Dell E228WFPC goes dim after 10 minutes, not 2 seconds
  • smalltownguy
    • 127
    • US
    #81
    Re: Dell E228WFPC goes dim after 10 minutes, not 2 seconds
    Wow...I'd almost forgotten about this. Glad someone else could make some use of it!
    • Josephur
      • Mar 2015
      Ugh, problems though.. Monitor was working great after the C806 reflow.. then I put it all back together and now the lower 2/3rds of the monitor aren't working
      They are lighter than the top 3rd which makes me think the LCD row drivers now have an issue? What the hell could I have done wrong? I've disassembled the whole thing again and now I'm to my wits end, this monitor is about ready to go to the trash can
      • newtothis
        • Mar 2013
        • 1556
        • england
        #83
        You say you shoved the IC around, Have you created any bridges etc?
        Just adding flux and reflow without moving it around is enough btw
        • 1supertech
          • Apr 2012
          • 384
          Hello everyone I am here to confirm that reflowing c706 cured my monitor problems
          Tested for 1 hour and still running
          • beavrtek
            • Jul 2015
            • 3
            Hi 1supertech,
            Would you please give a little more detail on c706. I can't locate it on the main board of my E228WFPC (yes,"C").
            Has the matter of c706 in relation to this unit already been discussed? I was unsuccessful with a forum search.
            Thanks much,
            beavrtek
            • beavrtek
              • Jul 2015
              • 3
              btw, the issue I'm dealing with is the loss of backlighting within 2 sec of power on. ty.
              • beavrtek
                • Jul 2015
                • 3
                Unless you meant c806? That would make sense. disregard.
                • al.rob
                  • May 2015
                  I just found one of these monitors in the trash yesterday and it had this same issue. I removed C806 and tacked on a 1uf 50V electrolytic (neg on the pad that connects to D812) since that is what I had. The monitor is working now. Thanks for the help.
                  • Bowline
                    by Bowline
                    06-11-2025, 10:13 AM
                  • aaronkatrini
                    DELL Nvidia GTX 750Ti Mosfet goes short after a few minutes
                    by aaronkatrini
                    I have recently picked up this Dell OEM Nvidia GTX 750Ti 2GB Video card. Its an old card I know but still wanted to get it working if possible. The problem is the following:
                    - Put the card in my testing motherboard and start running Heaven benchmark
                    - Benchmarks seems to run smoothly up until half way then the motherboard completely shuts off immediately
                    - Try to start it again and I get a slight move from the PSU fan - a clear short
                    - A little troubleshooting later I find one shorted Mosfet - Replace them both - short is gone
                    - Put the...
                    05-18-2025, 04:18 PM
                  • DrFalken
                    Dell Inspiron 5593 shutdown after 5 seconds
                    by DrFalken
                    Hello everyone!
                    Motherboard model: FDI55 LA-J081P
                    Today a customer delivered this laptop completely dead, with the original power supply shorting when plugged into the connector.
                    I found and replaced a shorted MOSFET (PQZ3).
                    Now the laptop turns on (fan runs fine but no video signal) and after 5 seconds it turns off.
                    BIOS has already been updated (both 64MB and 128MB IC)
                    +3VALW and +5VALW are still present.
                    +VCCIN = 1.8V stable (measured on PLZ1 at power up)
                    Abnormal readings:
                    PLZ1 to GND = 0 Ohm
                    PLZ2 to GND = 0 Ohm
                    04-09-2025, 10:45 AM
                  • Akhlz001
                    by Akhlz001
                    09-20-2025, 07:15 PM
                  • Kambi13
                    Dell Inspiron 3542 Turns on works for 30 seconds to 1 minute then turns off
                    by Kambi13
                    Hi all need some help, I've got a Dell insprion 15 3542 that turns on works for about 30 seconds or sometimes a minute or two and then turns off and wont turn on again until I remove and replug the power connector
                    Not heat related, everything is ok regarding to that.
                    All voltages are present.
                    Wondering if this as anything to do with one wire circuit, the charger is not original, but it was working fine
                    Motherboard is Cedar 13269-1 F3XMC Rev A00...
                    07-12-2024, 06:10 AM
