Inverter tester using old CFL
This is a sticky topic.
    Do not throw away those broken CFL (14Watts or smaller), you can use them for testing your LCD monitor inverter circuits without buying spare lamps for testing.
    You can solder the wires directly to the connectors on the inverter board or you can get the correct connectors but then you have to have more than one type.
    I tested it out on my lamp tester board as you can see in the pictures.
    I open up the lamp assembly using small hack saw just enough for me to crack it open, just be real careful.
    Enjoy!
  • retiredcaps
    • Apr 2010
    • 9271
    Re: Inverter tester using old CFL
    Cool, I will provide this link in rev 0.4 of the 2 seconds to black guide sometime in the future.
    --- begin sig file ---
    --- end sig file ---
      How do you remember where the REV0.4 is? Is there a place in this forum that how to are kept?
      • retiredcaps
        • Apr 2010
        • 9271
        There is no formal tracking or process controls on this site as far as I know. I just keep my own thread and keep adding to the end of it and keep my own version control.
        A bit unsophisticated, but is works okay.
        • Jasgriff
          • Feb 2012
          • 578
          Looks good definitely a good idea for someone wanting to do a one off monitor repair. If you could even take out the lamps inverter board then solder the lamp directly to the bottom of the bulb fitting and glue the base back on. That way you could mount a bulb holder to you inverter tester board.
          Retiredcaps any chance you could link to your 2 seconds to black in you signature then it will be easier to point people in the right direction
          Fixed so far : 1 Home cinema system, 16 LCD Monitors, 4 LCD TV's
          How to resize your pictures guide click HERE
          Retiredcaps Ideal post example click HERE
            master hoarder
            • May 2008
            • 12170
            • Bulgaria
            Nice experiment. I too was thinknig about trying the same thing but that experiment always got delayed or left for other projects.
            Definitely good to know, though. I guess this will go on my "to-build" list now. Last month, we had a CFL light die in the house and I took it appart. Bad solder joints on the driving transistors (13003's) killed one of them. The CLF bulb probably still works, though. So looks like I have all of the parts needed .
            • ashraf osman
              • Apr 2012
              • AL Mansora
              Best regards
              A nice experience.
                Update with T5 4Watts lamp
                  master hoarder
                  • May 2008
                  • 12170
                  • Bulgaria
                  It's the hot Chilli Powder that makes everything work
                  Cool stuff
                  • dcooke570
                    • Jul 2012
                    • 11
                    OK. I have 13w and 23w CFLs but no 14w.
                    Does the wattage matter if all I'm using is the top half?
                      That will be too big (the 23W), 14w or smaller as shown will work. I did not try with other 13/14W with big body (such as used for under counter lights) yet to see if it will light up. Your 13W CFL twisted bulb should work.
                      • rogfanther
                        • Jul 2006
                        • 458
                        • Brazil
                        Would the inverse also work ? Like, using a bulb inverter circuit to test the lcd lamps ?
                          The inverter for the HOME CFL is made for driving CFL with starting filaments, it does not use the high voltage (1500~2000V) for starting the Ionnization like CCFL does, CCFL does not have filament.
                          • rogfanther
                            • Jul 2006
                            • 458
                            • Brazil
                            Oh, ok. Thanks.
                            • jlk69
                              Fix stuff
                              • Nov 2009
                              • 22
                              Would this bulb work?
                              I fix therefore I am.
                                Way too big even though it is the same wattage. I tried many shape and size and so far the curly one with 10~14W seems to work well.
                                • jlk69
                                  Fix stuff
                                  • Nov 2009
                                  • 22
                                  Wow, thanks for the quick reply. Looks like I will have to sacrifice a new bulb in the name of science. From the pictures I surmise that you don't need hook up to screen to test. Do you have to have a signal coming from the computer? Looks like that was not connected as well. Also, do all of the leads have to be hooked up to bulbs (mine has 4 leads for 4 bulbs?)?
                                    I force the bl_on line on mt tester board, you will have to have your monitor connected to the running PC but you do not need to have the screen T-CON connected.
                                    You have to have 4 working lamps, if one failed or not connected, the inverter will go onto shutdown mode.
                                    • jlk69
                                      Fix stuff
                                      • Nov 2009
                                      • 22
                                      I was afraid of that. So I might need to make as many as 4 test bulbs? Or I could try hooking 3 up to LCD with 1 test bulb and hope only 1 CCFL is bad in my monitor and keep trying until lamps stay lit.
                                      • Measuray
                                        • Feb 2012
                                        • 5
                                        Enjoy!
                                        Would a device like this workout more better?
                                        http://www.lcd-pdparts.com/ViewDetai...ProductID=1813
                                        CCFL & LCD TV Monitor Backlight Tester
                                        VIP Price:$16.30
                                        Last edited by Measuray; 02-21-2013, 12:07 AM. Reason: Forgot to add Youtube Video: CCFL Tester Laptop Screen Repair LCD TV Monitor ... - YouTube
                                        • Yanleb
                                          Sharp LC-60LE810UN Lamp Error
                                          by Yanleb
                                          I have this Sharp LC-60LE810UN that stays off and blinks a Lamp Error (1 long flash followed by a short flash, in a loop).
                                          I already confirmed that the first backlight strip has an open LED using a LED strip tester. The other 3 LED strips are fine.
                                          Before tearing the LCD panel apart, I want to make sure that the rest of the TV set is good. I've tested the power-supply/LED inverter board by sending 5 volt to PS-ON, to PNL-POW (that commands power the T-CON board only), OFL and STB pins. The power-supply is good.
                                          I've tried all the key...
                                          08-24-2021, 11:48 PM
                                        • vestaviascott
                                          Epson 5040UB Projector No Lamp Strike Stuck in Startup - Blinking Status/Lamp Lights
                                          by vestaviascott
                                          Hoping someone here can put me on the right track. I'm trying to troubleshoot/flowchart the "internal projector error" on my newly acquired Facebook Marketplace bought Epson 5040UB projector (3LED, not DLP). Owner said it needed new lamp, actually error code blink pattern indicates "Internal Projector Error, call Epson support". Unit is out of warranty as of 8/19
                                          Here's what happens:
                                          1) Power on
                                          2) Blue power indicator lights and the lens cover motor opens the lens cover, light fan noise heard
                                          3) Blue status light flashes for appx 4 minutes...
                                          07-29-2020, 06:08 AM
                                        • Gentian
                                          APSINT3636VR 3600W APS INT Series 36V DC 230V AC Inverter/Charger schematic
                                          by Gentian
                                          I have a tripp-lite aspint 3636vr inverter charger which blow some of mosfet transistors. I replaced them repaired also the driver circuit and tested but the mosfets burn again.
                                          It work very well as inverter and also as charger if I let the rear switch in auto mode (inverter) and charger only(charging) but in auto when I connect the feed line 220V AC first time it pass ok to line and start charging the batteries but when I remove the feed line it pass to inverter mode and if I do it again the second time when passing from charging to inverter the Main transformer start making a...
                                          03-06-2023, 07:07 AM
                                        • valvashon
                                          Insignia NS-LCD19-09 (PS OK, Inverter problem?)
                                          by valvashon
                                          For some reason I'm just not going to let this 19" TV defeat me. I guess because I have a schematic to work from I feel like I'm oh so close.
                                          History- while adding a turn-on circuit I let a small screw roll under the power board. Worked through all of that circuitry, probably replacing a MOSFET and PWM controller that were not bad but I was following the service manual. Finally figured out that the power supply is in working order when the inverter section (for the backlights) is disconnected. When the +12 supply to the inverter is disconnected the +12 and +5 will come up...
                                          01-04-2024, 01:44 PM
                                        • AJ847.63e
                                          BenQ TH681 Originally overheating now wont fire the lamp - Colour wheel not starting
                                          by AJ847.63e
                                          Hi All.
                                          Does anyone have any reference materials or something I can use to try troubleshooting a BenQ TH681? Google unfortunately has turned up zip. I did find a service manual for a W series BenQ but that is pretty much useless, it's more a glorified user manual. A list of voltages would be great as I suspect my mainboard is faulty, the colour wheel voltage is not dipping like it should.
                                          The one I am troubleshooting now was originally overheating after a lamp replacement. It originally would take 2 minutes or so for it to shut off and blink the temp and lamp lights...
                                          09-18-2023, 06:42 PM
