Viewsonic VX2035WM Turns on for a few seconds then goes black
  • Agent24
    I see dead caps
    • Oct 2007
    • 4981
    • New Zealand
    #41
    Re: Viewsonic VX2035WM Turns on for a few seconds then goes black
    Sounds like a monitor I recapped a while ago...
    22" Widescreen Chimei with dead CapXons, replaced all with Nichicon\Panasonic, works but randomly shuts off.
    Seems to shut off faster the higher the brightness level, and there is a yellow patch in the top-right corner. Someone suggested it was old lamps going faulty and tripping the inverter protection.
    Haven't looked into it further....
    Originally posted by seanc
    Is that picture before-recapping?
    What are the red/brown Panasonics? A new variant of FR?
    No, they are Hermei!! (see post #15) Bastards must be using Panasonic-style vents now....
    -David VanHorn
    • Welchs101
      • Sep 2008
      • 979
      did your monitor work in safe mode?
      • Agent24
        I see dead caps
        • Oct 2007
        • 4981
        • New Zealand
        #43
        Never tried it in safe mode as I didn't expect it would make a difference. It seemed to me to be very much a monitor problem, however I could try it if you wanted.
        -David VanHorn
        • Welchs101
          • Sep 2008
          • 979
          UPdate:
          Finally got it working. Had to uninstall the on-board video drivers and then re-install them. Seems to be working fine now. Note: I did not install the monitor driver from viewsonic. Well, actually i did but it gave me the problem again where monitor should go blank. So i uninstalled that driver and every thing seems to be working.
          • Agent24
            I see dead caps
            • Oct 2007
            • 4981
            • New Zealand
            #45
            I hope that fixes it although I don't really think your problem is the video card\drivers... I think it's the monitor itself.
            -David VanHorn
            • Welchs101
              • Sep 2008
              • 979
              I know what you mean. THis monitor seems kinda flakey i will let you guys know if there are any changes.
              • kaboom
                "Oh, Grouchy!"
                • Jan 2011
                • 2507
                Those bastard Hermeis really piss me off! They depend on the 'bean counters' doing parts spec'ing going "ooh- it's got the T-vent, it must be a good cap."
                I got your solution right here... in fact, I've nailed the problem.
                Welchs, don't kid yourself by pretending that 'software fixes power supplies.' It's possible that the scan format was changed in that INF reinstall, reverting back to 'less demanding' settings. You then squeezed more time out of it before it acted up again.
                -Paul
                "pokemon go... to hell!"
                EOL it...
                All style and no substance.
                guilty,guilty,guilty,guilty!
                guilty of being cheap-made!
                • Welchs101
                  • Sep 2008
                  • 979
                  But i replaced all the caps except one i think...........the only caps i did not replace were those on the logic board.
                  • Agent24
                    I see dead caps
                    • Oct 2007
                    • 4981
                    • New Zealand
                    #49
                    Maybe the ones on the logic board are stuffed too.
                    -David VanHorn
                    • Stephen
                      MacBook Pro 14" M1 Pro Turns on functions then turns off when I plug in USB C cable
                      by Stephen
                      MacBook Pro 14" M1 Pro Turns on functions then turns off when I plug in USB C cable to reset the computer. I disconnect the battery fully and then reconnect it and it won't turn back on. After letting it sit for a day I plug the battery back up, and the MagSafe 3 cable and it powers on and stays ons, once I plug in a USB C cable into the port closes to the MagSafe port it turns off and the Amber light turns off and won't turn on. No water damage, nothing, I want to do a DFU restore to wipe the computer since the customer stated they did an update and ever since it just decided to not work...
                      03-15-2024, 09:37 AM
                    • www
                      LG L192WS-BN backlight turns off after 1 second
                      by www
                      I am testing an old LG L192WS-BN monitor I have that gives an image, but has a backlight issue. When you turn it on the backlight turns on 1 second and it turns off, turns on again, 1 second and it turns off and stays off. Using a flashlight I can see there's still an image.
                      I replaced a bulged cap on the main board, but made no difference. I also got another exact same model monitor that has a broken ccfl (the connector got ripped from the panel and the main screen connector is also broken so I can't use this panel to test), tried using the main board from this one, same issue....
                      03-24-2024, 05:26 PM
                    • zklgfs
                      Anker SoundCore 2 Bluetooth Speaker Turns Off After a Few Seconds (Possibly Firmware Issue?)
                      by zklgfs
                      I have an Anker SoundCore 2 (A3105) that I saved from the trash (well, I guess there's a reason why it was supposed to go into the trash...). The problem is that it always turns off after a few seconds (sometimes it stays on a bit longer, between 30 and 60 seconds, but it still turns off). The power light turns on and the bluetooth light starts blinking, but both abruptly turn off again. The "turn off sound" is still played after the lights turn off. Sometimes, it also loops the on-off cycle several times without me pressing any buttons. If I connect an AUX cable, music...
                      08-11-2025, 02:14 PM
                    • andrhouseolly
                      Dell Precision 5510, AAM00 LA-C361P Rev:2.0 turns on, no image.
                      by andrhouseolly
                      Hi.
                      I kindly ask you to help me solve the problem.
                      Dell Precision 5510, motherboard AAM00 LA-C361P Rev:2.0
                      The board turns on, there is no image.
                      Read more. When the power supply is connected, the front panel indicators light up briefly.
                      When you press the power button, the button indicator lights up. The board works
                      there is no image, there is no matrix initialization, there is no image on HDMI.
                      When turned on, the fans do not spin, but when they warm up they start spinning.
                      When you turn off the button, the fans spin up to full speed for a short...
                      05-11-2024, 03:14 PM
                    • Egidio85
                      Samsung UE55F8000SZ Turns on and off immediately
                      by Egidio85
                      good morning, I have a samsung UE55F8000SZ tv that turns on, shows the logo and turns off after 1-2 seconds.
                      This defect happens continuously, hearing the classic click of the relay every time.
                      Power supply board BN44-00636B
                      disconnecting the mains and lamps from the power board always causes the same problem.
                      Is it normal that without anything connected this power supply turns on and off cyclically?
                      any suggestions on what to check?
                      thanks in advance
                      03-11-2025, 12:45 PM
