Dell 2407WFPb Monitor - Bad Cap
  • selldoor
    Slow Learner
    • Dec 2010
    • 7870
    #221
    Re: Dell 2407WFPb Monitor - Bad Cap
    Originally posted by sabretooth
    I checked F701. It seems OK! It's also not like any fuse I've ever seen before. But it checked out.
    No, as I said I had not seen one before but there was a phillips tv with some in a day or two back
    Unfortunately I've got no idea how to determine resistor wattage based on size. It's approx 4mm x 10mm, though. Googling "4x10mm resistor" has come up with a bunch of hits suggesting 1 watt.
    Ive looked on digikey - yes 1 watt is most likely
    The silver line of solder I think you're referring to - the goop that used to
    hold down the original capacitor? I'm not seeing any lines of solder.
    Good- couldnt tell from pic what it was - it was just something odd.
    • sabretooth
      • Apr 2012
      • 62
      Alrighty. I think I've got everything I need to know. Time to make the orders - having to turn to eBay for the resistors but everything else I can get from a few local reputable stores. Hopefully this ends with a working monitor and I can stop taking up a disproportionate amount of space in this thread!
      • sabretooth
        • Apr 2012
        • 62
        Originally posted by sirzur
        I have looked at it through a magnifying glass with a bright LED light on the surface and I can't see any dot I can only assume that pin 1 is the bottom left when the words are the right side up
        I must have bought the same component - no markings whatsoever as to what pin is supposed to be pin 1.
        • selldoor
          Slow Learner
          • Dec 2010
          • 7870
          #224
          I finally went by the bevel. Looked up the dimension of the SO-8 package and wikipedia showed the bevel. Pin 1 is on the bevel side, on the left
          Does yours have the bevel?
          • sabretooth
            • Apr 2012
            • 62
            I thought I was clever by doing a search on the forum and finding his post - shame I wasn't resourceful enough to find the followup It indeed does have a bevel on one side. Thanks.
            • sabretooth
              • Apr 2012
              • 62
              Argh, well this has come to a premature end. When I was removing one of the ICs, I must have yanked out one of the lines onto which the IC solders. Damned if I can find where it comes from.
              • selldoor
                Slow Learner
                • Dec 2010
                • 7870
                #227
                If you post a good picture of the damage zone we may be able to suggest
                a fix.
                • sabretooth
                  • Apr 2012
                  • 62
                  Hopefully this is good enough, then!
                  I've already tried scratching around to find the trace but haven't tried very hard and didn't want to push it in deeper or make fixing more difficult.
                  • selldoor
                    Slow Learner
                    • Dec 2010
                    • 7870
                    #229
                    Looks fixable - I am just going off for a week (very inconvenient!) others should be able to advise. Try and clean the area up with isopropyl alcohol on cottonbud or soft brush
                    Probably Not all the pins need attachment see if you can find a datasheet for the chip.
                    • Jasgriff
                      • Feb 2012
                      • 578
                      I agree with selldoor... Very inconvenient that he is having a week off!
                      Do you have any isopropyl alcohol? dont scratch it anymore just get hold of some of that stuff and it will clear the majority of it up. Then get us another pic and we can help work out what goes where.
                      Fixed so far : 1 Home cinema system, 16 LCD Monitors, 4 LCD TV's
                      How to resize your pictures guide click HERE
                      Retiredcaps Ideal post example click HERE
                      • dawm123
                        • May 2012
                        • China
                        #231
                        Originally posted by WillyBobz
                        Thank's for all the information NZROSSI, I have just looked on the website....wow it looks quite complicated! Can you give me any step by step instructions as to how to order, I will use the same agent that you used. Any help/advice GREATLY APPRECIATED!!!!
                        Regards
                        WillyBobz
                        Also need help.I smalltao point of view in things, but do not know how to do this?
                        • sabretooth
                          • Apr 2012
                          • 62
                          Alright, busy times but got some time to clean up the circuit board and take a photo.
                          I'm pretty sure I've ruined it! See attached.
                          • WillyBobz
                            • May 2011
                            • 11
                            • England
                            #233
                            Hi Sabretooth,
                            Check out this link below, it is for a Polish forum, use google translate, it also has the Diagram for L651, hope that this may help you.
                            Good Luck!
                            http://obrazki.elektroda.pl/1950185900_1304529310.jpg
                            • selldoor
                              Slow Learner
                              • Dec 2010
                              • 7870
                              #234
                              Hi Sabretooth,
                              Good Luck!
                              I am not so sure-Willtbobz, what was the main link to this.
                              The components we do know are D605 on pin5 (not on pic) A 10k resistor on pin1 (could be on pic but not labelled C613 on pin 6 (not on pic)
                              Similarly we have R617 R627 R622 R609 Q602 not mentioned on pic.
                              perhaps they only have topside components labelled.
                              • selldoor
                                Slow Learner
                                • Dec 2010
                                • 7870
                                #235
                                Right - Help required from circuit experts - I attach a pic - I have guessed that the IC in question is a NCP1200A (got confused in the threads) Most of the connections seem obvious but struggling with where pin 8 goes. Sabretooth can you see the hole/pin I have dotted the yellow to - what is on the other side of the board at that point. Can you do a close up of the area.
                                Team -feel free to comment this is a suggestion only and we dont want to cause further damage.
                                  If I am correct, that HV pin is the kick start power input from the main DC supply through a bunch of resistors connected in series to drop the 325 Vdc from the main cap down to about 12~18vdc to start the SMPS, once it started, the power supply circuit inside the SMPS will switch from the HV pin to the VCC pin which is generated by the extra winding off the transformer.
                                  I have the 2407WFPB at home that I need to work on, so which board is this I need to look at?
                                  • selldoor
                                    Slow Learner
                                    • Dec 2010
                                    • 7870
                                    #237
                                    Power supply back – board number is 4H.L2K02.A01 position marked on attached
                                    • soumen1
                                      • Mar 2012
                                      • India
                                      #238
                                      Originally posted by soumen1
                                      I have replaced the unknown zener with a 6.8V 5W zener. [...] My only remaining question is, should I continue like this with an external 5V power supply, or should I try to replace the hexfet and inductor back in the board. It would be nice to get back to one power supply. The danger is, if the gate control circuit was damaged, the zener and hexfet will do fireworks again, and this time I may not be lucky and downstream components may fry.
                                      Update: I tried replacing the hexfet, and thanks to the 5W 6.8V zener I earlier connected across the load, my display board (the one with the Genesis chip) did not fry. The hexfet gate control is clearly kaput as well, as the supposed 5V drain rose to about 7 volts and the zener got hot (but survived). I turned off the monitor hastily and returned to an external bypass 5V power supply to the display board.
                                      Without a schematic and test voltages, it's very hard to debug the gate control of the hexfet. So my plan is to install a Murata OKI-T/3-W40P-C POL buck DC/DC converter from the 19V source to the required 5V drain, bypassing the on-board converter completely like I am doing now, but drawing from the 19V rail on the internal SMPS board. BTW, I also added the 27V zener in parallel with a 30V MOV on the 19V rail (after the 5A slow blow fuse) for added safety in future.
                                      https://cdn.badcaps-static.com/pdfs/...4ea943619a.pdf
                                      • WillyBobz
                                        • May 2011
                                        • 11
                                        • England
                                        #239
                                        Pin 8 connects to R603 on other side of board as in the Diagram on the link in my previous response.
                                        I have checked this against a power supply board that I have on the bench.
                                        Sorry unable to take a decent picture (close up)
                                        • selldoor
                                          Slow Learner
                                          • Dec 2010
                                          • 7870
                                          #240
                                          Thats Great Willybobz - I forgot there is a high def pic earlier in the post.
                                          I think we just need sabretooth to test what pads he has got for continuity to the next joint then he can try and fit it. Any without continuity will have to be wired. Perhaps he can put a snipped cap leg into the "through" and a
                                          small wire from that to pin 8 rather than just a solder blob. Anyone any other ideas.
                                          • keepread
                                            Dell monitor PSU vs Dell laptop PSU
                                            by keepread
                                            Hi there!
                                            Someone gave me their old monitor, it's Dell S2715ht.
                                            The owner was using it when his PSU began to smell and then to smoke. It literally began to melt. He turned the monitor off, pulled the PSU, and ditched it because it was smelly even after it cooled. So I got the monitor but not the plug.
                                            Now, I tried to bring the monitor back to life, by plugging one of my many Dell laptop PSUs. They are of the same 19.5V, and the wattage of the laptop PSU is higher than that which the monitor is rated for. Visually, the socket on the monitor seems compatible, and the plug plugs...
                                            10-30-2025, 04:45 PM
                                          • MORETTIGIAN
                                            by MORETTIGIAN
                                            Title:
                                            Description:
                                            Procedure performed:
                                            - Removed backplate
                                            - Reapplied thermal compound
                                            - Reassembled card
                                            09-18-2025, 12:14 PM
                                          • Borse2008
                                            by Borse2008
                                            • There’s
                                            07-15-2025, 04:55 AM
                                          • Lapsmith
                                            Fried capacitor on Dell-5520. Guilty as charged.
                                            by Lapsmith
                                            While installing new SSD's in my new to me Dell 5520 laptop, I dropped a screw which sparked and fried a capacitor. Yes, I know I should have disconnecte the battery first Doh!😡. The laptop runs fine, but I want to replace the capacitor asap. I ordered and received the replacement (10uF, 25V 0603). Since I also managed to burn up one of the pads it was soldered to, my main question is whether it is okay to solder this capacitor on top of another capacitor (same size, same function in circuit). Specifically, PC4428 is bad and no way to easily solder to the board. I would like to solder it piggy...
                                            07-06-2025, 11:08 PM
                                          • Bowline
                                            by Bowline
                                            06-11-2025, 10:13 AM
