Princeton VL193 intermittent flicker
  • ravenor
    • Sep 2011
    • 27
    My VL193 flickers intermittently. The flicker usually goes away when I power it off and power it back on but sometimes it remains. I have posted pictures of an overhead view of the power supply and two closeups of the inverter.
  • retiredcaps
    • Apr 2010
    • 9271
    Re: Princeton VL193 intermittent flicker
    1) It could be those two caps on the inverter board that are causing the flickering.
    2) Check the DC voltages on the connector to the inverter board and see if they are stable or fluctuating.
    --- begin sig file ---
    --- end sig file ---
    • ravenor
      • Sep 2011
      • 27
      How would I test the DC voltage? Sorry, I'm still pretty new to troubleshooting electronics.
      • retiredcaps
        • Apr 2010
        • 9271
        Do you have a multimeter? If yes, post a picture of it.
        • ravenor
          • Sep 2011
          • 27
          Yes I have one.
          • retiredcaps
            • Apr 2010
            • 9271
            Yes I have one.
            Okay, one retiredcaps' bonus point for having a Fluke 83 III.
            1) Set your Fluke 83 III to DC volts (2nd switch position - V with the solid line and dash line).
            2) Plug in and power on your lcd. Hookup a working computer displaying your favourite wallpaper.
            3) Put your black probe on a ground screw on the inverter board.
            4) Put your red probe on each colored wire on connector CN1 on the inverter board.
            5) Number each pin and report each DC voltage reading. See if the readings are stable or fluctuating during the flicker.
            See my fellow Canadian Afrotechmods' excellent multimeter tutorial (5 minutes long)
            http://www.youtube.com/watch?v=bF3OyQ3HwfU
            • retiredcaps
              • Apr 2010
              • 9271
              PS. If you ever think about selling your Fluke 83 III, send me a PM.
              • retiredcaps
                • Apr 2010
                • 9271
                Post a picture of the logic/main board as well. Flickering could also be due to a bad voltage regulator on the logic/main board. Bad caps on the logic/main board is another possible cause.
                • ravenor
                  • Sep 2011
                  • 27
                  I have tested all the voltages and they are all stable(they changed by at most 0.01 volts). Here's the mainboard.
                  • ravenor
                    • Sep 2011
                    • 27
                    Thanks for the offer but I don't think I'll be selling it soon.
                    • retiredcaps
                      • Apr 2010
                      • 9271
                      I circled what I think are 3 voltage regulators.
                      1) Plug in lcd and power on. Hookup a working computer again. Put your Fluke 83 III into DC voltage.
                      2) Put your black probe on a ground screw on the main board.
                      3) Put your red probe on each pin of each component except for the top tab.
                      4) List the part number of each component and its DC voltage reading for each pin.
                      5) Report findings like so
                      IC100
                      part number = 7805
                      pin 1 = 0.0V
                      pin 2 = 5.0V
                      etc
                      6) Try to take this readings while the monitor is flickering.
                      • ravenor
                        • Sep 2011
                        • 27
                        I think I've solved the problem for now. It turns out that the refresh rate was set to 75Hz, after I changed it to 60Hz, the problem went away.
                        • retiredcaps
                          • Apr 2010
                          • 9271
                          I setup my Windows only to show supported refresh rates.
                          • ravenor
                            • Sep 2011
                            • 27
                            Same here, and 75Hz was supported but it still caused the problem.
                            • x_orange90_x
                              by x_orange90_x
                              01-29-2025, 09:24 PM
                            • protocold
                              MacBook Pro 15" 2010 820-2850 intermittent charging
                              by protocold
                              I would like to get some help on a 820-2850 logic board with intermittent charging problem. Sometimes the battery will charge all the way and sometimes magsafe would be cycling between green and orange.
                              I have already tried replacing dc-in board, swapping good battery, swapping genuine 85w chargers. None of that helps..
                              when it is not intermittent:
                              PPVBAT_G3H_CHGR_R is 12.07v
                              when it is intermittent:
                              When the light is green, PPVBAT_G3H_CHGR_R is 12.99v
                              when the light is orange, PPVBAT_G3H_CHGR_R is 11.62v
                              data line on the battery...
                              07-25-2025, 08:18 PM
                            • Gentian
                              APSINT3636VR 3600W APS INT Series 36V DC 230V AC Inverter/Charger schematic
                              by Gentian
                              I have a tripp-lite aspint 3636vr inverter charger which blow some of mosfet transistors. I replaced them repaired also the driver circuit and tested but the mosfets burn again.
                              It work very well as inverter and also as charger if I let the rear switch in auto mode (inverter) and charger only(charging) but in auto when I connect the feed line 220V AC first time it pass ok to line and start charging the batteries but when I remove the feed line it pass to inverter mode and if I do it again the second time when passing from charging to inverter the Main transformer start making a...
                              03-06-2023, 07:07 AM
                            • valvashon
                              Insignia NS-LCD19-09 (PS OK, Inverter problem?)
                              by valvashon
                              For some reason I'm just not going to let this 19" TV defeat me. I guess because I have a schematic to work from I feel like I'm oh so close.
                              History- while adding a turn-on circuit I let a small screw roll under the power board. Worked through all of that circuitry, probably replacing a MOSFET and PWM controller that were not bad but I was following the service manual. Finally figured out that the power supply is in working order when the inverter section (for the backlights) is disconnected. When the +12 supply to the inverter is disconnected the +12 and +5 will come up...
                              01-04-2024, 01:44 PM
                            • fixit007
                              Samsung flicker - BN44-00932T board or else?
                              by fixit007
                              I picked up this TV that the prior owner said - just died.
                              Tested the fuse - burnt. A dead capacitor is visible too on the hot side (CP801). Got the replacement power board (cheaply - used). Replaced the board - the TV turned ON!
                              Now, about a month later (yesterday) I noticed the left side of the screen was flickering from time to time. That was already happening with the antenna input, not through HDMI.
                              Also, some glitchiness with a Fire stick on HDMI3 - I hit an app with quick dark screen in stick, the TV goes - no input. Then I had to choose the stick...
                              05-04-2024, 06:14 PM
