Dell 2407WFPb Monitor - Bad Cap
Re: Dell 2407WFPb Monitor - Bad Cap
The reason it does not work may due to the sub-power supply board has the problems, there are buck regulator circuits that convert the 19v to lower voltages that you need to check.
http://s807.photobucket.com/user/bud...?sort=3&page=1Never stop learning
Are the PSU boards for the 2405 and 2407 boards interchangeable? There seem to be a lot of 2407 boards floating around on ebay / taobao, whilst the 2405's are a bit thin on the ground. The connectors mark CN701 (to logic board) and CN702 (to inverter) look identical in terms of dimensions and wiring colours.Comment
I am currently working on a Power-Supply of a 2407WFPb.
Trough the help of you in this awesome Forum, i was able to find replacement-Parts for all dead components on my board, with exception of one:
On my board, C626 is dead as well. Does anyone know, what capacity C626 is?
Would be great to have more information on that.
btw:
If anyone needs more inforamtion about this board:
I have drawan the complete scematic of that board (currently only by hand as a draft) by following the traces and mesaunring the components.
Now i am adding all known information of all the Parts (Ratings, values, replacement-parts etc.)Comment
Looks like this is a list of caps (IF YOUR board is the same) so you can work out
which it is by elimination
https://www.badcaps.net/forum/showpo...2&postcount=33Please upload pictures using attachment function when ask for help on the repair
http://www.badcaps.net/forum/showthread.php?t=39740Comment
Sorry I did try to find a pic but couldnt see one.
Re there no markings on it - The physical size is also a clue.
If you have made out a schematic do you already know the voltage?Please upload pictures using attachment function when ask for help on the repair
Yes, ok.
No, unfortunately there are no markings.
It is a standard SMD case, probably 0805 size.
Voltage would be verry low, this cap goes from Pin 4 of the L6561 to Ground.
Pin 4 is the current-feedback-voltage, measured by the famous R670, which is 0.22Ohms.
I would assume that this cap is around ~10nf, it is just to filter the current-feedback.
On the Typical Application Circutis in the datasheet of the L6561, there is no capacitor in that position,
maybe it works even without...Comment
I cant find any reference to it as being faulty but on this russian site
http://monitor.espec.ws/section33/post1216836.html
there is a clear picture of it and is is on their wiring diagram.
If it doesnt work without it C628 looks to be the same size and if you have any facility to measure that, perhaps try one the same value.
Unless anyone comes up with a definitive reply.Please upload pictures using attachment function when ask for help on the repair
I did not find that russian site so far - thanks!
On my board, C628 is a fair bit 'higher' (or thicker) than (what remained of) c626.
Anyway i measured C628 - it's 1uF.
R669 and C626 form an RC-Lowpass for the current-feedback,
currently i don't know the switching-frequency, but 1microfarad seems to be to much:
R669 is 1k, so the filter has a Frequency of 195Hz, which i think is to low, since the switching-frequency is probably somewhere around 10kHz.
I think i will try with ~1-10nF (159kHz - 15.9kHz).
In the meantime i found the Application-Note AN966 from ST.
There i can find one circuit example, where they have a filter in the feedback-path.
There they have 330Ohms and 1nF Capacitor.
You will get a feedback when i replaced all the failed parts, but i have to order them first.
And befor i can order, i have to finish the BOM of another Project, because i want to order all parts together.
So it could take some time till i have any feedback.Comment
Ok - Good luck
Its always useful to report back as it may help others in the future.Please upload pictures using attachment function when ask for help on the repair
Hello friends.
Won by a monitor 2407WFPb is defective and friend who gave me could not waste time on concert.
Well, ask experts to help this wonderful Forum.
Here is what I noticed in the defect:
Perfect operation, image and fully operational controls, but after 30 minutes, she literally "LOCK". Turns off the power and turns the power on and it starts normally and back to work for another period.
I opened the monitor and visually saw no fault in the components.
I suspect there might be some problem with the "Firmware".
I leave here so this case to analyze.
Hugs.
Ps: Sorry for my English, I'm using a translator.Comment
This is not going to be easy!
Can you post good clear pictures of your boards.
When it "locks" do you mean
1 picture stays on
2 screen goes blank power led stays on
3 screen goes blank power led goes off
4 screen goes white.Please upload pictures using attachment function when ask for help on the repair
On the PC (VGA), after about 30 minutes, the screen goes black, the LED on and dead controls.
Connected to a satellite receiver (TV) (VIDEO) after about 30 minutes, the screen is with mixed colors and illuminated LED controls and dead.
Turning off the power on again and everything back to normal until locked again.
Post photos later.
Grateful.Comment
"On the PC (VGA), after about 30 minutes, the screen goes black, the LED on and dead controls."
Can you still see anything on the screen - perhaps shining a flashlight on it?
If you switch it on and heat the boards with a hairdryer does it turn off any quicker?
If you keep it cool with a fan does it stay on any longer?Please upload pictures using attachment function when ask for help on the repair
I'll post the results.
Grateful.Comment
My Dell 2407 has has the most common problem in this thread:
a oxidized capacitor C605, burned R670, broken IC651 (like it exploded), some other semiconductors have 0 resistance ...
Is there evidence that this type of defect is "planned obsolescence or built-in obsolescence"? I assume the capacitor C605 is a special type to reduce the lifetime of this monitor to less than 6-8 years.
At the moment there are some offers for power supplies on ebay. The power supplies are advertised as new with a price tag from USD 20 to USD 60 and shipping cost from USD 10 to USD 30. Anybody had success with a power supply from china?Comment
Current Item no. for PSU is 131028175844
Current Item no. for 10 caps is 400583064089
by MORETTIGIANTitle:
Description:
Procedure performed:
- Removed backplate
- Reapplied thermal compound
- Reassembled card
- GPU powers on and operates normally under...11 Photos -
by Borse2008Hi everyone,
I have a Dell U3425WE, which I've recently replaced with another model. That said, the original unit is still fully functional in terms of the display — it works perfectly over HDMI and DisplayPort. However, the USB-C and Thunderbolt 4 ports have stopped functioning correctly. The Issue:- The 90W Thunderbolt 4 port (circled in the photo) no longer charges or powers any device, including laptops or MacBooks.
- There’s
07-15-2025, 04:55 AM -
by LapsmithWhile installing new SSD's in my new to me Dell 5520 laptop, I dropped a screw which sparked and fried a capacitor. Yes, I know I should have disconnecte the battery first Doh!😡. The laptop runs fine, but I want to replace the capacitor asap. I ordered and received the replacement (10uF, 25V 0603). Since I also managed to burn up one of the pads it was soldered to, my main question is whether it is okay to solder this capacitor on top of another capacitor (same size, same function in circuit). Specifically, PC4428 is bad and no way to easily solder to the board. I would like to solder it piggy...
by BowlineMy question pertains to understanding the control circuity inside a Dell PT434 type battery used in Dell E6400, E6410 and other Dell notebooks?
I have tried multiple different Dell power adapters. My Dell... -
by momakaNormally, I never post repairs this quick after I do them, because… I am usually very slow.
But today, I’m making an exception here. Why? No idea. Perhaps only because the repair details are still “fresh” in my head… which is ironic, given this is a 16 year old monitor that hardly anyone will care about today. It is new to me, though.
I picked it up last November from someone on my local Craigslist. It wasn’t very close to where I live, but was close to a family friend that I had to go visit anyways. So after watching the posting on Craigslist for a few weeks and seeing it getting...
- Loading...
