Dell 1704FPT - Flickering and hissing
  • davepusey
    • Aug 2011
    • 5
    I have a Dell 1704FPT 17" LCD Monitor that I purchased new in 2005.
    Yesterday morning it started flickering (as if one of the two backlight lamps was switching on and off) and it was almost making a noticeable hissing noise.
    Having ordered a replacement monitor, I thought it would be interesting to disassemble this one to see if I could fix the problem, as the monitor is otherwise in good working order.
    Having carefully taken the monitor apart, I carefully reconnected the power supply and control boards, and powered up the monitor. The flickering was still present, as was the hissing.
    From careful inspection and listening, the hissing seems to be coming from one of the transformers, in the inverter portion of the power supply board.
    In the photo's attached, it's the transformer that is at the same end of the board as the mains connector.
    Also of note, the sister transformer at the other end of the board is, when powered, cold to the touch. The hissing transformer seems to be getting quite warm to the touch.
    If the monitor is put into standby (powered, but with backlights off) the hissing stops.
    Is it the transformer that is faulty, and can this be repaired easily?
  • alexanna
    • Mar 2010
    • 1346
    Re: Dell 1704FPT - Flickering and hissing
    In the future please use managed attachments to post your photos
    Figure out a way to install the top CCFL bulb connectors into the bottom inverter connectors,and bottom bulbs in top inverter connectors.
    Dose the noisy transformer change positions?
    • PlainBill
      • Feb 2009
      • 7034
      To add to alexanna's suggestion, if the problem stays with this transformer, the transformer cannot be repaired, it must be replaced. This is quite easy to do if you can find a replacement. In many case, this requires nothing more than an eBay search for the number stamped on the transformer.
      If the problem moves to the other transformer, you have either a bad CCFL, or CCFL wiring.
      PlainBill
      • davepusey
        • Aug 2011
        • 5
        The leads from the lamps are only just long enough to go to their current locations. I cannot see any easy method to swap them round.
        PlainBill
        Yes, I realise the transformer itself cannot be repaired. I was refering to the monitor in general.
        If I cannot swap the lamps round, would disconnecting the lamp from the faulty transformer help? With the lamp disconnected, would the hissing continue if the transformer is faulty?
        • alexanna
          • Mar 2010
          • 1346
          You can swap the CCFLS,Toasty said it best flip the board over.
          I use a piece of cardboard to insulate the inverter/power supply so that nothing shorts to ground.
          You don't need to have the flat LDVS ribbon hooked up to the panel; the panel gets its voltage through the ribbon so insulate it also.
          The noise you are hearing is most likely caused by the transformer or a CCFL,so that part of the circuit should all be hooked up.
          Give the CCFL connectors a good Eyeball also for damage.
          • davepusey
            • Aug 2011
            • 5
            Which cable is this? The one with many many tiny wires, that goes between the LCD and the main control board?
            Visually, they look fine.
            • alexanna
              • Mar 2010
              • 1346
              Yes that's the one,looks like it's already disconected.
              • smason
                • 1652
                I have a 1703 on my waiting for parts shelf, that also needs a transformer.
                Haven't tried too hard to find one yet, but I think my initial search wasn't too successful.
                • davepusey
                  • Aug 2011
                  • 5
                  No, the cable is just tucked down behind the wooden block the board is sat on.
                  I've come to the same conclusion regarding getting a replacement transformer.
                  What I'm considering doing is using the perfectly good panel to build a DIY video projector.
                  I noticed the cable, from the power supply to the control board, has a wire marked BACKLIGHT_EN. I suspect this is a simple logic level signal to turn the inverters on/off (such as when the monitor goes into standby when no input signal detected), then it shouldnt be a problem to disable them permenantly.
                  • PlainBill
                    • Feb 2009
                    • 7034
                    Perhaps you and smason could make arrangements to transfer a good transformer from one to the other. The one can have another working monitor and the other a DIY video projector.
                    PlainBill
                    • davepusey
                      • Aug 2011
                      • 5
                      PlainBill
                      And excelent idea, assuming the transformers are the same between the 1703 and the 1704FPT.
                      I did find a refurbished board online for £30, but as my replacement monitor only cost £69 it wasn't worth it in my opinion... http://www.codemicro.com/store/produ...efurbished.php
                      • Lumberjack777
                        • Dec 2010
                        • 464
                        On some monitors the Dell 1704FPT and the Dell 1905FP use the same board. Some of these boards have a manufacturer's defect where they used a 22uF 50v cap next to that inverter transformer, when it should have been a 2.2uF 50v.
                        I have a previous post on this. https://www.badcaps.net/forum/showpo...8&postcount=15
                        • reessi
                          ACER BM320 Monitor - Horizonal Flickering Lines After a While
                          by reessi
                          The monitor started off showing flickering thin (1 pixel) lines horizontally every say 3mm..
                          They are black on the right and gradually fade to nothing on the far left.
                          They start either after 5 mins or up to 2 hours after so annoying for testing.
                          They flicker continuously very fast! With a slight pause milli-second every second.
                          Initially I cleaned the LVDS cable and connected to the T-Con and then it worked fine for 3 weeks but not sure if this was just co-incidence.
                          I tested each half by removing the first the left flex from...
                          06-03-2025, 09:58 AM
                        • wattage
                          by wattage
                          Hello Badcaps Community,
                          07-13-2025, 04:41 PM
                        • ant3202
                          HP 27es - LED monitor - Monitor Flashing On - Off
                          by ant3202
                          Hi Everyone
                          Lately I am experiencing the deja-vu incident on one of the led monitor like this.
                          https://www.badcaps.net/forum/troubl...lashing-on-off
                          The monitor is HP 27es LED Monitor
                          https://h30434.www3.hp.com/t5/Deskto...e/td-p/6804692
                          The monitor will randomly blackout and display no signal and will recover again.
                          Sometimes need to power and off again to restore the display but...
                          03-20-2025, 07:30 PM
                        • Ali101
                          AOC LV243XIP 23.8 inch Monitor Screen Flickering
                          by Ali101
                          AOC LV243XIP 23.8 inch Monitor screen flickering after power on monitor within few seconds and image disappear, if power off and on again then then image come back and again disappear within few seconds, i had checked all capacitor which seems ok to me, i have doubt something wrong with LCD board and mainboard is ok, i don't have other same monitor so i check and verify either LCD have issue or mainboard,
                          shall highly appreciated any hep to fix this monitor,
                          PS. i had attached pics and short video for reference,
                          Video Youtube Link: https://youtu.be/z9hIq7Ujj...
                          02-13-2022, 06:21 PM
                          Wise Wing F199 19'' LCD monitor - recapped
                          by momaka
                          Looking through my repair pictures and notes, it's been a long time since I posted anything in the LCD monitors section. So here goes that.
                          I'm dedicating this thread to one of the very first LCD monitors I repaired (if not the first one), which was more than 10 years ago now. The monitor is a Wise Wing, model F199. It's a 19” CFL-backlit LCD. I got it for free off of Craigslist in 2009 from a guy, who said he bought it for cheap from Wallmart and the monitor worked only for a little less than 2 years before quitting.
                          When I saw the Craigslist post, I wasn't...
                          08-24-2020, 10:58 AM
