i am replacing ccfls on my viewsonic VX2235wm and i'm wondering if there are other options to using shrinktube on the resoldered ends. what size is this tube - is 2:1 5/64 (.078) small enough? the boots have split when sliding them back from the ccfl, so they dont separate the ends as well as they once did. seems hot glue would get hot and runny again. tape seems too thick to slide into the boot. any suggestions appreciated - thanks.
replacing ccfls - shrinktube critical?
Re: replacing ccfls - shrinktube critical?
Silicon adhesive; there is even a formulation designed for electrical insulation.
PlainBillFor a number of reasons, both health and personal, I will no longer be active on this board. Any PMs asking for assistance will be ignored.
Never be afraid to try something new. Remember, amateurs built the ark. Professionals built the Titanic. -
thanks bill - reading google links got me to rtv red (safe for automotive sensors, but still has acetic acid) and Star Brite Liquid Electrical Tape @ home depot as most easily available options. nothing @ ratshak. others i read about that have no acid or other corrosive ingredient cost 30 bux + for a few ounces. acetic acid is how big an issue here? anyone care to save me from another hour of reading and suggest any products? thanksComment
RTV6700 Series (RTV6702, RTV6703, RTV6708)
or: RTV162
GE is not the only brand those are sold under.
If the RTV number is the same then it's the same stuff no matter the brand.
.Mann-Made Global Warming.
- Dr Seuss
by iMuhtasebthis board suffered from a bad trackpad and bad keyboard after liquid damage; board was turning on no issues..
we've replaced the bad trackpad and bad keyboard no issues whatsoever.. during 2nd final checkup we booted to an external macOS and there started the critical update issue; it boots externally but to the internal SSD it shows critical update; tried Wi-Fi tried Ethernet tried Hotspot same thing..
One weird symptom is it takes too long to power on and show the Apple logo for some reason..
I've taken a look into the MLB and noticed tiny liquid around Q3100.. its... -
by ReintarFirst of all, I'd like to mention that I'm a novice when it comes to laptop repair, although I do have some experience with soldering.
One day, my laptop experienced a severe stutter, and after rebooting, it failed to boot into Windows. I decided to disassemble it and found that the PL900 component was blown. Later, I came across a post (https://www.badcaps.net/forum/troubl...error%E2%80%99) with the same problem, where...08-30-2024, 06:13 AM -
by m1ch43lzmHi, i have this RadioShack IR thermometer Cat. No 22-170 which takes 2xAAA batteriss, I've tried with NiMH AAA rechargeables but it complains about low voltage, it flashes an "empty" battery and doesn't measure anything, even with freshly charged 2xAAA NiMH, so i have to "borrow" the batteries from my multimeter when i want to use it
I'm thinking abour replacing the 2xAAA batteries with a small LiPo battery that fits inside that space, but the voltage would be too high (4.2v)
I'm open to suggestions on whether i should use an LDO or another type of voltage... -
by bulkchart32nichiconare what i used because i had heard the voltage doesn't matter as long as it is more than the original cap. i'm now reading that high voltage may make the cap's esr too high. is this a good cap for replacing those oem ones?
1500 µF 16 V Aluminum - Polymer Capacitors Radial, Can 8mOhm 2000 Hrs @ 105°C -
by ktmmotocrossHello.
I was replacing ALC660 on asus x58c two times but still no sound with new chip, but works with original with bad sound. Nex time i replace audio ic in hp 840 g5 and again not work with new chip.
So is there something special needed when replacing audio ic? - Loading...
