HP Elitebook 840 G1 BIOS Issues
  • Larchemont
    • Aug 2022
    Hello Folks,
    i have a HP Elitebook 840 G1 with a locked BIOS and i have bought a CH341a (black PCB). My problem is that the Bios Chip reads 25Q128A 13ECO and i cannot find a profile for this chip in any of the software recommended in the guide threat in this forum. The chip cannot be detected wich i dont find too surprising, but i can read the chip with random other profiles selected.
    I have found a post in this forum in wich the user stated he was able to flash this exact chip with the CH341a and the testclip, but unfortunately this user is no longer active. In his post he states that this chip is 3volt and that he was successful with asprogrammer, wich gives me hope this is possible.
    Heres the post:
    https://www.badcaps.net/forum/showpo...&postcount=103
    So to my Question. What would be a smart way to read the correct bios dump, can i just use a similar profile?
    best regards
  • peste
    • 13924
    • ROMANIA
    Re: HP Elitebook 840 G1 BIOS Issues
    Originally posted by Larchemont
    Hello Folks,
    Heres the post:
    best regards
    yes..try a similar profile...but remove the bios chip from the motherboard before reading the bios chip
    https://www.youtube.com/watch?v=DWWigscuQDY
    • DynaxSC
      ASRock B650M PRO RS - BIOS CHIP 25Q256JW BLOCKED BY STATUS REGISTERS
      by DynaxSC
      Hi
      I have then desoldered the chip, backupped the contents, and tried to earease the chip in order to program stock image, but the chip is locked by status registers SREG2 (TB) and SREG6...
      08-04-2025, 12:20 PM
      Common SPI bios chip programming Questions and Answers
      by SMDFlea
      Q: I have a bios request,i can`t post my backup as i can`t read from the chip.
      A: If you can`t read from it how do you expect to write to it ?.
      Q: Why is my bios chip unreadable ?.
      A: The programmer is faulty or has a worn or broken zif socket.
      The USB cable is frayed,connector pins worn or some other physical damage.
      Not enough amperage or voltage to power the programmer properly.
      Bad...
      09-02-2021, 04:40 PM
    • JoWed
      Problems with reflashing BIOS Chip on omen by hp laptop 17 an104ng
      by JoWed
      Hello Community,
      I recently tried to change the Batterie on my Omen by HP Laptop 17 an104ng and after putting in the new batterie ([Batterie Link](https://www.amazon.de/7xinbox-17-AN0...&keywords=16%2...
      07-01-2025, 09:32 AM
    • Azurain
      Elitebook 840 G5 Bios Chip Soldering Question
      by Azurain
      I have an HP Elitebook 840 G5 that I am trying to get working again. I've removed the front bios chip (the 32mb one) and have run it through HP unlocker already. I've uploaded and verified the new bin, but am now experiencing an issue that has led me to believe I've been soldering the chip back to the motherboard incorrectly.
      Essentially, after re-soldering the chip back into its place and reassembling the laptop, the charging light immediately flashes orange and white and then shifts to a solid white. The capslock and numlock lights blink seven times...
      04-14-2023, 06:58 PM
    • thxd43
      Lenovo laptop does not turn on, what does this number mean in a BIOS chip?
      by thxd43
      Hello, first of all, excuse me, I am using the translator, English is not my native language.
      I have a Lenovo ideapad 330S - 14IKB laptop.
      The tablet did not recognize me when I connected it, so I checked the device manager and I realized that there were many with the exclamation mark, so one by one I began to update their drivers until the sign disappeared of admiration, I even updated the BIOS, and the laptop rebooted normally and worked, so far so good, but the tablet still did not recognize me, I read on the internet that it could be due to a...
      02-23-2023, 08:37 PM
