204B freezes after caps replace
  • whotopia
    • Oct 2013
    • 8
    • Switzerland
    Re: 204B freezes after caps replace
    If the power supply is putting out 13.06-13.07 V on the DVM, can we consider it stable? I have this situation, but the logic board still seems to not be sending correct voltages back for dimming etc, and the power button won't light. So is this a bad logic board, or still potentially bad power supply? My supply ultimately failed enough to leave brown mark on the shielding. I replaced all the caps.
      "13.06-13.07 V" that is fine as you can see in the other post on this thread.
      • whotopia
        • Oct 2013
        • 8
        • Switzerland
        Just an update for my case:
        As I own more than on 204B, I swapped logic boards from a working unit. This immediately solved the problem.
        I found a Chinese source for the part and ordered a new replacement signal/logic board (BN41-00620F Driver Board) from here:
        http://www.baoseek.com/index.php?cPa...=products_list
        But there are plenty of other sources available:
        http://www.ledbos.com/index.php?main...oducts_id=8113
        http://www.lcd-pdparts.com/ViewDetai...ProductID=5975
        http://www.dhgate.com/product/drive-...159977847.html
        http://www.ebay.fr/itm/Samsung-204B-...item2c6963ecaf
        • romavnts
          • Oct 2015
          • Russia
          I had the same problem with 204B - monitor sometimes freezed after powering on.
          Shortening pins 5 and 6 of EEPROM A81SC (24C08) made 204B working.
          But there was no physical damages in 24C08 nor in it's dump.
          The cause was the bad capasitor C609, which did not smooth IC602 (1.8V voltage regulator for powering MCU) output.
          • RJARRRPCGP
            • Jul 2004
            • 6304
            Originally posted by ztrekr
            Yes, I'm in Europe, but not in the UK.
            Ok, then I will try to find proper capacitors, replace them and see what's going to happen.
            Europe is almost always 230, IIRC.
            ASRock B550 PG Velocita
            Ryzen 9 "Vermeer" 5900X
            Arc A770 16 GB
            eVGA Supernova G3 750W
            Alienware AW3423DWF OLED
              by momaka
              03-12-2025, 03:42 PM
            • Paxman_Swede
              by Paxman_Swede
              Hello!
              01-14-2025, 09:51 AM
            • edith
              Caps and how to find one to replace
              by edith
              Hello everyone I have a question. I have a laptop and his schematic. Can anyone tell me how to measure or any way to understand specific of caps so i can buy new one?
              Also in case how can I understand if some caps of some dead Mobo i have, are ok to be replaced in my new motherboard which im trying to fix?
              Thank you!
              06-11-2023, 05:00 PM
            • madscientist750
              Replacing electrolytic caps by solid caps on old motherboards
              by madscientist750
              I do have several old pc motherboards which i recapped 10 year ago and some of those caps are bulged now.
              I would like to upgrade them using solid capacitors. I do use them for testing and helping some alternative operating systems.
              I would like to ask if such an upgrade can be done, what should i have in mind when replacing electrolytic by solid caps and if such thing exist, if there are caps list for old motherboards. I would have to figure out what caps needs each motherboard and then prepare a list to try to ask for them on some electronics stores.
              10-19-2025, 06:10 AM
            • Mattz_GT
              Which caps to replace: ECS P4M800Pro-M V1.0A
              by Mattz_GT
              It's feeling like this board has a case of badcaps, instability and reboots - and not wanting to necro a a very old thread, it seems the 680uF 4V are highly suspect.
              I don't really want to blanket recap everything, but maybe the others around that area could do with being changed?
              Equipment: I have a temperature controlled soldering station, read the bit where it says set to 400F, don't think I would have gone that high without reading that.
              Spring plunger solder sucker, and some desolder braid... and a bit of good old leaded 60/40.
              PS. Additional diagnostic,...
              01-22-2025, 12:12 PM
