Chimei 5MS To 2MS RR, Possible?
  • bigjohn22
    • Jun 2012
    • 22
    G'day
    This is my first post here and feel lucky I found you, guys as I'm not very good with electronics.
    I have the guts of a Chimei 19" 2MS screen (circuit boards) from a monitor I broke the screen. Can I use these boards into a 22" Chimei 5MS to get fastter refresh rate from it?
    Thanks for any answers
    John
  • selldoor
    Slow Learner
    • Dec 2010
    • 7870
    Re: Chimei 5MS To 2MS RR, Possible?
    The 5MS and 2MS you refer to is not the refresh rate which is usually 60hz or
    75hz?
    You are referring to the response time? if so, this is probably a characteristic of the panel and will not be improved.
    If you wanted to try you would need to change the mountings unless the boards had exactly the same fixing positions and also check that any
    interconnecting sockets matched exactly. I have to say we do not have many people on here trying this - its is sometimes hard enough getting replacement boards off supposedly exactly the same monitor to work.
    Perhaps someone who has done it before will be of more help.
    • bigjohn22
      • Jun 2012
      • 22
      Thanks for answering.
      I told you I didn't know much and thank yo for educating me. It may seem crazy but I always try to fix things, sometimes I get it right sometimes I don't.
      Thank you
      John
        You should find out first if the 19" inverter will have enough power to drive the 22" lamps
        • bigjohn22
          • Jun 2012
          • 22
          Thank you
            Many of these ultra-fast refresh rate screens use trickery to achieve the response time, by overdriving the pixels. I don't like this; you can often see shadows when things move fast across the screen. The overdriving is done on the T-con board, which is permanently affixed to the panel in most cases. It may be possible to enable overdriving in your video card's configuration software to achieve a very similar effect.
            • bigjohn22
              • Jun 2012
              • 22
              I'm liking this. The more I read these threads the more I like the subject.
              Thanks guys
              John
                CHIMEI InnoLux M185BGE-L22 TFT LCD Datasheet
                M185BGE-L22 is a 18.5" TFT Liquid Crystal Display module with WLED Backlight unit and 30 pins
                1ch-LVDS interface. This module supports 1366 x 768 HD mode and can display up to 16.7M colors. The
                converter module for Backlight is not built in.
                Screen Size 18.51” real diagonal
                Driver Element a-si TFT active matrix
                Pixel Number 1366 x R.G.B. x 768 pixel
                Pixel Pitch 0.3 (H) x 0.3 (V) mm
                Pixel Arrangement RGB vertical stripe
                Display Colors 16.7M color
                Transmissive Mode Normally white
                Surface Treatment AG type, 3H hard coating,...
                11-05-2024, 07:48 AM
              • seascoot
                Need to identify transistor on Chimei M220Z1-L03
                by seascoot
                Hi all.
                I have a burned out transistor on the integral t-com board of a Chimei TFT panel. The panel is a M220Z1-L03 and the board is labelled M$35-D024790. Since the component is burned out I can't read any ID on it. It is marked Q4 on the board.
                Any chance someone can ID this or direct me to a schematic? I googled all over the place, but could find nothing.
                Would also appreciate any views on the likelihood of having success by just replacing this transistor.
                Thanks!...
                10-09-2020, 12:39 PM
              • petehall347
                John Deere AM137667 components identification .
                by petehall347
                what are these black things to the right of the ic chip . ? both test as shorted ....
                03-04-2022, 01:48 PM
              • double_DD
                Why does my ISP router hate my "homemade" power supply??
                by double_DD
                It's gonna be a long intro, so please buckle in, as it's a problem that's been bugging me for several days now. Thanks in advance.
                So, I have 2 modems/routers, whatever the proper nomenclature is, one from ISP and one mine. I want to power them via USB-C rather then their original mains adapters (for reasons, that are hard to explain to sane people). Both routers come with 12V/3A mains adapters.
                For this purpose I acquired USB-C charger with 250W and 5 ports, 2 of which can supply max 20V/3A. Since 12V isn't a standard PD voltage option (and to future proof,...
                07-12-2025, 03:09 AM
              • DrewPhillips
                Capacitor Diarrhea - Nichicon PL Series
                by DrewPhillips
                Hello All, I have on the bench a couple of PSU's which have some failed Nichicon PL series caps. They didn't "puke" their guts through the top, but instead "diarrhea'ed" corrosive brown electrolyte through the bottom, down the legs and onto the board. On one cap, the electrolyte rotted the cap right off the board leaving 2 little stubs, and also corroded a trace on the foil side.
                The PSU's are Power-One MAP series and are ringing-choke topology. The semiconductors have date codes in 1993. The PSU's were used in a commercial application, fan-cooled. They had failed...
                03-02-2025, 10:18 PM
