Hp 1955
+ More Options
Posts
  • terminatorX
    • Feb 2012
    • 63
    Hp 1955
    The hp 1955 (Benq 48.L1A02.A00) the monitor was just totaly dead.
    So I opened it and removed the power board. So I found out that one of the three pins on the power cable connector was blown. If you look at the "green" side its the left pin. the center pin was loose and the right pin had cracked solder. So I resoledered it. I think I did I decent job on that but it didn't help at all. The power led didn't go on. also here is no bulging on capacitators or something similar. What do you think, could it be both the C5707 transistors and the picofuse maybe?
  • PlainBill
    • Feb 2009
    • 7034
    Re: Hp 1955
    Don't post pictures inline. It seriousl inconveniences retiredcaps and pisses me off.
    No, it's not the picofuse, and it's not the c5707s.
    Let's do this logically. What is the voltage across the large cap? On the top view there is an 8 pin IC partially obscured the green wire. What is the part number of that IC?
    PlainBill
    • terminatorX
      • Feb 2012
      • 63
      Re: Hp 1955
      Thanks for respons. Just want to emphasize that I'm a real newbie.
      Can I check the large cap without current running through? Not really in the mood of killing my self if do something wrong...
      Ic part number should be 1200AP40,CPBC, 0449 close to a spot called IC601.
      • retiredcaps
        • Apr 2010
        • 9271
        Re: Hp 1955
        No.
        1) Assuming your mains AC is 110 to 120V AC and you have a manual range multimeter, set it to 200V DC. Yes, set it to DC.
        2) Plug your black probe into the COM jack. Plug your red probe into the Volts jack.
        3) Put your red probe on the positive leg of the capacitor. Put your black probe on the negative leg of the capacitor.
        4) If it is working properly, we expect a stable DC voltage reading somewhere in the 165V to 170V DC range.
        120 mains AC x 1.414 (rectified) = 169.68V DC
        --- begin sig file ---
        --- end sig file ---
        • terminatorX
          • Feb 2012
          • 63
          Re: Hp 1955
          Nope the AC is 230V. Don't know how to determine which leg is positive or negative (or even if that matters). Just to make clear....should I plug in the board to the wall as is or mount it back to the screen first?
          • selldoor
            Slow Learner
            • 7870
            Re: Hp 1955
            Please can you update your profile with at least the country you are in.
            The previous instructions need amending accordingly
            TAKE EVEN GREATER CARE
            1) Assuming your mains AC is 230AC and you have a manual range multimeter, set it to 600V DC. Yes, set it to DC.
            3) Put your red probe on the positive leg **of the capacitor. Put your black probe on the negative leg of the capacitor. YES IT DOES MATTER
            4) If you rectify 230 volts AC RMS with bridge rectifier, without Filter capacitor, the meter will read 230 X 1.414 Volts = 325.22 Volts exactly.
            So If it is working properly, we expect a stable DC voltage reading somewhere in the 320V to 350V DC range.
            ** The capacitor probably has a white or pale blue stripe down one side
            with - - - - - - minus signs in it the leg on the same side as the stripe
            is the negative. Note both legs are high voltage.
            The monitor does not have to be rebuilt and I believe for this test the power board can stand alone. Do not rest it on anything metallic and do not touch it other than with the probes. Do not let them slip off the legs and do not touch the board after the test until it has been switched off for at least 5 minutes.
            If you have any time for reading read this:https://www.badcaps.net/forum/showthread.php?t=10419 there are revisions within it so start at
            post 18 .It will give you advanced insight into what further tests may be required.
            • terminatorX
              • Feb 2012
              • 63
              Re: Hp 1955
              Thanks for your good help!
              Not really sure what this is about...AC RMS....
              To be exactly sure what I'm doing. I don't really se an adequat marking for +/- so would it be a good guess to say at the side where there are those minus marking should be the minus pin?
              • selldoor
                Slow Learner
                • 7870
                Re: Hp 1955
                Yes - I believe that is what I said?
                [Quote]
                is the negative.[Quote]
                • terminatorX
                  • Feb 2012
                  • 63
                  Re: Hp 1955
                  Hahha sorry read that part quickly, thought you meant the actual pin was suppose to have a marking....
                  But you still didn't describe what AC RMS rectifier ...filter capacitator...is.
                  • terminatorX
                    • Feb 2012
                    • 63
                    Re: Hp 1955
                    Never mind I did the testing. I have a semi automatic DMM. The capacitator showed 0.5V to verify the plausability of the test I also tested my hp 1940 powerboard that I also have a problem with that is in another thread it showed a very stable 325V.
                    Knowing this what do you belive is the reason the power connector blew it's two soldering points? Is it really the capacitor that is boken maybe the current is inhibited somewhere else...
                    • PlainBill
                      • Feb 2009
                      • 7034
                      Re: Hp 1955
                      1. Benq is notorious for shoddy soldering
                      2. The pins of the power connector can receive a lot of stress when the power cord is plugged in..
                      3. The fuse in the power supply would blow long before any excessive load would destroy the solder on the pins of the power connector.
                      Resolder the pins!!!
                      PlainBill
                      • terminatorX
                        • Feb 2012
                        • 63
                        Re: Hp 1955
                        Ok...
                        So would you say the capacitator is bad? Do you want me to resolder the power connector pins? I just did that.....
                        • PlainBill
                          • Feb 2009
                          • 7034
                          Re: Hp 1955
                          Ok...
                          Let's walk through this. I'm seeing references to another monitor, don't do that. It's hard enough as it is.
                          1. What is the voltage across the large cap?
                          2. Using the minus (-) lead of the large cap as ground, what are the voltages on the pins of the NCP1200AP40? Do this carefully.
                          PlainBill
                          • Krankshaft
                            • Jan 2007
                            • 2328
                            Re: Hp 1955
                            For easier troubleshooting I've attached the main switcher IC datasheet.
                            Post the readings Plainbill suggested and we'll get a better handle on the status of the IC.
                            • selldoor
                              Slow Learner
                              • 7870
                              Re: Hp 1955
                              Ok...
                              No Not the power connector pins - the pins of all the components ringed in red on the earlier picture.
                              I understand you to say that the voltage across the Big cap is 0.5v.
                              Whilst it could be the cap, this may be due a fault in the bridge rectifier
                              which I will mark in a picture. This should be tested initially with the power OFF, with your meter on a test diode setting.
                              Take a multi-Meter and switch it to Ohm x 1
                              Test between one of the "~" and "+" legs.
                              You should get either an almost-zero reading in one direction, and when you reverse the test probes, you should get an almost infinite reading.
                              Now try the same between this "~" leg and "-".
                              Same as above.
                              Now repeat the same tests with the other "~" leg, and "+", and then "-".
                              Same as above.
                              If you either get almost zero or almost infinite in BOTH directions, then the rectifier burnt out.
                              If the rectifier has gone the fuse will probably also be blown - can you test it. (POWER OFF) Can you post any numbers on the Rectifier and the fuse.
                              • terminatorX
                                • Feb 2012
                                • 63
                                Re: Hp 1955
                                So PlainBills and Krankshafts part.
                                Weird part is that i retested the large cap voltage and it fluctuated around 1.4XX volts instead what I said before around 0.5V.
                                Hope I done this properly.
                                Pin 8 had about the same voltage as the large cap voltage and pretty much the same fluctuation. They were more or less synchronized.
                                Pin 7 read -0.008 but also fluctuating. Pin 6 about 0.203. Pin 5-1 read stable zero (pin 3 read actually 0.001) To mention when started reading it read a value that increased when retested it started about the same initial value increasing the same way. All fluctuating values were like this.
                                Selldors part:
                                I followed:
                                http://www.youtube.com/watch?v=dqkT6hF0O3E
                                and pretty much got the same reading maybe just below what was on the vid.
                                For some reason it doesn't seem to work ohm way. If I have low ohm reading it all read "OL"when I set it to M(ega I suppose) ohms then it starts to read and one direction is always reading a bit higher.
                                So I don't know why it's not matching with diode testing...
                                when You say fuse do you mean the picofuse?
                                Just to mention nothing has been soldered out of the board yet.
                                • selldoor
                                  Slow Learner
                                  • 7870
                                  Re: Hp 1955
                                  I followed:
                                  My turn to not understand- Can you post the actual readings with what leads on what pins.
                                  No ,I mean the mains fuse - I have marked what I think is a fuse It will probably say on the board and on the fuse but cant see. (This is why good clear photos are important)
                                  Have you resoldered the joints yet?
                                  • terminatorX
                                    • Feb 2012
                                    • 63
                                    Re: Hp 1955
                                    Have not resoldered yet will maybe do that at weekend.
                                    Ok so i hope this is right. When I talk about the rectifier I mean; (+,1,2,-) pins.
                                    Using the DMM in diode mode i get:
                                    Red on leg + and black on leg1= OL
                                    Red on leg 2 and black on leg - =OL
                                    Black on leg + and red on leg 1= 0.495
                                    Black on leg 2 and red on leg - =0.506
                                    Red on leg 1 and black on leg 2 =OL
                                    Black on leg 1 and red on leg 2= OL
                                    But when using in ohm mode it's just really weird. To mention it does work properly since I tested it on a couple of resistors on the board and right values where displayed.
                                    Here are a couple of values it's more values at one reading because my DMM show different values when setting range...
                                    Red on leg + and black to both leg 1 and 2 =2MΩ
                                    Black on leg + and red on leg 1= 34.67kΩ, 145.1kΩ, 0.642MΩ and 2.07MΩ
                                    Black on leg + and red on leg 2= 39.7kΩ, 165.9kΩ, 0.72MΩ and 2.28MΩ
                                    Red on leg - and black on leg 2= 40.21kΩ, 166.5kΩ, 0.738MΩ and 2.42MΩ
                                    Red on leg - and black on leg 1= 40.49kΩ, 167.5kΩ, 0.739MΩ and 2.39MΩ
                                    By the way, how should I test the fuse before resoldering?
                                    • jayoung
                                      • May 2011
                                      • 172
                                      Re: Hp 1955
                                      Set the DMM on 200 ohm scale and put one probe on each leg of the fuse. You should get a reading less than 1 ohm (same as touching the two probes together).
                                      • selldoor
                                        Slow Learner
                                        • 7870
                                        Re: Hp 1955
                                        Hmm! test fuse?? Whilst looking for an easy way to show this I noticed that this board has a switch. When you were testing the BIG Cap
                                        was it definitely switched on?
                                        If it was can you test the switch. - same as the fuse but obviously resistance when on and none when off.
                                        • fabianard
                                          HP 1955 - Backlight not working
                                          by fabianard
                                          Greetings,
                                          I have a HP H1955 monitor. The monitor is obviously old (from 2005) and a similar replacement monitor wouldn’t be particularly expensive and hard to get hold on. The problem is that I'm using it for a custom built special purpose so it would be tedious and might take a while to find an exact replacement.
                                          Description of problem
                                          Suddenly it went black during use. When I restarted it, it stayed on for 1-2 seconds then went black again. This was repeated a couple of times. Then a burned smell came from the monitor and from that point the backlight was not...
                                          07-16-2021, 11:56 AM
                                        • amigo744
                                          apple imac 27 2015 a1419 lcd t-con board 6870S-2047A repair
                                          by amigo744
                                          imac 27 late 2015
                                          lcd display t-con board model 6870S-2047A
                                          Want to repair t-con board
                                          display has no screen, but backlight is on, it communicates with mainboard, all diag leds on.
                                          all ribon connections are without damage
                                          mainboard functions without problem. connected an other display and there is a picture...
                                          so i investigate t-con board and all capacitators for shorts and blown fuses
                                          can´t find any fuses...???
                                          so there are many capacitators that seems shorted......
                                          07-30-2023, 06:01 AM
                                        • datsnow
                                          Where i can find this capacitators for this 7870?
                                          by datsnow
                                          hi!
                                          my 1st post here, i think this place is my best choice to found the answer to my problem! i hope i'm not wrong.
                                          sorry if my english is bad at some parts, since i'm portuguese, i'm not that fluent :p
                                          so, the problem. i have a 7870 Ghz Edition 2GB. i started to have some artifacts some days ago and after searching, and since the card's warranty has finished way long ago, i tried the "oven reflow method".
                                          i inserted the pcb into the oven, with all the precautions, for 8 minutes. the first 5 minutes were pretty standard, but...
                                          03-31-2016, 05:48 PM
                                        • LeKowalsky
                                          Enermax Platimax EPM1500EGT random turn on
                                          by LeKowalsky
                                          I'm novice in smps repairs and lurker here also in addition to my preparation I have read Jestine Yong's Troubleshooting & Repairing Switch Mode Power Supplies many times and I cautiously proceeded in small steps a time.
                                          What's on the table?
                                          Enermax Platimax 1500W (EPM1500EGT)
                                          Symptom
                                          A fault is a little tricky here. When plugged into the wall for a first time (i.e. after proper discharge) PSU starts on power button (PS_ON) as expected, runs smoothly with all the voltages in tolerance also shows quite stable operation...
                                          04-14-2020, 08:05 AM
                                        • terminatorX
                                          Bad Hp 1940 and 1955
                                          by terminatorX
                                          Hello=)
                                          I'm new here so please bear with me.
                                          I'm a newbie in this field....
                                          I have googled alot and found a couple of threads here but decided to make one thread of my own.
                                          I have one hp 1940 (Benq 48.L1G02.A00) that when plugged to power starts flicker rather rapidly and just keeps doing that. To mention not connected to PC. The power led is on.
                                          It's not originally my screen so I can't really say anymore in the symtoms department and I removed the power board from the inside now. Nothing really seems to be blown or damaged, no bulging of capacitators....
                                          02-08-2012, 03:47 PM
