32" Goodmans TV
+ More Options
Posts
  • dumpystig
    • Jul 2011
    • 485
    Re: 32" Goodmans TV
    We have the same boards but somewhat different connections. Can you post a close up pic of your PSU socket area (with plugs connected) and I'll be more able to make a comparison - I can get a better idea when I can compare positions of wires of a particular colour. Cheers
    System: HP xw6600 Workstation, 650W PSU | 2x Intel Xeon Quad E5440 @2.83GHz | 8x 1GB FB-DDR2 @ 667MHz | Kingston/Intel X25-M 160GB SSD | 2x 1TB Spinpoint F3, RAID0 | 1x 1TB Spinpoint F3, backup | ATI FireGL V7700 512MB | Sony Optiarc DVD +/-RW | Win 7 Ultimate x64 | 2x Dell UltraSharp U2410f | Dell E248WFP
    • dumpystig
      • Jul 2011
      • 485
      Re: 32" Goodmans TV
      Here's mine
        Re: 32" Goodmans TV
        See attached
        • dumpystig
          • Jul 2011
          • 485
          Re: 32" Goodmans TV
          Right, to start with you should only have a few outputs from PSU to M/b @ STBY:
          PL805:
          #10 - 3V37
          #11 - ^
          #12 - 5V07
          And from M/b to PSU @ STBY:
          PL803;
          #5 - 62mV
          #6 - 1V74
          #7 - 32V2
          All other pins remain low until TV is started either by RC or side button. M/b (VCTP) then initiates STBY_ON_OFF output to PSU, PL804#6 goes low and all other V's (3.3, 5, 12, 24, 34) are then present. Next PL803#1/PL802#12 goes high to start inverter/backlight.
          So now @ RUN:
          PL801:
          pin #1 - NC
          pin #2 - NC
          pin #3 - NC
          pin #4 - 24V3
          pin #5 - ^
          pin #6 - GND
          pin #7 - ^
          pin #8 - NC
          pin #9 - NC
          pin #10 - NC
          PL802:
          pin #1 - 24V3
          pin #2 - ^
          pin #3 - ^
          pin #4 - ^
          pin #5 - ^
          pin #6 - GND
          pin #7 - ^
          pin #8 - ^
          pin #9 - ^
          pin #10 - NC
          pin #11 - 2V46
          pin #12 - 3V01 ~ 2V92
          PL803:
          pin #1 - 3V01 ~ 2V92
          pin #2 - 2V47
          pin #3 -
          pin #4 -
          pin #5 - 2V56
          pin #6 - 56mV
          pin #7 - 33V9
          pin #8 - 12V1
          pin #9 - GND
          pin #10 - ^
          PL812:
          pin #1 - 5V1
          pin #2 - ^
          pin #3 - 3V36
          pin #4 - ^
          pin #5 - ^
          pin #6 - GND
          pin #7 - ^
          pin #8 - ^
          pin #9 - ^
          pin #10 - 3V34
          pin #11 - ^
          pin #12 - 5V04
          PL813:
          pin #1 - GND
          pin #2 - ^
          pin #3 - 12V1
          pin #4 - ^
          • dumpystig
            • Jul 2011
            • 485
            Re: 32" Goodmans TV
            The bold values in my last post are what I'm getting on my board, but they are all very close to or the same as the values indicated in the Sanyo training manual.
            Also am I correct in assuming you listed your wires the wrong way round on your PL813/
              Re: 32" Goodmans TV
              Probably...
              Most of my voltages look out of spec, apart from standby.
              Maybe it's worth buying a main board and selling the board on if it doesn't fix the problem. I don't stand to lose much as long as I can sell it.
              AFAIK my PICkit 2 (microcontroller programmer) can program EEPROMs. I may take the EEPROM out and reflash it. Any idea where to find a .bin file for it?
              • dumpystig
                • Jul 2011
                • 485
                Re: 32" Goodmans TV
                I'm wondering if your mod around IC807 may have something to do with it now. If you want me to give you some ref. V's from the PSU just let me know what test points and I'll post them here.
                I did search for the .bin file a couple of weeks ago but those things are almost non-existant on the web.
                  Re: 32" Goodmans TV
                  Yes, what does the pin next to Q837 (pin #8) measure at? Mine is bouncing all over the place from 4-5V and that doesn't look good.
                  If I get a good, working board in, I'll copy the eeprom and post it here for future users.
                  • dumpystig
                    • Jul 2011
                    • 485
                    Re: 32" Goodmans TV
                    Where is the bugger - underneath?
                      Re: 32" Goodmans TV
                      On the top of the board, SG2525A, pin #8. What does yours measure at?
                      • dumpystig
                        • Jul 2011
                        • 485
                        Re: 32" Goodmans TV
                        Got it.
                        STBY - 1V7~1V8
                        RUN - 332mV
                        Good idea with the EEPROM, but I reckon you will have to be certain the replacement board comes from the same manuf./model else it will prob be useless - although I stand to be corrected.
                          Re: 32" Goodmans TV
                          Got it.
                          STBY - 1V7~1V8
                          RUN - 332mV
                          I think I found one for a Goodmans TV available, anyway it's the main board which decides the "personality" of the set so if it boots up as a Hitachi who cares :P
                            Re: 32" Goodmans TV
                            Here's the EEPROM .hex I looked at it and it seems okay, I mean there is data in there like the channel settings (BBC, CH4 etc.) but I have no way of decoding the rest.
                            I'm going to try erasing it and seeing if it resets it, I doubt it though. [EDIT: Nope, still dead.]
                            To get around file size limits I had to rename this to a .doc file.
                            I'm really questioning what part has gone in this set... it's EITHER the PSU or the main board. Right now it's looking a lot like the main board but what would cause this? Software issue? Hardware issue?
                              Re: 32" Goodmans TV
                              Okay, I reversed my fix to the TV with pin #8. Now the LED doesn't blink, but we're back to the original issue: it just won't turn on. I had a little difficulty with the circuit, I broke a resistor off the board (R970), but I looked the schematic and it looks redundant to me, so I bridged it. I might replace it later and see if it matters, but I don't think it will.
                              One pin to look at is SHUTD, as it appears to turn the power supply off. I suspect it must be low to do so. The resistor R970 then might be necessary as it stops the PSU from being held in shutdown while the cap C898 charges. But if we stop the PSU shutting down by removing the transistor which is pulling it down, we might never be able to turn the TV off properly... Ugh! A new PSU is a simple answer, if the main board is good.
                              Now, we have to debug the slow start circuit and find out why it stops the TV starting properly. Perhaps some protection is activating; if so, why?
                              I'm most interested in the transistor Q818 as that seems to handle switching the TV on and off, although the switching on and off is also handled by other parts, so it's like everything has to activate in sequence, maybe this was the problem?
                              There's a lot of protection in this circuit. VFB and Q808 seems to be overvoltage for the 12V rail, tripping on 15V or so. Not bad at all, a good idea in fact. If the caps are aged, the rail might be peaking. So I could look at inhibiting this. Also interesting is the stuff around 5VREF; maybe an undervoltage cut-out?
                              Problem is, this stuff is all primary side. So I can't probe it with a scope as I risk damaging it. Unless I broke the ground pin off the plug but that is very much frowned upon (and rightly so) as it leaves the chassis of the scope LIVE, and dangerous. I'm limited to a 3 Hz multimeter.
                              I've attached a screenshot of the part of the circuit we are interested in.
                                Re: 32" Goodmans TV
                                Ugghhh!
                                I was a doofus, I bought a power supply for this TV, didn't read the description - sold as faulty!
                                Thought it was too good to be true for £10.
                                Although I will still try to get it working - maybe the fault is similar or easier to fix than this one.
                                Also - note to self - I need to reflash the eeprom with the original data, maybe it's not booting because of this?
                                  Re: 32" Goodmans TV
                                  Ah - found an EEPROM
                                  http://www.eserviceinfo.com/download...ips_f4238.html
                                  For a Toshiba but 17MB22 chassis.
                                    Re: 32" Goodmans TV
                                    Ah, got my broken PSU today.
                                    Interesting. The transformer for the PFC has been broken right off the board and is quite loose.
                                    The fuse is also blown.
                                    Apart from this though, it seems okay.
                                    Was thinking of removing the PFC fet, and the PFC transformer. Replace the main winding of the transformer with a piece of wire. It wouldn't have PFC any more, but it should work just like mine did, on 328V.
                                    I'll give it a go, haven't got much to lose.
                                      Re: 32" Goodmans TV
                                      Okay, my remove the PFC mod actually seems to have worked.
                                      At least, the PSU didn't explode...
                                      Got standby 5V and 3.3V.
                                      HOWEVER, it still doesn't start... Any ideas?
                                      Across main filter cap I get ~330V in standby and 310V run. I'm hoping the run voltage is high enough; it's a bit on the low side. My last set must have had partially working PFC because run voltage was usually around 330V and standby was about the same. 310V bus corresponds to 219V AC, and the working range is stated at 220-240V.
                                      I need to reflash that EEPROM and see if it fixes it.
                                        Re: 32" Goodmans TV
                                        I was researching the problem I have and it might be a bit more complex than I thought, but at least it is reasonably easy to fix.
                                        This kit here claims to fix the stuck in standby and blinking LED problems. I have either one of those issues. So I am ordering the components featured in the kit and will try and fix it.
                                        http://www.sparedparts.com/products/...k_light_faults
                                        I have another Acoustic Solutions 32" TV I bought for cheap which appears to have the same problem, so if the Goodmans can be fixed maybe the Acoustic Solutions can be too.
                                        • dumpystig
                                          • Jul 2011
                                          • 485
                                          Re: 32" Goodmans TV
                                          Yep, you sure are having some probs with those Vestel boards - much the same as me ffs. I've had this thing running just fine for days, then I left it off for a few days and on powering up tonight I'm getting the flashing LED crap again. Only today it was a different flash/rate from previous, so up to now I've had four different 'errors' - but nowhere can I find a list of the error codes. But I have narrowed it down to the startup sequence; switch on (from stby) and after a couple of seconds the M/b should chuck out 3V2 on PL003/1 to PL803/1 which in turn goes directly to PL802/12 and supplies the inverter switch-on power. But instead of the 3V2 it's only giving around 2V9, and according to the service manual it should be between 3~5V, and I reckon the 3V minimum is crucial - and maybe there's not enough current either, but the output is too short for me to measure either V or A before it locks out. The backlights illuminate for a split second and then the set locks out and goes into LED flash again. So I'm gona have a closer look at the components supplying the VSUP_3v3_COM on the VCTP.
                                          Back to your set, I think you are having the same probs as I was initially, both my PSU and M/b were playing up. I sorted the PSU and now all the V's are as they should be except the inverter V mentioned above. I'm away for the weekend but I'll get back on it Sunday, and have a closer look at your posts again too.
                                            by momaka
                                            03-12-2025, 03:42 PM
                                          • Paxman_Swede
                                            by Paxman_Swede
                                            Hello!
                                            01-14-2025, 09:51 AM
                                          • captain150
                                            by captain150
                                            03-16-2025, 07:34 PM
                                          • Foetuss
                                            Gigabyte GA-6OXT :: caps question
                                            by Foetuss
                                            Good evening
                                            I recently aquired a rev 1.1 Gigabyte 60XT, and was suprised of the amount of leaking caps for a motherboard of the P3 era. Especially the way the 330µf caps seems like the housing discolored even.
                                            Now, there are some 3300µF 6.3V KZG series around the CPU. Would it be OK to replace them with something like EEUFR1A332 ? (Panasonic FR 3300µF 10V). Or was this board designed around very low ESR caps?
                                            But I was also suprised about the bigger boys, which are 330µF 25V.
                                            Could it be they used 25V caps because they were cheaper / available at that time?...
                                            02-11-2025, 12:22 PM
                                            EVGA e-GeForce 7600 GS AGP 256MD2 [256-A8-N542-T2] with bad caps - fixed
                                            by momaka
                                            I did it again – I had to fulfill my inner desire to fix yet another old piece of hardware. This one is actually kind of worthwhile, too – it’s an EVGA e-GeForce 7600 GS AGP video card, model P/N: 256-A8-N542-T2. With the popularity of “retro” PCs from the Win9x to XP era going up, and the diminishing supply of decent AGP cards, it is expected their prices will go up. Or is it? I bought the this video card rather on the cheap side (~$9 USD shipped to my door), because the eBay seller listed it for parts or repair (and correctly noted the bad capacitors.)
                                            So, here is the...
                                            06-06-2020, 04:39 PM
