Vizio LP2626/VMM26-F20I
+ More Options
Posts
  • ent
    • Mar 2013
    Re: Vizio LP2626/VMM26-F20I
    Any idea how to replace ZD801 or what the value of it is? Is this fixable?
    C504 is obviously needed too, but what do I do about what I assume is a zener diode?
    Any help would be greatly appreciated!
    • ent
      • Mar 2013
      Alternatively, if anyone has a picture of the ZD801 component, or can tell me what it says, it might give a clue what value it is. Mine is obviously unreadable, and I can't find any schematics anywhere.
      Thanks for all the great information. With a little more help, I feel this is fixable.
      • thepeaceseeker
        • May 2013
        Lots of good info in this thread! I have a similar problem but the difference in my situation is there is no message on the screen before it goes off. Image is present on LCD. Backlight comes on for a couple seconds and then just goes off. Inverter signal voltage is constant at multi-pin cable connection.
        I have been able to determine that the backlight fluorescents are ok (hooked them up to a inverter board from a similar monitor : stayed lit), I had the blue ceramic caps in stock so I replaced them : no difference. What else is strange is that if I change the input source or turn the signal to the monitor on and off, the screen comes on for a couple seconds again each time. Initially I thought this might be a problem with the logic board signalling the power supply board. But like I said the inverter signal voltage is constant and I can trace the it to the small batch of SMD resistors and transistors just before the set of three 8 pin IC's before the step up transformers. Without a schematic I can't trace it through any further. It seems to be sensing something, or a cap or transistor is breaking down in that circuit.
        What other signal factors are involved? What about feedback signal from the backlight output circuit? Anyone have a schematic for this board? I feel I am very close...
        EDIT: Oh, forgot to mention. Once ceramic cap and 1.5m resistor were slightly discolored. As I said, I changed the caps, measured resistor and it measured OK.
        Any help would be appreciated. Thanks!
        • tibimakai
          • Jan 2012
          • 3680
          I didn't want to start another thread.
          It's a possible purchase, but I don't know what could be the problem?
          It just needs a reset or an EPROM issue?
          http://www.youtube.com/watch?v=mJHpo...ature=youtu.be
          It seems like it's in a test pattern of some kind.
          • warchico
            • Dec 2011
            #45
            I was researching the N3 3KV SEC capacitor to confirm its value. SEC seems to be the Manufacters logo Success electronics LTD in Tiawan. They confirmed 3pf
            • hubschrauber
              • Jul 2015
              • usa
              #46
              To all who posted info on this... Thank you! Thank you! Thank you! Thank you! Thank you!
              Just got my order from Mouser including the 12pf 3kv and 3pf 3kv caps and 1.5mOhm resistors. The resistors did not test not off-value once I removed them from the board, but they looked a little toasted so I swapped them anyway. The 3pf caps didn't test as defective either so I'm not sure they needed to be replaced. Anyway, my monitor, which would flash on for about 2 or 3 seconds and then go black, is all fixed now for about $10 instead of $200+ to replace the monitor. Many Thanks!!!
              In case it helps anyone find the parts, here's what I used...
              • 1.5M resistor - Vishay VR68000001504JAC00 (Note: these are huge, but well over-spec'd)
              • 3pf cap - muRata DEF2CLH030CJ3B
              • 12pf cap - TDK CC45SL3FD120JYNNA
              • XCrunner
                • Jul 2015
                • 4
                I am aware this is an old thread, but would anyone be able to help me with a couple of the plugs? There are four slots that say "8AN3" near where the capacitors are. I am not sure which cords go into them.
                • XCrunner
                  • Jul 2015
                  • 4
                  Here is the link
                  http://i.imgur.com/p8gHjLh.jpg
                    You have 4 individual lamps set up in two pair for the top and bottom edges of the LCD panel. The pink and blue pair can go into either pair of the receptacles on the board.
                    So what you have as shown in the picture, the left pair the pink one can go into the left most connector, the blue can go into the connector to the right of it, and so on.
                    • XCrunner
                      • Jul 2015
                      • 4
                      Okay, I have replaced the c504 with a 12pf 3kv capacitor and made sure the lamps have the correct wiring but it still doesn't seem to want to power on :/ Is it possible something else is blown? The first time I tried to power it on I had the wires in the wrong lamps and the power supply was not mounted, i saw a spark and there is a very tiny black dot/charred area above the label. Could this have caused something else to blow, because everything else on the board looks fine. Any help is greatly appreciated.
                      All the previous posts have been very helpful with teardown and what to look for.
                      Thanks!
                      images of my board below.
                      http://imgur.com/a/eFEih
                      • XCrunner
                        • Jul 2015
                        • 4
                        Anyone?
                        • jjdeluxe
                          • Oct 2016
                          Brilliant info. Thanks. I took a photo of the connections before disconnecting, or so I thought. Then spent quite a while searching on the internet for the answer to the connections and found this post.
                          I located and replaced the blitzed capacitor (C504) with this http://tinyurl.com/h9bft46. However the fix does not seem to be successful or at least complete. I only replaced the one capacitor because it was clearly fried, but not any other components. this project is sorta beyond my patience level and lack of diagnostic tools/knowhow. Nevertheless, thanks to all who offer their time to help others.
                          I'm inclined to buy a whole power supply board, if I can find one.
                          • CPeter
                            • Mar 2017
                            • 3
                            Re: Vizio LP2626/VMM26-F20I (after thoughts)
                            Originally posted by Schaugaard
                            I had a similar situation, in my case however, c504 was clearly fried. (c504 is a 12pF, 3000 volt ceramic disc capacitor.)
                            I took my monitor apart and removed the C504 capacitor and measured it with a B-K Precision capacitor tester. It reads 3pF and I did the test several times. Is it true that the correct value is 12pF and that may be the source of my problem? This monitor is 8 years old and when it is working is really nice, but not worth putting much money into.
                            I tested resistor R508 and the value is 1.44 M ohm
                            CPeter
                              Is the cap has 3n printed on the body?
                              • CPeter
                                • Mar 2017
                                • 3
                                It is marked:
                                12J
                                3KV
                                JNC
                                CPeter
                                  That is 12pF cap.
                                  • CPeter
                                    • Mar 2017
                                    • 3
                                    Would that be a possible cause of my 2 seconds to black screen? I can find that caps on E**Y and get a couple. The R508 resistor measures 1.44 Meg. I think the color code is brown, green, green. I think that is 1.5 Meg and the tolerance code is gold.
                                    Thank you,
                                    CPeter
                                      The resistor is close enough tolerance of 5%.
                                      That cap needs to be replaced.
                                      • SS454
                                        vizio e650i-a2 backlight flashes then turns off
                                        by SS454
                                        vizio e650i-a2 (LWJAOZBP Serial) led backlight flashes then turns off, has video (via flashlight) and audio.
                                        panel: au optronics T650HVN05.4
                                        72 led total on 12 strips, 6 led per strip wired in three groups of 24 (led driver board has three anode and three cathode pins)
                                        link to datasheet: https://datasheetspdf.com/pdf-file/8.../T650HVN05.4/1
                                        Vizio 56.04219.641G (liteon PA-3231-01WN-LF) Power Supply Unit
                                        https://www.shopjimmy.com/vizio-56-0...-power-supply/
                                        Vizio 55.75J01.001G (91.75J10.004G) Main Board...
                                        08-20-2020, 03:57 PM
                                      • brad2157
                                        Vizio E70-E3 Two white vertical lines
                                        by brad2157
                                        I picked up a Vizio E70-E3 for free that shows Vizio logo and then goes to a black screen. Original owner said he started having wifi issues and then he tried to reset the TV and that's when it wouldn't boot up any longer after his reset attempt. I picked up a replacement main board from eBay that matches the same model # board as the original from the TV.
                                        Original main board - Shows Vizio logo when TV powers on, then goes to black screen. Doesn't boot up. No screen issues with any lines on start up Vizio logo.
                                        Replacement main board - Boots up fine, but starting...
                                        12-13-2021, 05:11 PM
                                      • EazyBone
                                        Vizio d650i-c3 freezing
                                        by EazyBone
                                        This Vizio doesn't freeze at startup. Not that problem
                                        This Vizio will go into an app like YouTube and work and a very bad picture rate and freeze on videos pretty quickly. But will freeze up in all the apps. Plug a Roku stick into it and it works flawless without video buffers etc. Is there a solution to this freezing issue with Vizio's? It's at latest firmware. I figured they just suck, but factory reset and firmware didn't fix.
                                        09-16-2023, 08:20 AM
                                      • brucetv
                                        Vizio oh ohhhh Alert Px65-G1 & Px75-G1
                                        by brucetv
                                        For any unfortunate soul that purchased this Tv you might want to know about a premature panel failure problem it has many times within the 1 year warranty or just past it. Imagine that. A top of the line P series with all kinds of fancy dancy features and the panel isn't worth a damn. In fact we see more panel problems on the P series than any other series Vizio year after year since they came out. Shame on you Vizio and consumers please quit buying into this crap. On the Px65-G1 the Tv will boot up with a faint Vizio V logo first then get the usual Vizio logo for about 5 seconds and then go...
                                        03-11-2021, 08:26 PM
                                      • frannyjunk
                                        Putting LCD panel from Vizio TV into another brand TV
                                        by frannyjunk
                                        I have a Vizio P502UI-B1 50" tv and baked the main board a little too much (to reflow BGA) resulting in a dead tv. I would like to use the Vizio LCD panel in another tv. Someone in the P502UI-B1 thread said he/she was able to take that Vizio LCD panel and put it into an LG 50UH5530 and it worked. Looking at the Tcon boards from the 2 tv's show different model boards (LG = EAMDJ2S55 while the Vizio tcon = V500DK2-CKS2). I have since looked up tv's that uses the V500DK2-CKS2 Tcon board (Hisense 50H7GB, Vizio P502-B1E & M50-C1, Westinghouse WD50UT4490, and a few others). Does this mean any...
                                        07-27-2021, 04:14 PM
