Dell E207WFPc
+ More Options
Posts
  • retiredcaps
    • Apr 2010
    • 9271
    Re: Dell E207WFPc
    Originally posted by killian6pk
    Connector Label Reads:
    Black = N/F
    Okay, it took me a while to figure out N/F. It is oN/ofF.
    You need to monitor this pin as you turn the power on and off. You may need to do this test several times.
    I'm expecting to see 0.0V and something more than 2.0V (like 3.3V) as you press the on/off button.
    --- begin sig file ---
    --- end sig file ---
    • killian6pk
      • Apr 2010
      • 502
      Re: Dell E207WFPc
      All right I'll get on it.
      Have you ever stopped to think and then forget to start thinking again?
      As a very wise man once said on this forum: "Of all the things I have lost I miss my mind the most."
      • retiredcaps
        • Apr 2010
        • 9271
        Re: Dell E207WFPc
        The monitor does not power on at all, no light or flicker or anything.
        Does the power LED come on at all? All the voltages to the logic board seem to be correct.
        • killian6pk
          • Apr 2010
          • 502
          Re: Dell E207WFPc
          Ok what I have done is I have the power board and main board hooked up and the power cord is plugged into a power strip with an on/off switch. If I touch my probe to the black wire connector coming from the n/f spot on the power board to the main board the DC readings are all over the place. They never settle down. My black probe I had connected to one of the grounding screw holes.
          I switched over to AC and got steady readings but they were like 46v.
          I am assuming that it is DC we are looking for? Should I be grounding somewhere else?
          • killian6pk
            • Apr 2010
            • 502
            Re: Dell E207WFPc
            Just saw this post. I will have to reassemble the monitor to check the readings and to see if the power light is coming on. I still need to have my black probe connected somewhere to have a free hand to cycle the on/off button. What's your suggestion on where to connect it?
            • retiredcaps
              • Apr 2010
              • 9271
              #26
              Re: Dell E207WFPc
              You want to measure DC.
              If I'm right about the N/F (i.e. oN/ofF), it should be 0.0 and > 2.0V DC. I use a ground screw closest to the connector for ground (my black probe). Red probe stays on the N/F pin. If you have aligator clips, they help a lot.
              If your multimeter has a min/max function, that would help a lot too.
              • retiredcaps
                • Apr 2010
                • 9271
                #27
                Re: Dell E207WFPc
                Wait on reassembly. Measure the N/F pin again.
                • killian6pk
                  • Apr 2010
                  • 502
                  Re: Dell E207WFPc
                  Got it all hooked up and the boards are up side down of course. I can't hook up the screen because I would not be able to get to the boards to check voltages (I will post pictures of the way this goes together tomorrow). The power led does not come on. There is 3.2v (when I push the power button) on the underside of the main board at the connection attached to the black wire coming from the power board. Don't know if the accomplishes anything or not. I am going to quit for tonight and pick this back up in the morning. Thanks for the help.
                  • retiredcaps
                    • Apr 2010
                    • 9271
                    #29
                    Re: Dell E207WFPc
                    There was one person who fixed a lcd just recently (last week?) and reported that the power led didn't work after the repair. So just for fun, please hookup a working computer to the lcd just in case everything is working and the power LED is burnt out.
                    • Rtech
                      • Jul 2010
                      • 1095
                      #30
                      Re: Dell E207WFPc
                      To test the led,just means putting a small DC voltage across it,and sometimes,just measuring across it with the meter set on diode test,puts a voltage acorss it and MAY be enough to light it,a 1.5 battery would certainly do it.and by reversing input leads should enable it to change colour.it is a very simple test.
                      • killian6pk
                        • Apr 2010
                        • 502
                        Re: Dell E207WFPc
                        I'm back and will try to both put a diode test on the led and reassemble the monitor to see if it comes on. Back in a short time.
                        • killian6pk
                          • Apr 2010
                          • 502
                          Re: Dell E207WFPc
                          Ran the diode test on led and it lit up on each side for each color.
                          Put the monitor back together and hooked it up to the computer. Got very nice white backlights, but no picture or power led. On and Off switch did work, however. What is the next thing to try?
                          • retiredcaps
                            • Apr 2010
                            • 9271
                            #33
                            Re: Dell E207WFPc
                            1) Double check the connector from the logic board to the panel board. Even if it looks seated properly, maybe reseat and clean the connections with alcohol. These connectors are often fragile so be careful.
                            2) The panel board which runs lengthwise across the top of the lcd sometimes has a fuse. If it is open, you would get a white screen.
                            • killian6pk
                              • Apr 2010
                              • 502
                              Re: Dell E207WFPc
                              I'll check both thanks.
                              • killian6pk
                                • Apr 2010
                                • 502
                                Re: Dell E207WFPc
                                I looked both the Panel and Main Boards over thoroughly and could not find a fuse on either board. However, in looking the main board over it appears that the connector to the front button bar has a pin that is broken off. I am going to try to repair it with a cut off piece of resistor wire. We'll see how that works and I will get back to you all with a report. That connector is really poorly designed and fragile. I don't know if I broke it off or if the previous owner did trying to work on the monitor before giving up. Thanks
                                • retiredcaps
                                  • Apr 2010
                                  • 9271
                                  #36
                                  Re: Dell E207WFPc
                                  On the panel board, the fuse is usually SMD style and denoted with a "F". For example, F1.
                                  • killian6pk
                                    • Apr 2010
                                    • 502
                                    Re: Dell E207WFPc
                                    Sorry it has been so long since my last post. Had to do some stuff with my Dad he is in the early stages of Dementia and we were trying to get a roofer and have some work done on his house.
                                    I finally found a fuse on the Main Board (it test good) and just tonight found a fuse on the Controller (Panel) board. I took a picture, but it is really small. It is just above the red dot I placed on the picture. I need some help with what the specs are on the fuse. Of course there is nothing written on the fuse itself.
                                    • retiredcaps
                                      • Apr 2010
                                      • 9271
                                      #38
                                      Re: Dell E207WFPc
                                      1) Is the fuse open?
                                      2) The picture is too fuzzy to tell. If your camera has macro mode, enable it and take the board to a window when it is sunny outside. That should produce a clear focused image.
                                      • killian6pk
                                        • Apr 2010
                                        • 502
                                        Re: Dell E207WFPc
                                        Sometimes my fingers outpace my brain. Yes I tested the fuse on the controller board both for continuity (showed open) and on the resistance setting went directly to O.F so I believe the fuse is bad. As soon as we see some sunshine I will retake the picture. Supposed to get some today. So after turkey I will repost a picture.
                                        • killian6pk
                                          • Apr 2010
                                          • 502
                                          Re: Dell E207WFPc
                                          Turkey was postponed for about an hour. I took the picture again and the Fuse is the little white SMD just above the red dot. It is also just to right of the first leg of the big IC with 3 legs. Hope this picture is clear enough.
                                          • master3112
                                            by master3112
                                            07-29-2025, 01:55 PM
                                          • F R 2568
                                            Dell Latitude 5420 does not start (no post) need help to find the reason why
                                            by F R 2568
                                            Hello all,
                                            this is my first post, so if I make mistakes please do not hesitate to point them out, thank you in advance.
                                            I got a Dell Latitude 5420 (Service Tag: 7RFM6D3, Motherboard: GDF40 LA-491P Rev.: 2.0 (A01)) which does not start and I want to repair it. These are the symptoms:
                                            If the laptop is only connected to the AC adapter (battery removed):
                                            When I press the power button, the keyboard backlight and the display backlight are turning on. Caps key light is lightning, but key does not respond to pressing it.
                                            The power/battery...
                                            01-08-2025, 05:45 AM
                                          • diamon
                                            Looking for Dell Latitude 5520 / 5530 / 5540 RJ45 network connector replacement
                                            by diamon
                                            I have a Dell Latitude 5530 with a damaged RJ45 network connector. See the attached pictures.
                                            Have already searched on Farnell / Aliexpress / Ebay and had contact with several suppliers on Aliexpress and Ebay, but they cannot deliver this connector.
                                            Is there someone inside the EU, who has these connector(s) or perhaps defective motherboard(s) for these laptop models I have mentioned in the topic title.
                                            Pictures of these boards:
                                            Dell Latitude 5520 https://www.ebay.com/itm/256052956663
                                            Dell Latitude 5530 https://www.ebay.com/itm/125844181534
                                            Dell...
                                            02-28-2024, 12:51 PM
                                          • Bowline
                                            by Bowline
                                            06-11-2025, 10:13 AM
                                          • lalle-
                                            Dell G5 SE 5505 - "Invalid memory installed" after BIOS update.
                                            by lalle-
                                            Hello!
                                            I have a problem with a Dell G5 SE 5505 laptop that I hope someone can give me a few pointers on.
                                            [OK, it's not really a laptop, I'm running the motherboard on my desktop with only cooling, RAM and an M2 drive attached.]
                                            I had some performance issues, so I decided to update my BIOS from 1.7.0 to the latest version, 1.20.0.
                                            The computer restarted and the update dit not want to continue without a battery connected, even though I used dell's method of bypassing this requirement.
                                            I tried updating to a custom BIOS from Reddit user Satori_Nori https://www...
                                            08-11-2024, 02:01 PM
