Dell 2407WFPb Monitor - Bad Cap
  • pkanar
    • May 2013
    • 19
    Re: Dell 2407WFPb Monitor - Bad Cap
    @macjedimatt: If you are doing the standard bypass surgery described in post 151 above, then you were correct that T601 is on the high-voltage side of the black line (only pins 9 and 10 are on the low-voltage side, but they are on the other side of the barrier diodes from the +19V rail you are hooking up. So, there should be no current flowing through T601 after the bypass, even if you have shorted the coil between pins 7-8 and 9-10. It should work. If it doesn't, there must be another cause. Are you by any chance connecting the +19V supply to the T601 side of the barrier diodes?
    • Venomhatch
      Disney Employee
      • 44
      After fixing the Main big Cap, replaced the fuse with same amperage one. Plugged it in. Book IC651 blows a section of the top of it and that is gone now. I just need to find a new Power Board. Any ideas where to find one? I have tried eBay and local CL. Ohh and I have the 2405FPW
      • macjedimatt
        • May 2012
        • 21
        Hmm.. Ok that is good to know. I did this one the same way I did the other two I have done and they both work fine. One has been running everyday for over a year. I noticed that the PA-6 power supply cuts out when I connect the power board to the main board. The main board is fine. I tested with parts from one of the others.
        It is good to know I didn't kill the board! I'll have to do some more testing. It could be the particular PA-6 I'm using. I noticed the markings on it are different from the others. Does anyone have a pin out of the main board power connector so I can check the voltages without having to dismantle one of the other 2407s I just put back together?
        Thanks!!
        • lexwalker
          • Feb 2011
          • 307
          • Malaysia
          #404
          Originally posted by Venomhatch
          It is coming from the edges of the top leaking inwards to the middle. I also thought it was just marker, and it isn't bulging. But I also never have seen marker look like a powderish substance.
          Most likely red marker pen, seen plenty of those. Most often they would use either green or blue instead of red. When in doubt, simply replace them.
          Originally posted by macjedimatt
          My monitor also failed, I tried using the powersupply trick with a Dell PA-9 adapter. The power adaptor's light goes out when I connect power to it. It looks like the transformer(?) near the top of the board is damaged. The markings under the heat pad are: 1J.20289.001 LTSJ 0621. Anyone know where I can get a replacement? I tried searching digikey but there are way too many options.
          No. This was the same failure. After successfully fixing 2 of these, for some reason I thought it would be a good idea to cut the small wires on it. I thought it was connecting to the AC side of the board. As soon as I did it, I realized what that part was for The damage is a little beyond what I can manage to repair safely. It doesn't look like something I can find easily without more information, which I haven't been able to get. I suppose it is just as well. This panel has a scratch on it and the stand is missing.
          Before or after the barrier/schottky rectifiers/diodes? Usually should be after the rectifiers as they would block the DC back to the transformer, unless one of the rectifiers/diodes is shorted (or had breakdown at certain voltage threshold). I usually use a bench power supply to test first.
          • BastiaanNaber
            • May 2013
            • Netherlands
            #405
            I'm trying to source the parts I hope are damaged. I'm having a hard time finding the Q651 and the big cap (120UF 450V) in stores around Schiphol, the Netherlands. I have looked in this thread where Farnell and Digi-Key are mentioned. Digi-Key wants 18 euro (more than $20) for shipping and Farnell won't ship to consumers.
            Any descent online suppliers? I'm willing to pay something but 18 euro is a bit steep for a 2 euro component I think.
            • lexwalker
              • Feb 2011
              • 307
              • Malaysia
              #406
              If can't find 450V capacitors, then can go for higher 500V ones. If this monitor does not have PFC then can use lower 400V ones as well (which is the voltage rating found on most AC-to-DC adaptors with the same topology). If can't find 120uF then go for 150uF or 180uF. Usually I get mine from RS Components, Farnell or Mouser. Sometimes I use eBay. Plenty of those 120uF 450V on eBay though, and cheaper too.
              • pkanar
                • May 2013
                • 19
                It does have PFC; needs 450V or higher (and 500V will be even harder to find).
                • Venomhatch
                  Disney Employee
                  • 44
                  Ok so I am thinking if I can use this:
                  To do the job of my PSU Board? I dont need the audio to work just the video portion.
                  If it is possible I guess I would need to know if anyone can tell me what both of the harnesses need voltage in these pics?:
                  I am thinking this could work if all that PSU board does is distribute power. But I would need to make sure everyone gets the right voltage they need.
                    That power supply is only 40 Watts, typical power consumption without Audio and USB is 57 Watts, max is 110 Watts. So the power supply should be at least 20% higher power capacity than 57 Watts MINIMUM.
                    https://cdn.badcaps-static.com/pdfs/...0a5c54d930.pdf
                    You can also see the in-rush current rating in the spec sheet.
                    • Mattylad
                      • Mar 2013
                      Cheers for the PSU fix - works a treat.
                      • macjedimatt
                        • May 2012
                        • 21
                        For those of you keeping track, I figured out what was wrong with it. The Dell PA-6 power adaptor I was using just couldn't handle it. The markings on it are very different from the other two I'm using so maybe this one just isn't made as well
                        I switched it out with a PA-9 and it works great. I also found a base for it This makes three of these monitors I've fixed now. I have two using the PA-6 which is a 70W powersupply and one using a PA-9 which is 90W.
                        • nothin
                          • Jul 2013
                          Sorry if this has already been covered, I scanned through this thread and did some googlin, but it's hard to absorb information when post #9 in a massive thread is a picture perfect image of my leaking cap, but with different markings
                          I'm an Aussie (so our sparks come out at 240V) and one of my three aged but still fantastic 2407WFP's turned itself off while in standby the other night and now refuses to power on.
                          Here's the only obvious sign of damage (from comments in this thread I see there may be a lot of caps to be suss at, but this one made it pretty clear it's unhappy):
                          While I have the most basic understanding of capacitor specs, the lack of values for farads and volts on this one leaves me stupefied. Would one of you find capacitor wizards be able to point me in the direction of a suitable spec for replacement?
                          • pkanar
                            • May 2013
                            • 19
                            @nothin: The voltage and capacitance are on the bottom side. It will be the same as everyone else's (120μF, 450V). Insert a blade under it and gently cut the caulk from the board, to reveal its spec.
                            Beware that the repair will not be as simple as replacing C605. The Q651 MOSFET is almost certainly blown (measure it with an ohmmeter to convince yourself). The 2 microchips on the back likely need replacing, too.
                            There are fixes, and the answers are all in this thread, but a successful repair will require you to undertake a more serious study than what you have done so far.
                            • nothin
                              • Jul 2013
                              OK Cheers. I'll set aside some time to read all the way through
                              • nothin
                                • Jul 2013
                                So I've confirmed the following are dead:
                                C605 - 120uf 450V 105C
                                F601 - 4A, 20mm, antisurge ceramic fuse (T4A H)
                                Q651 - STP10NK60ZFP, Zener protected N-channel MOSFET, TO-220, FEC code 993-551
                                ZD601 - 15V 0.5W Zener diode
                                R670 - 0.22 ohm
                                Is R670 a 1/2W?
                                IC651 - L6561D - physically appears ok, my multi doesn't have a capacitance check, are there any other test for this one?
                                • lexwalker
                                  • Feb 2011
                                  • 307
                                  • Malaysia
                                  #416
                                  Check surrounding components linked to this MOSFET, especially trace connections from the gate to the PWM I.C for possible failed components....
                                  R670 - 0.22 ohm
                                  Is R670 a 1/2W?
                                  This one sounds like Rsense (ie. resistor for current sensing). That one is usually at least 2W or higher. Recommended replacement would be wirewound type resistor, rather than carbon film. Also trace the connections from this Rsense as well for any other failed components.
                                  Not sure if this power factor correction I.C is spoiled, though in my opinion usually they don't usually spoil easily. In your case, I could be wrong though...
                                  • jetadm123
                                    • 2169
                                    #417
                                    You really can't use a capacitance function to check this chip. You can try a quick test by setting your meter to 1K resistance setting and checking for a short across the Vcc and ground pins.
                                    If you're going to order all your parts from one source, go ahead and order the L6561D anyway, since it's a low cost chip.
                                    • nothin
                                      • Jul 2013
                                      I think there was a post earlier here where a bloke had deemed it faulty as a connected cap was giving incorrect readings when on the board, but checked ok individually, though I may have mixed this up with another IC anyway
                                      Makes sense - I've got 3 of these monitors, so was probably gonna order some extars anyway. On this topic, is there a consensus on which component or components actually trigger this fault? I wouldn't mind replacing these on the other two monitors, since they're of about the same age. And also, does anyone have recommendations for somewhere that ships to AU that would have all these components available? Most of our local electronics retailers carry a pretty limited range of stock...
                                      • pkanar
                                        • May 2013
                                        • 19
                                        The consensus here is that C605 is the origin of this failure. Check the ripple current spec on the replacement; it should be at least as high as the OEM, which was 740mA @ 120Hz. Also, my impression (from reading this thread) is that the PFC chip usually fails together with R669, but sometimes does not fail, however the PWM chip (IC601) has to be replaced every time, even though the measurements do not pick up anything obviously wrong with it.
                                        The 15V Zener regulates the rail that supplies both IC's. If yours is toast, replacing both IC's is prudent. That PFC chip did drive the power MOSFET to its death. Now, the PFC cannot see the ripple current that hits the circuit after C605 disconnects, except on pins 1 and 8. And I am guessing what actually happened is that it was fed with too many volts on pin 8.
                                        • pkanar
                                          • May 2013
                                          • 19
                                          Just got a test report that my repair of the power board was a success.
                                          All parts were from Mouser, with substitutions done as follows:
                                          Q651: 2SK3502 -> STF16NK60Z (14A in a plastic package)
                                          IC601: NCP1200A -> NCP1200 (60kHz)
                                          IC651: L6561 -> L6562
                                          The full Mouser part list was:
                                          667-EET-ED2W121BA
                                          511-STF16NK60Z
                                          863-NCP1200D60R2G
                                          511-L6562D
                                          576-0215004.MXEP
                                          756-W21-R22JI
                                          • keepread
                                            Dell monitor PSU vs Dell laptop PSU
                                            by keepread
                                            Hi there!
                                            Someone gave me their old monitor, it's Dell S2715ht.
                                            The owner was using it when his PSU began to smell and then to smoke. It literally began to melt. He turned the monitor off, pulled the PSU, and ditched it because it was smelly even after it cooled. So I got the monitor but not the plug.
                                            Now, I tried to bring the monitor back to life, by plugging one of my many Dell laptop PSUs. They are of the same 19.5V, and the wattage of the laptop PSU is higher than that which the monitor is rated for. Visually, the socket on the monitor seems compatible, and the plug plugs...
                                            10-30-2025, 04:45 PM
                                          • MORETTIGIAN
                                            by MORETTIGIAN
                                            Title:
                                            Description:
                                            Procedure performed:
                                            - Removed backplate
                                            - Reapplied thermal compound
                                            - Reassembled card
                                            09-18-2025, 12:14 PM
                                          • Borse2008
                                            by Borse2008
                                            • There’s
                                            07-15-2025, 04:55 AM
                                          • Lapsmith
                                            Fried capacitor on Dell-5520. Guilty as charged.
                                            by Lapsmith
                                            While installing new SSD's in my new to me Dell 5520 laptop, I dropped a screw which sparked and fried a capacitor. Yes, I know I should have disconnecte the battery first Doh!😡. The laptop runs fine, but I want to replace the capacitor asap. I ordered and received the replacement (10uF, 25V 0603). Since I also managed to burn up one of the pads it was soldered to, my main question is whether it is okay to solder this capacitor on top of another capacitor (same size, same function in circuit). Specifically, PC4428 is bad and no way to easily solder to the board. I would like to solder it piggy...
                                            07-06-2025, 11:08 PM
                                          • Bowline
                                            by Bowline
                                            06-11-2025, 10:13 AM
