Re: Dell 2407WFPb Monitor - Bad Cap
I have just done a by pass today,and the Monitor switched on using a 19.5v 3.950amp Power pack.The screen was very good EXCEPT for some slight distortion which looked like small waves travelling across the screen.The first thing was to try the refresh rate,and it was better at 60Hz then anything else higher.I assumed then it was probably poor regulation from the 'cheapo' power pack,and replacing it with a 20V 7amp power supply resulted in a perfect picture.This pack had an internal fan which switched on after about an hour or so,so suspect you probably need a good quality one with a minimum of 5amps at the 20V(100W).
Kudos to AdrianM! You are definitely a genius!!! Got mine fixed now. Tons of thanks. Recommend everyone to do the magic formula as described by AdrianM in post #155. Cheers!
Got it fixed now. New approach though. I began to wonder what voltage(s) were supposed to be produced by the SMPS so traced out the circuit around the output transformer. The feedback for the buck stage is obtained via an opto switch that comes on at about 20V (determined by a LM431 variable Zener). Just the one 20V supply rail then! A quick hookup to a bench supply confirms a happy monitor when juiced by 20V@3A.
