32" Goodmans TV
Re: 32" Goodmans TV
The Goodmans LCD TV is now fully assembled and passes all burn-in tests. This time I properly broke the trace between the fet and the SG2525A. Thanks for everyone's help.
Only issue is, there is a rather loud whining noise coming from the TV, I assumed this would go away when case is put back on, but no luck. It seems to be coming from the PFC transformer. Is there any way to fix this? I'm almost tempted to just remove the PFC MOSFET and leave it, as the PFC doesn't seem to be working anyway. Without a MOSFET it would just be a coil with a series diode. Maybe the switching noise from the secondary PSU is causing the noise (introducing it to the PFC coil) in which case removing the coil and replacing it with wire jumpers may be the best solution. (Of course, also removing the MOSFET, otherwise the FET would be shorting out the PSU many times a second.)Last edited by tom66; 07-12-2011, 03:40 PM.Please do not PM me with questions! Questions via PM will not be answered. Post on the forums instead!
For service manual, schematic, boardview (board view), datasheet, cad - use our search.Comment
Re: 32" Goodmans TV
Tom, is your set finally sorted now? Regarding the whining, try checking the inductor L817, that's where I was getting a lot of noise on my PSU; I rolled an A4 sheet of paper into a narrow cone and held it to my ear to help pinpoint the source on the board. I applied a couple of drops of superglue to the top of the copper winding and let it permeate and dry. Repeated this several times, allowing the glue to build up and encase the winding. Now it's almost silent.
My set has been running perfectly over the last three days and I've not had to replace any components. The main thing that worked for me was resoldering loads of joints, concentrating on those parts of the circuit that I deduced (hoped) to be the cause. I think the worse components I found were adjacent to or underneath IC400 on the M/B; it does get quite hot and that T-Wing 'heatsink' seems to me to be almost useless so I removed it and replaced with a small aluminium 'sink from a fubar router I have. I also modded the TV back casing and fitted a 50mm PC case fan directly above IC400 - the difference now in it's temp is amazing, getting nowhere near as hot as it did. The fan is powered from the 12V IDTV supply with a 3W resistor to lower the speed so it's inaudible when the set is on.
Did you suss that the M/B PROTECT_DETECT circuit does nothing regarding the PSU? It goes to PL803/5 and stops there - had me confused for a while as I was assuming maybe this was causing the fault.
Anyway, after all the time I've spent on this and reading of many other faults I reckon these Vestel boards are a complete ballache because of dry joints. But at least I'm sorted now, so happy days.System: HP xw6600 Workstation, 650W PSU | 2x Intel Xeon Quad E5440 @2.83GHz | 8x 1GB FB-DDR2 @ 667MHz | Kingston/Intel X25-M 160GB SSD | 2x 1TB Spinpoint F3, RAID0 | 1x 1TB Spinpoint F3, backup | ATI FireGL V7700 512MB | Sony Optiarc DVD +/-RW | Win 7 Ultimate x64 | 2x Dell UltraSharp U2410f | Dell E248WFPComment
Re: 32" Goodmans TV
Yeah, I eventually found out that the protection on the motherboard isn't used by the PSU. Although, it does go into the CPU. So it's possible that could cause the same symptoms. In my case, it was just the soft start FET Q837.
Agreed. Cheap OEM'd junk...Please do not PM me with questions! Questions via PM will not be answered. Post on the forums instead!
Re: 32" Goodmans TV
IC400 is the VCTP Microcontroller on the M/B - it's near the centre of the board and has the semi-rigid heatsink attached that resembles a 3" long piece of black tape - does yours not have this? And the chip does get pretty hot, on mine anyway. I'll upload a pic shortly.System: HP xw6600 Workstation, 650W PSU | 2x Intel Xeon Quad E5440 @2.83GHz | 8x 1GB FB-DDR2 @ 667MHz | Kingston/Intel X25-M 160GB SSD | 2x 1TB Spinpoint F3, RAID0 | 1x 1TB Spinpoint F3, backup | ATI FireGL V7700 512MB | Sony Optiarc DVD +/-RW | Win 7 Ultimate x64 | 2x Dell UltraSharp U2410f | Dell E248WFPComment
Re: 32" Goodmans TV
IC400 is the VCTP Microcontroller on the M/B - it's near the centre of the board and has the semi-rigid heatsink attached that resembles a 3" long piece of black tape - does yours not have this? And the chip does get pretty hot, on mine anyway. I'll upload a pic shortly.Please do not PM me with questions! Questions via PM will not be answered. Post on the forums instead!
Re: 32" Goodmans TV
It seems to have been an issue on my board - as I mentioned in an earlier post it was reflowing SMD components around/underneath/adjacent to this chip that finally provided my fix.System: HP xw6600 Workstation, 650W PSU | 2x Intel Xeon Quad E5440 @2.83GHz | 8x 1GB FB-DDR2 @ 667MHz | Kingston/Intel X25-M 160GB SSD | 2x 1TB Spinpoint F3, RAID0 | 1x 1TB Spinpoint F3, backup | ATI FireGL V7700 512MB | Sony Optiarc DVD +/-RW | Win 7 Ultimate x64 | 2x Dell UltraSharp U2410f | Dell E248WFPComment
Re: 32" Goodmans TV
Also, did you use thermal paste for the new heatsink?Please do not PM me with questions! Questions via PM will not be answered. Post on the forums instead!
Re: 32" Goodmans TV
I had various symptoms, from 2s-to-black/intermittent running/LED flashing (various rates)/not starting with HDMI connected. As I seemed to resolve one issue another arose, so I've been all over both the PSU and M/B, looking at the circuit diagrams and trying to rectify the relevant stages on each board. It's taken me absolutely ages over the past 3 weeks, done my head in at times, but I saw it as a challenge and was determined to fix the bastard.
I simply attached the heatsink with superglue; over the years I've found it to be very effective in all sorts of applications. The original T-Wing is only attached with adhesive anyway so I guessed I had nothing to lose - as it turns out it's working rather well in conjunction with the fan.System: HP xw6600 Workstation, 650W PSU | 2x Intel Xeon Quad E5440 @2.83GHz | 8x 1GB FB-DDR2 @ 667MHz | Kingston/Intel X25-M 160GB SSD | 2x 1TB Spinpoint F3, RAID0 | 1x 1TB Spinpoint F3, backup | ATI FireGL V7700 512MB | Sony Optiarc DVD +/-RW | Win 7 Ultimate x64 | 2x Dell UltraSharp U2410f | Dell E248WFPComment
Re: 32" Goodmans TV
No....
It just died!
When turned on the standby LED blinks on and off.
Bad caps... I hope so this time.
I will also attempt to fix the PFC circuit.Please do not PM me with questions! Questions via PM will not be answered. Post on the forums instead!
Re: 32" Goodmans TV
Yeah Snap! WTF? Been having a different prob the last 2 days - switch on, tries to power up, locks out with LED flashing for a couple of mins.
I now seriously believe it to be somewhere on the inverter/backlight stages.
In the LG Panel datasheet it shows the power sequence for the panel and the inverter/lamps but I don't have a 'scope so can't get very far with that. But also the inverter start voltage [PL003/1 > PL803/1] should be Min.3VDC - Typ.5VDC but most times my M/B is outputting around 2.9VDC and I reckon this is crucial. It could also be that there is an intermittent fault further along either on the inverters or the lamps. You any idea how to access the lamps?System: HP xw6600 Workstation, 650W PSU | 2x Intel Xeon Quad E5440 @2.83GHz | 8x 1GB FB-DDR2 @ 667MHz | Kingston/Intel X25-M 160GB SSD | 2x 1TB Spinpoint F3, RAID0 | 1x 1TB Spinpoint F3, backup | ATI FireGL V7700 512MB | Sony Optiarc DVD +/-RW | Win 7 Ultimate x64 | 2x Dell UltraSharp U2410f | Dell E248WFPComment
Re: 32" Goodmans TV
I'm going to scope the standby PSU. Suspect bad caps.Please do not PM me with questions! Questions via PM will not be answered. Post on the forums instead!
Re: 32" Goodmans TV
I did more reading of the panel datasheet to try and get a better understanding of how the bugger works. I'm looking at the LVDS cable at the moment, I'll let you know how I get on. You had any luck with what you were trying?System: HP xw6600 Workstation, 650W PSU | 2x Intel Xeon Quad E5440 @2.83GHz | 8x 1GB FB-DDR2 @ 667MHz | Kingston/Intel X25-M 160GB SSD | 2x 1TB Spinpoint F3, RAID0 | 1x 1TB Spinpoint F3, backup | ATI FireGL V7700 512MB | Sony Optiarc DVD +/-RW | Win 7 Ultimate x64 | 2x Dell UltraSharp U2410f | Dell E248WFPComment
Re: 32" Goodmans TV
I also have been offered an Acoustic Solutions 32" TV. Made around the same time as the Goodmans. Has a problem: turns itself off after a few minutes. Could be bad caps. Who's betting it's using a 17MB22 chassis too?
Rather interestingly I caught eye on an Acoustic Solutions 32" with faulty sound. Of all companies to get sound right, it should be Acoustic Solutions... It sold for too much though.
I'm on the look out for a 42" Full HD TV. I got a 42" 720p from the local tip. Honestly, I don't know how much difference it will make at the distance TV is watched at, around 10 ft.
Last edited by tom66; 07-23-2011, 06:09 PM.Please do not PM me with questions! Questions via PM will not be answered. Post on the forums instead!
Re: 32" Goodmans TV
Okay, it's open...
5VSTBY is 5.04V
3.3VSTBY is 3.36V
Both are good.
Main PFC bus voltage still stuck at 328V, but it used to work on this.
The set is stuck in standby, but the main 5V line measures 1.8V...? Could be an issue.,
3.3VSTBY is getting 600mV dips on it when the LED flashes. (A whining sound is also briefly emitted during this time.) This downwards going pulse might be the reason the set is cycling, but what is causing it?
The LED flashes approximately three times a second and the 3.3VSTBY dips are in phase with it when it goes out...
Note that the TV is not being switched on at this time. This occurs as soon as it is plugged in.Last edited by tom66; 07-24-2011, 05:11 AM.Please do not PM me with questions! Questions via PM will not be answered. Post on the forums instead!
Re: 32" Goodmans TV
I lifted the main board out - no shorts or screws. I thought a screw may have fallen behind it. No such luck...
I think the VCTP is causing the problem. The PDP_GO/BL_ON_OFF is pulsing high, then low, at about 3 Hz, in time with the LED, and the 3.3VSTBY dipping by 600mV. Disconnecting the inverter cable doesn't help. There's no signal from the inverter telling the TV to shut off, and when disconnected the set does the same thing, so I think I can rule out the inverter.
The set is turning on, then turning off, for some reason.
Oddly, pressing MENU, CH_UP or VOL_DN makes the flashing stop. (Other buttons have no effect.) The set doesn't work, but it makes me suspect more and more that the VCTP is at fault.
1.8VSTBY is good too, solid 1.886V, no dips. That's 4.8% above nominal, but it should be fine as there is a typical ±5% tolerance on most cheap regulators.
PROTECT_DETECT, the signal going into the VCTP, is always low. Measured at R454.Please do not PM me with questions! Questions via PM will not be answered. Post on the forums instead!
Re: 32" Goodmans TV
STBY_ON_OFF is pulsing high-low every 3 Hz with a 75% duty cycle, now that tells me the set is trying to turn itself on, but why? It normally stays in standby when you plug it in and only turns on when you press the button on the remote...!
This seems to be a software issue - the VCTP is telling the PSU to turn on! Perhaps it is too early for it to turn on and it isn't ready... perhaps the PSU is also bad. I did pull the power out while it was on, and this could have killed it.
I will remove the EEPROM from its socket and see if the set boots up.Please do not PM me with questions! Questions via PM will not be answered. Post on the forums instead!
Re: 32" Goodmans TV
Yep, I'm having similar probs which I'm attributing to the VCTP or its surrounding components - in particular the PDP_GO/BL_ON_OFF trigger for the inverter power up supplySystem: HP xw6600 Workstation, 650W PSU | 2x Intel Xeon Quad E5440 @2.83GHz | 8x 1GB FB-DDR2 @ 667MHz | Kingston/Intel X25-M 160GB SSD | 2x 1TB Spinpoint F3, RAID0 | 1x 1TB Spinpoint F3, backup | ATI FireGL V7700 512MB | Sony Optiarc DVD +/-RW | Win 7 Ultimate x64 | 2x Dell UltraSharp U2410f | Dell E248WFPComment
Re: 32" Goodmans TV
EEPROM removed, same problem.
WP is always high. WP should be low for normal operation according to svc manual, but write protect is actually active low. So it is good that it is high. Service manual is wrong.
Something else is wrong then...Please do not PM me with questions! Questions via PM will not be answered. Post on the forums instead!
by momakaI know I've been a little scarce lately (like the last 2-3 years), but I'm still here and still doing my thing with fixing PSUs.
https://www.badcaps.net/filedata/fetch?id=359177... -
by Paxman_SwedeHello!
I have studied the board and...-
by captain150I'm trying to repair two old VCRs, they both have bad caps. One has leaky ones, the other would barely run until I subbed in some caps from another power supply I had laying around (though they are the wrong values). This vcr works for an hour or two, but then the power supply starts whining and the picture gets lines in it. I didn't replace all the secondary caps, so another voltage might still be problematic, or the values I used are too far off.
I've been on mouser and digikey but the options are a bit overwhelming. I just need some new ones that will work. They don't need to be top quality,...-
by FoetussGood evening
I recently aquired a rev 1.1 Gigabyte 60XT, and was suprised of the amount of leaking caps for a motherboard of the P3 era. Especially the way the 330µf caps seems like the housing discolored even.
Now, there are some 3300µF 6.3V KZG series around the CPU. Would it be OK to replace them with something like EEUFR1A332 ? (Panasonic FR 3300µF 10V). Or was this board designed around very low ESR caps?
But I was also suprised about the bigger boys, which are 330µF 25V.
Could it be they used 25V caps because they were cheaper / available at that time?...-
by black6hostGood day!
I have a Samson Resolv studio monitor that has no sound output. I've opened it up and found two caps that are bulging on what I believe to be the power supply section of the amplifier board. The board is marked Resolv 65A AMP V1.2. The caps in question are YUSCON, 2200uF, 35V, 85C temp and have markings of RA(P) and are 16mm x 25.5mm tall. I've attached the schematic and the caps in question are C5 and C6. I'm assuming they are low esr caps. I've tested both caps and they test low uF, nowhere near 2200uF.
I'm going to replace the caps and I'll be the first...-
- Loading...
