I-Inc IF281D Display Problem
  • dennylee
    • Jan 2012
    • 13
    #61
    Re: I-Inc IF281D Display Problem
    To answer PCBONEZ...I did not keep the Box..it would cost almost $130 to ship...it is almost 3 yrs old. Bought another so this is just gravy and an attempt to hone some very old unused skills Looking to Retire in Two years and need a hobby which might cover the grocery Bill. Pulled the Logic Board--identical to AloofOne INC so pic is posted of board....no physical damage: 20 GJT caps on the board. Will post values later.
    • dennylee
      • Jan 2012
      • 13
      #62
      Logic Board has 20 Caps: 12 ea.--GJT 25v10uf (M) 3x8mm 105c
      5ea.--GJT 16v100uf(M) 4x12mm 105c
      3ea.--GJT 16v470uf(M) 8x15mm 105c
      • mockingbird
        • Dec 2008
        • 5484
        #63
        I would personally replace ALL the caps on the logic board. Be warned, those small caps are extremely difficult to replace if you have no experience in soldering. You can easily destroy the board when you become frustrated getting the old caps out or the new ones in - ESPECIALLY those 4mm ones.
        The 16 470uF ones are a dime a dozen... Please confirm the diameter n the 16V 100uF ones. Are they really 4mm? Maybe 5mm?
        • dennylee
          • Jan 2012
          • 13
          #64
          I believe you are correct...5mm.. eyes not as good as they use to be. I'm Game. I use to work on Arcade Games replacing chips in the 80's..would drop in a scocket for the next replacement..lifted a few traces in my day, lots of choice words would follow. The only thing that worries me is Taxes and running out of Wine When I went to Badcaps to try and order all the caps I did not know where to find the caps I need. I have created an account however, is there somewhere else I need to be looking ? Mouser or DigiKey ?? I think I should replace the caps on the PSU as well not that much more in cost. From the info I have read..Rubycon about the best ?
          • mockingbird
            • Dec 2008
            • 5484
            #65
            I always encourage people to buy from Topcat, but the type of caps you need varies to widely to place everything in one order by him.
            The only people who stock Rubycon that I know of is Newark. Doesn't matter who you use inasmuch as what you use. Nichicon, Rubycon, UCC, whatever. I even buy Illinois Components when they're on the rare occasion suitable and priced better (Though I am disappointed with them, I ordered a 33uF 400V IC cap and the top was already slightly bloated and the heatshrink job was shoddy - must have been Leroy on that shift mmmm hmmm).
            Make sure you get the right kinds of caps. If you would post all the caps in a coherent format, like I showed you earlier, I could help you out. It's a little difficult to read your posts. You seem to be in loath of paragraphs.
            • dennylee
              • Jan 2012
              • 13
              #66
              PSU:
              Taicon 50v 10uf "HW" 5x11mm 4 each
              Taicon 35v 33uf "PW" 6x12mm 1 each
              Taicon 10v 220uf "PW" 6x12mm 2 each
              Taicon 25v 220uf "HD" 8x15mm 1 each
              Rubycon 25v 680uf "YXG" 10x20mm 2 each
              Chemicon 16v 1000uf "KZH" 8x20mm 2 each
              Chemicon 35v 1000uf "KY" 13x20mm 2 each
              Logic Board:
              GJT 25v 10uf "M" 3x8mm 12 each
              GJT 16v 100UF "M" 4x12mm 5 each
              GJT 16v 470uf "M" 8x15mm 3 each
              Is this the format you are asking for Mockingbird ?
              • mockingbird
                • Dec 2008
                • 5484
                #67
                Yes, excellent!
                I'm going to give you links to Digikey, because their shipping is cheaper than Newark, and I don't like to use Mouser.
                I'm going to guess which caps belong to which VRM, as there seems to be two on the board:
                https://www.badcaps.net/forum/attach...9&d=1325972026
                VRM 1
                VRM 2
                Small Caps On PSU
                Logic Board
                I seperated it this way because we have to match the ESR of all the caps in each seperate VRM, or get as close as possible.
                REPLACEMENTS
                VRM 1
                16V 1000uF 8x20mm Panasonic "FR" 1560 0.030
                25V 220uF 8x11.5mm UCC "KZE" 760 0.072
                10V 220uF 6.3x11.2mm Panasonic "FM" 455 0.13
                VRM 2
                35V 1000uF 12.5x20mm Panasonic "FR" 2600 0.018
                25V 680uF 10x20mm Panasonic "FM" 2180 0.019
                Small Caps On PSU
                50V 10uF
                Please double check this one. I don't see why such a small value cap would be 6.3mm. If it really is 35V 33uF, then this 5x11 cap should do fine.
                Logic Board
                25V 10uF 4x7mm Nichicon "PW"
                16V 100uF 5x11 Panasonic "FR"
                16V 470uF 8x15mm UCC "KZE"
                • dennylee
                  • Jan 2012
                  • 13
                  #68
                  Thank You Very Much... Mockingbird. The Taicon 35v 33uf could very well be 5x11, it is C33 and part of the Primary PSU on the Board you referred to. I do not have any calipers to get an accurate Height and Diameter and have not removed any caps from the board, all done with a ruler in a awkward position. I will order up the caps. Thank you again for your time and effort.
                  • PCBONEZ
                    Grumpy Old Fart
                    • Aug 2005
                    • 10661
                    If memory serves I've seen 6.3mm 33uF on AOpen boards but they were only like 7 or 8 mm tall.
                    Agree it's a very unusual size.
                    The data sheet says the 33uF 35v PW should be 5x11 mm.
                    If the problem is caps (not so sure it is) I'm guessing it's the GJT.
                    Mann-Made Global Warming.
                    - Dr Seuss
                    • Wasted_Elmo
                      • Feb 2012
                      Originally posted by nightstar
                      I have an IF281D that was exhibiting similar symptoms. Periodic black outs with increasing frequency preceded by shimmering text at the top of the screen and an occasional ghost image displaced horizontally. For a time I averted the black screen problem by removing the shroud and directing a high powered fan at the electronics on the back.
                      Based on the visual artifacts I discounted the possibility of inverter/back light failure and recapped the input logic board. So far the repair seems to be successful.
                      The CapXcon caps on my logic board were KM and ST series which are rated for a meager 1000 hrs and 2000 hrs respectively the lower of which approximates the three year warranty period on this monitor. I suspect a case of planned obsolecense.
                      Good luck with your repair I'll wager a recap sets things right.
                      nice well i see a solution was made for this monitor i also have the same problem and was looking for a solution but question is
                      do you have any pictures of what you did and what should i be looking for ?
                      i am really new to getting my i inc IF281D fixed i was upset when i started to get the same symptoms when having the VGA input working but i did a work around to using the HDMI input for 1yr and it worked till i started with the same problem 2 days ago so tried to look all over even thinking about converting this to an LED but i didnt know how and where to start till i got here
                      so i thank you all for helping out aloofone cause if it was not for him i wouldnt be here lol
                      but what i am looking for is a picture with details of what you replaced
                      and with what part number and details on where to get it and what should i use for this whole repair
                      and bonus cookie points if you guys can give out pointers on how to convert this monitor to an led with brightness control
                      • rogerfixit
                        • Jan 2007
                        #71
                        You guys are really thorough and very helpful.
                        I applaud your services
                        • Barizon
                          • Jul 2012
                          • 3
                          Hello all!
                          I can see a really good people on this forum and I have a problem I want to share with you guys and maybe we can fix...
                          I have a 28in HannsG monitor model # HG281D which has the same power board from our friend AloofOne: FSP217-4F02.
                          A loosen screw from the power board short circuited the board touching against the LCD metal cover and now the monitor is not working anymore.
                          So, I have a couple questions:
                          1. Is it possible to fix the board even with the damages in it? I do know how to soldering big components, but I've never tried on SMD components.
                          2. I saw on the internet one guy who replaced the internal power board with an external PC ATX power, which I have one spare at home. Does someone have an idea in how to implement this solution?
                          So, basically that's it. I'm really frustrated, because I bought this used monitor, I drove 2 hours to pick it and the short circuit happened only 2 days after I started using...
                          So, any feedback is gratefully appreciated.
                          - Gustavo Barizon
                          Below some pictures of the damage:
                          Full view of the boards
                          In the middle where the screw touched
                          A damaged component. It exploded as you can see
                          Pay attention to the R27 and C10 components
                          Wider view of damaged area: Close to the integrated circuit the R27 & C10
                          Now a closer view of the damaged components
                          Explosion
                          Here is the component detail (the good ones)
                          And finally the external ATX power supply I have. I got 25V on this set and I saw on the power board one of output voltage is 25V as well. Maybe this works!
                          • zedascouves
                            • Jul 2012
                            • brasil
                            #73
                            This is not 25V. AC, it's 12V. CC.
                            • Barizon
                              • Jul 2012
                              • 3
                              That's true! I've checked and I took the wrong scale. My bad.
                              Is that correct to make 24V I may just -jump +12V with -12V?
                              I'm thinking to wire with this power supply output but I don't have the power supply (FSP217-4F02) output voltages. Does anybody know?
                              Thanks!
                              - Gustavo
                              • zedascouves
                                • Jul 2012
                                • brasil
                                #75
                                OUTPUT SPECIFICATIONS:
                                Output Voltage: +5Vsb | 4.75V - 5.25V
                                +18V | 17.0V - 19.0V
                                +24V | 23.0V - 25.0V
                                Output Current: +5Vsb | 0.15A ~ 1.5A
                                +5Vsb | 0.35A ~ 3.5A
                                +18V | 0.3A ~ 3.0A | Peak 4.0A
                                +24V | 0.8A ~ 8.0A | Peak 10.5A
                                • Barizon
                                  • Jul 2012
                                  • 3
                                  zedascouves: are those numbers from FSP217-4F02 or FSP271-4F02? (I found the 271, but I couldn't find the 217)!! Please confirm, because it matches with the 271 diagram I have in hands here.
                                  Thanks!
                                  • borlosky
                                    • Aug 2012
                                    • 4
                                    i'm having similar issue with my iF281D, the power light comes on (blue) like normal, but no image/black screen. if i hold a flash light to the screen i see nothing still, sometimes i'm able to leave monitor on for a few hours, and then turn it off then back on quick, and will start working again, for a little while... i'm just not sure if it's the caps on the power supply, the input board or the backlight inverter... need to know which kit to order so i can replace the caps. any help would be appreciated. i've taken the monitor apart already and see no caps that looks bulged or anything to determine which one is causing the issue.
                                    • selldoor
                                      Slow Learner
                                      • 7870
                                      #78
                                      Welcome to the forum-
                                      We can help a lot more if you please post good clear pictures of the whole chassis, and then pictures of each board, front and back and close up of connectors, (max resolution 2000x2000 and 2MB) using the manage attachments button, which is found by clicking "go advanced" under quick reply.
                                      Barizon has totally messed up this thread!
                                      Examples of what is needed
                                      https://www.badcaps.net/forum/attach...1&d=1290283049
                                      https://www.badcaps.net/forum/attach...7&d=1280167246
                                      It will be useful if you can say a bit about yourself - skills tools etc.
                                      If not easily readable in your pics please state the board part numbers.
                                      • DIODE
                                        • Mar 2012
                                        • 30
                                        HELLO
                                        I have a I-INC 28 lcd monitor IF281D that was dead and after replacing the power supply it now powers up fine but will not display any image. The symptoms are as follows;
                                        Without VGA input connected the power on light comes on blue the sceen illuminates white with no image and then goes black after a few seconds and the power light turns amble.
                                        With a VGA signal connected the same thing occures but the screen stays illuminated white with no image and power on light remains blue until power is removed.
                                        I would be thankful for any suggestions.
                                        • retiredcaps
                                          • Apr 2010
                                          • 9271
                                          #80
                                          1) Usually there is a "panel" board that runs the entire length of the lcd. It is located at the top of the lcd and there will be a LVDS cable attached to it. See if the SMD fuse is blown.
                                          2) If the SMD fuse is good, then check all the voltage regulators on the main board to see if they are outputting their correct voltages.
                                          --- begin sig file ---
                                          --- end sig file ---
                                          • keepread
                                            Dell monitor PSU vs Dell laptop PSU
                                            by keepread
                                            Hi there!
                                            Someone gave me their old monitor, it's Dell S2715ht.
                                            The owner was using it when his PSU began to smell and then to smoke. It literally began to melt. He turned the monitor off, pulled the PSU, and ditched it because it was smelly even after it cooled. So I got the monitor but not the plug.
                                            Now, I tried to bring the monitor back to life, by plugging one of my many Dell laptop PSUs. They are of the same 19.5V, and the wattage of the laptop PSU is higher than that which the monitor is rated for. Visually, the socket on the monitor seems compatible, and the plug plugs...
                                            10-30-2025, 04:45 PM
                                          • Askic
                                            Problem with monitor DS-D5022QE-B
                                            by Askic
                                            Hello to all,
                                            I have a problem with monitor that is delivered together with CCTV system.
                                            The monitor appears to be completely dead, there is no LED power diode and it doesn't react to pressed power button.
                                            I have disconnect display and check many components on the power supply part of the board. There is no anything obvious and monitor is about 3 years old. There are no bulged caps. When measuring voltages on the output connector to VGA board I can measure stable 14.5 V on 12V pins and stable 5.07V on 5V pins. So I assumed that this part of the board is OK....
                                            05-31-2023, 03:14 AM
                                          • CptChronic
                                            Samsung LU32J590UQUXEN Monitor display problem
                                            by CptChronic
                                            I have an intermittent display problem with my monitor, when I plug in the HDMI cable to my (or any) laptop, you see the connection screen shrink on the laptop as it usually would before displaying on the monitor but 95% of the time the monitor display stays black.
                                            Before it cut out all together, tapping the monitor control button a fair few times would make the screen display, and everything work fine.
                                            But now it never does it. Not sure what's going on, hoping someone can help. I'm capable of stripping the thing down and soldering in new parts if needed, or programming...
                                            04-24-2023, 04:33 PM
                                          • tmhobadcap
                                            LG 24MP56HQ-P Monitor Backlight problem?
                                            by tmhobadcap
                                            I have a few successful experience in fixing tv backlight problem. But for monitor, I have no experience. However, I think they are more or less the same. Am I correct?
                                            Recently, I got the captioned monitor and the owner said it could not be turned on. I open it up and found that one of the SMT capacitors seemed to be bad. I replaced it as well as the other one. The monitor still could not be turned on.
                                            I found the power indicator is on. When I shine a flashlight on the screen, I can see the image. Therefore, I think it is with backlight problem. I took out the led strip....
                                            10-13-2021, 01:52 PM
                                          • tmhobadcap
                                            by tmhobadcap
                                            10-12-2021, 01:43 PM
