MacBook Pro 15" 2010 820-2850 intermittent charging
  • protocold
    • May 2019
    • 24
    I would like to get some help on a 820-2850 logic board with intermittent charging problem. Sometimes the battery will charge all the way and sometimes magsafe would be cycling between green and orange.
    I have already tried replacing dc-in board, swapping good battery, swapping genuine 85w chargers. None of that helps..
    when it is not intermittent:
    PPVBAT_G3H_CHGR_R is 12.07v
    when it is intermittent:
    When the light is green, PPVBAT_G3H_CHGR_R is 12.99v
    when the light is orange, PPVBAT_G3H_CHGR_R is 11.62v
    data line on the battery sdl/sda = 3.3v.
    Here are u7000 voltages when it is green.
    1 = 0v
    2 = 15.8v
    3 = 3.88v
    9 = 0.62v
    12 = 3.4v
    13 = 3.4v
    14 = 3.26v
    15 = 0.072v
    19 = 5.1v
    20 = 5.02v
    27 = 16.4v
    Any help would very much appreciated. Thanks!
  • C152Heavy
    Samsung LN46C630K1F – Intermittent Backlight, BN44-00341B Power Board
    by C152Heavy
    Summary for TL-DR readers:
    • Backlight is intermittent, may come on with TV boot or not. No flickering, never fails during TV on.
    • Have obtained Samsung schematic & service documents - Can upload if helpful.
    • Have read ALL applicable threads
    • C1818 and CP820 replaced as low hanging fruit
    • CN802 data taken for normal and failed BL operation. SUMMARY: Pin 2 - 5vDet = 3.52 @normal, 0.0 @BL fail. Pin 6 - EPWM = 1.631 @normal, 1.058 @BL fail.
    • VCC pin (18) of PFC...
    01-11-2023, 02:53 PM
  • wesc0
    MSI G513QR - G533-6050A3250201-MB-A03(A3) - Intermittent Charging
    by wesc0
    Hi all, have a strangely behaving laptop that's giving me issues. It charges thru the barrel jack, but when I watch the battery indicator in BIOS, the charging indicator flickers off and on. When I plug the charger in, I hear hissing from around the area of L67050. I also had an intermittent issue where the fans weren't spinning up at all, allowing the CPU to reach 100C+ in BIOS and OS - this cleared itself up after I left it overnight but of course I don't trust that it'll stay that way. USB C charging works fine.
    Any advice or direction is greatly appreciated! If there's any...
    09-30-2025, 07:58 AM
    Apple MacBook Air 13'' LATE 2010 820-2838 820-2838-A 820-2838-B Boardview
    Apple MacBook Air 13'' LATE 2010 820-2838 820-2838-A 820-2838-B Boardview...
    10-22-2024, 02:37 AM
  • Zippo978
    Telefunken te43550b40q2k intermittent backlight
    by Zippo978
    Good morning everyone
    I have this Telefunken te43550b40q2k TV that has intermittent backlighting, sometimes it turns on and then does not turn back on.
    I tested the LED bars and all three work, not even one burned LED, then I tried to put only two bars short-circuiting the end of the connection cable and it does not give any problem the LEDs stay on without problems, I also tried short-circuiting the central connector and the initial one, always no problem, but as soon as I put the third bar, no matter the position the problems start again.
    Thanks in advance...
    09-04-2024, 01:35 AM
  • BigPete
    Intermittent display on Sherwood Newcastle R-965 Receiver
    by BigPete
    I'm working on a Sherwood R-965 at the moment. It came in with relays clicking constantly and also going into protect mode.
    I've re-soldered a lot of dry joints and replaced quite a few capacitors and now it works, but I still have one problem I haven't solved and would like some opinions.
    The vacuum display is quite intermittent. Sometimes it won't turn on, sometimes it will turn on but the characters, numbers and letters are frozen on, regardless of which buttons are pushed. And sometimes it works flawlessly. If the display doesn't turn on initially, restarting...
    08-25-2024, 02:48 AM
