Neovo F-419 no power.
+ More Options
Posts
  • playman
    • Jan 2011
    • 252
    #41
    Re: Neovo F-419 no power.
    Shoot!!! That indicates the resistor is good. Check R822, please.
    R822=814 or 814kohm, wich is well with in the 5% tolerance.
    I put it back in and checked a reading between them and got 1491kohm
    Some parts are 'jelly bean' parts - available from multiple companies and interchangeable. For decades the standard resistor used in electronics was a 1/2 watt leaded carbon composition resistor with a 20% tolerance. As electronics moved away from vacuum tubes, current demands dropped, and better materials became available this evolved to the 1/4 watt metal film 5% tolerance leaded resistor. With surface mount, the standard resistor is now a 1/8 watt metal film SMT resistor.
    To answer your question, all of the other components that look like R821 and have an R designation are resistors; the only difference between them would be the resistance. R821 should have the numbers 684 on the top - 68 followed by four zeros, or 680000 ohms, or 680K ohm. I'll let you tell me what a 470 ohm resistor would say.
    PlainBill
    I was going to say HAH you just gave me the answer earlyer, was going to say well ofcourse 470kohm,
    then,
    hey wait a minute what's that 0 there, so i'm guessing it's 0-1-2-3-etc..
    so a 470 would give me 4.7kohm? (man I have no idea how I got that number lol)
    but then as I was not 100% sure so I checked the net and 470 should be 47ohm right?
    Acording to this site http://www.electronicrepairguide.com...stor-code.html
    those SMD's are just like the color resistors except they use numbers instead of color code?
    SMD and SMT are the same?
    • PlainBill
      • Feb 2009
      • 7034
      then,
      You are correct, it's 47 ohm. And SMD and SMT are used interchangeably, although I suppose one is preferred, I just don't know (or care) which.
      This of course doesn't help explain the original problem, so lets see if we can figure out what is going on with the SMPS controller. To that end, I've crudely marked up your picture of the bottom of the power supply, labeling a few points of interest.
      V- is the negative side of the rectified AC, V+ is the positive side. I believe you indicated that was 320 volts. I've also marked the rough boundaries of the hot side of the SMPS in yellow. Lastly, I've numbered the SMPS controller in orange - assuming the lower right corner is pin 1.
      With AC power disconnected and the DMM on the 200 ohm range, what is the resistance between V- and U801, pin 1? Between V- and U801, pin 3? Between V- and U801, pin 6? Between the upper end of R821 and U801, pin 3?
      PlainBill
      Wit
      • playman
        • Jan 2011
        • 252
        #43
        Yes you labeled pin1 correct.
        V- to U801 pin1 =0.9
        V- to U801 pin3 = no read
        V- to U801 pin6 =1.2
        R821 to U801 pin3 = 0.9
        did not get any reading past R821
        Ps.
        Is there any way to make my crapy DMM better?
        • PlainBill
          • Feb 2009
          • 7034
          Ps.
          The resistance readings are what I would expect. Next, let's try voltage measurements. All readings will be made with the black probe on V-. Rather than specify the voltage range to use, set the meter to the 1000 VDC range, then go to the next lower range if the reading is within that range. (For example, you measure the voltage on U801, pin3. It reads about 160 volts, Reduce the range to the 200 VDC range and measure again.)
          Now plug in the power cord and carefully make these measurements.
          V- to U801 pin1
          V- to U801 pin3
          V- to U801 pin6
          The best way to make a crappy DMM better is to sell it and buy a new one. Recently we have had a few cases where the problem was the 'organism' holding the probes.
          PlainBill
          • Rtech
            • Jul 2010
            • 1095
            #45
            PlainBill[/QUOTE]
            Gave me a good start to the day,thanks Bill.
            • playman
              • Jan 2011
              • 252
              #46
              V- to U801 pin1 = 0v
              V- to U801 pin3 = 3.32v on 20VDC
              V- to U801 pin6 = 0v
              I started @ 600VDC and went down to 20VDC
              Used the black probe on V- and Red on U801
              And I laughed
              • PlainBill
                • Feb 2009
                • 7034
                And I laughed
                I'm having a problem getting my head around the readings you have gotten at various times on the V+ to U801 pin 1 path. Still, this looks very much like U801 has failed. I'd say it's time to replace it.
                PlainBill
                • playman
                  • Jan 2011
                  • 252
                  #48
                  That's a shame, it will be interesting how it will go when I try to solder the new one in, there are so small solderings on it lol.
                  It might take some time to get the part.
                  what should I do after I have replaced it? just put it to gather and test the screen?
                  BTW do you know of some good newbie soldering 101 site, i've found some but none that were good enough.
                  • alexanna
                    • Mar 2010
                    • 1346
                    #49
                    Buy some Chip Quik for Digi-Key it makes removing the small IC a snap.
                    When you solder the new part in coat the pads and pins with flux, Then with a fine tip soldering iron melt some solder on the tip, and like you are drawing a line with a pencil start at the solder pad and drag the solder to and on the pins of the IC.
                    • retiredcaps
                      • Apr 2010
                      • 9271
                      #50
                      CuriousInventor has excellent videos
                      http://www.youtube.com/watch?v=3NN7UGWYmBY
                      --- begin sig file ---
                      --- end sig file ---
                      • BobMollie
                        • Mar 2015
                        • 20
                        Is this thread still going. I have a power issue with a Neovo F419 also. The only problem is that my board layout is different the what is being shown here.
                          So show us good clear and focused pictures of your boards to start with.
                          • BobMollie
                            • Mar 2015
                            • 20
                            Here are some pictures of the power supply board and the logic board. The unit does not turn on nor does the LED power light. I do have 167 volts across C805.
                            • BobMollie
                              • Mar 2015
                              • 20
                              I have read the articles. Does anyone have a schematic of this board, or any info on the board?
                                What DCV do you have at the white connector that has the cable going to the Logic board (disconnect the cable to the logic board first)?
                                • BobMollie
                                  • Mar 2015
                                  • 20
                                  I have 0 volts on everything except the Green had 0.017 vdc and the Blu had 0,05 vdc.
                                  • BobMollie
                                    • Mar 2015
                                    • 20
                                    budm are u their?
                                      So it is dead without the logic/main board connected.
                                      You will need to check the rectifier diode D841 mounted on the heatsink and D842 to ake sure they are not shorted. If they are OK, then we need to find out if there are shorted circuit in the inverter section.
                                      I will need good clear pictures of the bottom side of the board.
                                      • BobMollie
                                        • Mar 2015
                                        • 20
                                        Budm, Diodes D841 and D842 test ok. See the foil side of the two circuit boards.
                                        • BobMollie
                                          • Mar 2015
                                          • 20
                                          Budm are you their.
                                          • Caly411
                                            burned mosfet wich has written on top "I6 GUE 8v1507"
                                            by Caly411
                                            Hi, Im having a similar problem with my Acer Nitro 5 AN517 52, took it to repair and they said that the problem was a burned mosfet wich has written on top "I6 GUE 8v1507".
                                            There is written PQB12 on the motherboard right next to it.
                                            Does anyone know if there is soemthing similar I can buy to replace it with?
                                            Seems impossible to find theidentical mosfet online.
                                            08-30-2023, 10:48 AM
                                          • cacko85
                                            Asus R520U wich type od ssd ??
                                            by cacko85
                                            Hello folks
                                            Laptop Asus R520U problem with instaling ssd drive, laptop come with 2.5" hdd drive, but there is slot for ssd (M.2 I think) I put SAMSUNG 500GB SSD 980 Pro M.2 PCI-E NVMe, but can't be recognized in bios or windows
                                            I don't have any other type of ssd to try, maybe the bus is sata3 not pci-e ??
                                            Any info ?? tnx...
                                            08-13-2021, 03:07 AM
                                          • Malcolma172
                                            Philips 42pfl6008s/12 red led comes on for a second and then goes away but 3.49v stay active
                                            by Malcolma172
                                            I was trying to repair my tv wich previously had a blinking red led 2 times and it kept going. After shorting the sdm the blinking led changed 5 slow blinks and 3 fast ones wich in the service manual meant error 53 / the fusion chip.
                                            After I heated the fusion chip with a hairdryer for 5 minutes it started working perfectly but after a day it stopped this time no led blinks even in sdm mode.
                                            After probing the psu I have 3.49v and for 1 second I have at least 2 12.3v lines active the fusion chip gets warm in that second the led turns on and then the 12v lines start losing power...
                                            07-23-2025, 01:20 PM
                                          • ladharimohamed2
                                            Need bios toshiba satellite pro r50-b-15j
                                            by ladharimohamed2
                                            I need bios for toshiba satellite pro r50-b-15j motherboard faebsy2
                                            i have tried this :
                                            but no power
                                            and i tried this
                                            the laptop worked but asked for a password
                                            i have tried many with same motherboard name wich is FAEBSY2 A5A003954010 A but the laptop didnt turn on (no lights, no fan spinning)
                                            i have attached my original bios wich has been corrupted after a windows update (turn on but black screen)
                                            if any have the bios for the exact model name will be great "toshiba satellite pro r50-b-15j"...
                                            04-18-2024, 07:54 AM
                                          • Larchemont
                                            HP Elitebook 840 G1 BIOS Issues
                                            by Larchemont
                                            Hello Folks,
                                            i have a HP Elitebook 840 G1 with a locked BIOS and i have bought a CH341a (black PCB). My problem is that the Bios Chip reads 25Q128A 13ECO and i cannot find a profile for this chip in any of the software recommended in the guide threat in this forum. The chip cannot be detected wich i dont find too surprising, but i can read the chip with random other profiles selected.
                                            I have found a post in this forum in wich the user stated he was able to flash this exact chip with the CH341a and the testclip, but unfortunately this user is no longer active. In...
                                            08-21-2022, 07:24 AM
