeds the main board. If you still see the 2.7-3.5V, that would confirm budm's theory that the power supply cannot meet the load requirements.
                                Or the PWM IC is turning on all the MOSFET's at the same time due to out put drive stuck high (The output drive is setup as a bridge output).
                                To very if the 13V supply is OK is to put a load on it and see if it can handle the current. I think there is an error printed on the board, it shows 13V @ 0.3A, that is way too low for driving 4 lamps circuit which will use about 20~30 Watts of power, 13V @ 0.3A is only 3.9Watts of power.
                                Try using 47 Ohms 5 watts resistor connected to the B+ LINE and ground (monitor plugged into the outlet but not ON) and see if it will maintain 13VDC.
                                  By the way, just want to be sure, the 13V that drops down to about 3V, is it measured at the IC or at the rectifier output?
                                  • ilikesteel
                                    • Jul 2012
                                    • 284
                                    • usa
                                    #57
                                    budm-adm123-selldoor and company,
                                    attached are two pics of the jumper.
                                    I started from scratch and rechecked voltages.
                                    monitor connected to power. interface cable connected to pc that is powered off. power on the monitor is off. lamps connected to PS.
                                    PS supply voltages at the connector with the one blue wire.
                                    +14.25
                                    +5.14
                                    both are solid, no fluctuation.
                                    at the jumper on the low side (as viewing the picture) of the 8200 ohm resistor, same voltage 14.25. on the upperside of the resistor I get 8.36v, same as where the jumper is attached above the resistor.
                                    at the bit3105, there is 8.36v at pins 13 and 18, and it's solid.
                                    With the monitor powered on and the PC powered on:
                                    16.87V and 5.13V between gnd and the pins on the connector with one blue wire. from gnd to the low side of the resistor 8200, I have 16.87V. the opposite end of the resistor and the end of the jumper there is 8.36V.
                                    from gnd to pins 13 and 18 on the bit3105 there is 8.36V. all voltages are solid no fluctuation.
                                    I don't have a 47 ohm 5 watt resisior on hand to check the 13.V with an external load. If you think this is really the next step, I'll go and find one and make the test.
                                    much thanks and patience....... what a crew.
                                      Post 47 "I checked the voltage as indicated in red markings. yes, there was the 13V at the point you referenced. without the jumper in place there was 0 voltage at the indicated mark to turn on transistors. When I put the jumper in The 13V dropped to about 2.7 to 3.5 and kept fluctuating between those voltages."
                                      Now I am confused, where did you check and see that big voltage drop. in the your last post57, it does not look like you have that big voltage drop.
                                      • ilikesteel
                                        • Jul 2012
                                        • 284
                                        • usa
                                        #59
                                        budm,
                                        reread post #47. I don't know how to answer that starnge occurance. in my last post I doubled checked all voltages as indicated. I did it twice and came up with the same solid reading voltages which were not fluctuating.
                                        is the 8.36V a valid reading at pins 13 and 18?
                                        don't forget the jumper is still in.
                                        could the variying voltage levels I had before be because there was NO pc connection to the monitor? with the pc connected I don't see the flashing LOGO anymore, just a dark screen.
                                        much thanks everyone..... hope we're close.
                                          When that jumper is installed, we are basically bypass the switch (transistor) forcing the inverter to be on (backligts on) all the time when you plug in the power to the monitor.
                                          Since the 13V fed through a voltage dropping resistor, I do not expect the VCC for the I to be at 13V due to dropping resistor.
                                          Do you see any lights on the backside of the panel at all? I think at this point you will need test lamp to verify the Inverter circuit function.
                                          • 3D Modelka
                                            AOC 27 monitor Q27G2WG4 doesn't display logo or image on screen
                                            by 3D Modelka
                                            Hello. I have a problem with my AOC 27 monitor, specifically model Q27G2WG4, which I have been using for 3 years. The monitor stopped turning on: when I turn it on, the backlight turns on, the indicator starts glowing white, but the logo on the screen does not appear, and there is no image. However, if I check in the Windows system, the monitor is displayed as connected and working. I tried connecting it via HDMI and DP, but the result remains the same. If I turn the monitor on and off multiple times, it will eventually start and work. However, when the monitor is working, there are no issues....
                                            02-09-2024, 02:42 AM
                                          • valscu
                                            EIZO SW3031W monitor blue color instead of black
                                            by valscu
                                            I have an Eizo SX3031W monitor and after a period i had problems with the tcon board. I did reflow, it went well for a while after but the problems appeared again. The second reflow attempt was a failure, the tcon board stopped working. In the meantime, I bought a perfectly functional Samsung 305T monitor from which I took the tcon board and installed it in the Eizo monitor. Since I turned on the monitor, the blue color appeared in the background instead of black. And also in Windows, appears blue instead of black. I tried various settings from the monitor and driver settings but...
                                            08-10-2022, 02:08 PM
                                          • Ihandyrepair
                                            4 red flash led 65X950G boot Sony and android logo but then black
                                            by Ihandyrepair
                                            HI guys
                                            I got here a Sony 65X950G - I tried to find any repairs guides for this model but not many online
                                            here is the issue
                                            I have Sony and android logo. but then 4 led red flash lights front of the tv
                                            I have 3.3v ref. 12v reg then T con 12v when I press the power on button
                                            but then I get black screen and 4 red flash light at the front LED
                                            but I get 3 led flash on the LED driver board.
                                            I check that few X900F or C YouTube repairs, seems that if you have 4 led red flash it could be due of LED black light error
                                            so I tried...
                                            07-11-2024, 01:45 AM
                                            by momaka
                                            03-15-2023, 10:17 PM
                                          • sew333
                                            monitor AORUS AD27QD - short circuit and tripped breaker.
                                            by sew333
                                            Hello. I had a good monitor AORUS AD27QD. Yesterday when i was sleep i left monitor on like always. When i woke in morning there was not power in house. Something tripped breaker/fuse.
                                            When i turn up breaker and power back in,monitor just refused to turn on. So monitor i guess tripped breaker somehow and make short circuit.
                                            PC starting normally. Only monitor get damaged.
                                            During night only pc was running and monitor. Other devices was off.
                                            Is this possible that monitor can trip breaker?
                                            02-24-2020, 07:46 AM
