Re: Viewsonic VX2035WM Turns on for a few seconds then goes black
Maybe the ones on the logic board are stuffed too.
But i replaced all the caps except one i think...........the only caps i did not replace were those on the logic board.Leave a comment:
I got your solution right here... in fact, I've nailed the problem.
Welchs, don't kid yourself by pretending that 'software fixes power supplies.' It's possible that the scan format was changed in that INF reinstall, reverting back to 'less demanding' settings. You then squeezed more time out of it before it acted up again.
-PaulLast edited by kaboom; 07-23-2011, 08:36 PM.Leave a comment:
I know what you mean. THis monitor seems kinda flakey i will let you guys know if there are any changes.Leave a comment:
I hope that fixes it although I don't really think your problem is the video card\drivers... I think it's the monitor itself.Leave a comment:
UPdate:
Finally got it working. Had to uninstall the on-board video drivers and then re-install them. Seems to be working fine now. Note: I did not install the monitor driver from viewsonic. Well, actually i did but it gave me the problem again where monitor should go blank. So i uninstalled that driver and every thing seems to be working.Leave a comment:
Never tried it in safe mode as I didn't expect it would make a difference. It seemed to me to be very much a monitor problem, however I could try it if you wanted.Leave a comment:
did your monitor work in safe mode?Leave a comment:
Sounds like a monitor I recapped a while ago...
22" Widescreen Chimei with dead CapXons, replaced all with Nichicon\Panasonic, works but randomly shuts off.
Seems to shut off faster the higher the brightness level, and there is a yellow patch in the top-right corner. Someone suggested it was old lamps going faulty and tripping the inverter protection.
Haven't looked into it further....
i checked power save and screen saver options........all seem fine. now just doing google searches........i will keep you guys updated if i find anything out.Leave a comment:
Five minutes could be power save. Check the screen saver or power settings.Leave a comment:
ok. i finally got my neighbors computer to try out the monitor.
Bad news. I set the native resolution to 1680x1050 and made sure the refresh rate is ste to 60hz. After about 5min it shuts off. Really weird. I am now going to boot up in safe mode and see if it works there.......my guess is it will since ALL computers i have booted up in safe mode with works with this monitor...........not sure what to try if it works in safe mode.
i did not replace any of the caps onthe logic board...........think i should have?Leave a comment:
Per your suggestions: I went into the display settings (advanced tab) and changed the monitor refresh rate FROM 75Hz .....TO 60Hz.
This seemed to fix the problem. Monitor does NOT go blank after a few min. But i will keep testing for an entire day and I will try the same thing on my neighbors computer. ONce i have done this if it still works then I will say its truely fixed. I will let you know the out come in a day or so.
THANKS!!!!!!!!!!!!!Leave a comment:
PlainBillLeave a comment:
Make sure the computer is set to the native resolution of the monitor, 1680x1050 at 60 Hz.Leave a comment:
Do you think it could be hardware related like maybe a bad cap on the logic board?Leave a comment:
ok, i have some additional info.
When i boot my computer up in safe mode the monitor stays on .......with no problems. THis seems to suggest to me its a driver or some sort of conflict. But i have no idea what.
Any ideas?Leave a comment:
ok, so things are not totally fixed with this monitor yet.
Here is the strange thing.
I change the OnscreenDisplay from 15min to 60min and this "seems" to fix the problem on computer #1. However, when i gave the monitor back to my neighbor and again changed OSD to 60min............it DID NOT fix the problem. Computer #1 is newer than my neighbors computer and both are running xp-pro.
I am at a loss at this point. I brought my neighbors computer over and have been trying different settings but after about 10min the monitor goes to sleep and i cant seem to wake it up unless i turn on and off and even when i do this it only stays on for about 15 sec.
I foudn the service manual........and i am enclosing it here as well. ok fil eis to larage to post here so i am going to post web address where i found it.
yes, its before recapping. I forgot to take a new picture after i put the new ones in. I replaced all of the caps except the two that i have arrows drawn to .
also, i tried something onthe monitor setttings...........i reset the monitor to its "default" settings and things seem to be working well now. Now when the monitor sleeps the windows xp logo comes up on the screen and moves around the screen. before the screen would just go blank and i would have to turn it off and then back on to get the image to come back..........but it seems to be working fine now.
thanks.Leave a comment:
by StephenMacBook Pro 14" M1 Pro Turns on functions then turns off when I plug in USB C cable to reset the computer. I disconnect the battery fully and then reconnect it and it won't turn back on. After letting it sit for a day I plug the battery back up, and the MagSafe 3 cable and it powers on and stays ons, once I plug in a USB C cable into the port closes to the MagSafe port it turns off and the Amber light turns off and won't turn on. No water damage, nothing, I want to do a DFU restore to wipe the computer since the customer stated they did an update and ever since it just decided to not work...
by wwwI am testing an old LG L192WS-BN monitor I have that gives an image, but has a backlight issue. When you turn it on the backlight turns on 1 second and it turns off, turns on again, 1 second and it turns off and stays off. Using a flashlight I can see there's still an image.
I replaced a bulged cap on the main board, but made no difference. I also got another exact same model monitor that has a broken ccfl (the connector got ripped from the panel and the main screen connector is also broken so I can't use this panel to test), tried using the main board from this one, same issue....-
by zklgfsHi,
I have an Anker SoundCore 2 (A3105) that I saved from the trash (well, I guess there's a reason why it was supposed to go into the trash...). The problem is that it always turns off after a few seconds (sometimes it stays on a bit longer, between 30 and 60 seconds, but it still turns off). The power light turns on and the bluetooth light starts blinking, but both abruptly turn off again. The "turn off sound" is still played after the lights turn off. Sometimes, it also loops the on-off cycle several times without me pressing any buttons. If I connect an AUX cable, music...-
08-11-2025, 02:14 PM -
Hi.
I kindly ask you to help me solve the problem.
Dell Precision 5510, motherboard AAM00 LA-C361P Rev:2.0
The board turns on, there is no image.
Read more. When the power supply is connected, the front panel indicators light up briefly.
When you press the power button, the button indicator lights up. The board works
there is no image, there is no matrix initialization, there is no image on HDMI.
When turned on, the fans do not spin, but when they warm up they start spinning.
When you turn off the button, the fans spin up to full speed for a short... -
by Egidio85good morning, I have a samsung UE55F8000SZ tv that turns on, shows the logo and turns off after 1-2 seconds.
This defect happens continuously, hearing the classic click of the relay every time.
Power supply board BN44-00636B
disconnecting the mains and lamps from the power board always causes the same problem.
Is it normal that without anything connected this power supply turns on and off cyclically?
any suggestions on what to check?
thanks in advance
- Loading...
