is something special needed when replacing audio ic?
  • ktmmotocross
    Boardkiller
    • Feb 2014
    • 3610
    • slovakia
    Hello.
    I was replacing ALC660 on asus x58c two times but still no sound with new chip, but works with original with bad sound. Nex time i replace audio ic in hp 840 g5 and again not work with new chip.
    So is there something special needed when replacing audio ic?
  • mcplslg123
    • Jun 2015
    • 7262
    • india
    Re: is something special needed when replacing audio ic?
    Nothing-no special steps. Seems the IC's you got are all bad.
    • tomodachi
      • Apr 2012
      • 603
      • Turkey
      Especially Realtek codec chips are very heat sensitive and need to be worked on quick and with a bit lower temperature.
      if possible, try to remove audio chip by heating board from bottom side, not directly from above, this is a method I use
