LG 1953 Dead
  • smason
    • 1652
    LG 1953 Dead
    Got a nice 19" LG 1953 from work, just died one day.
    I figured this would be an easy recap, but looks like it might be a challenge.
    That's ok, it's the only repair on my pile other than the iMac iSight PS, and I'm due for a challenging monitor.
    Serious bloatage on the Samxon GFs. I replace all but a 33uf 50v that I don't have stock of, but it measures ok compared to a couple of the 1000 uf 25v that were like 2uf and 50ohms ESR
    I test it, still dead.
    The dual mosfets 4511GD http://html.alldatasheet.com/html-pd.../AP4511GD.html look like they've been running just a tad warm. Will check them for shorts, and test some voltages tomorrow.
  • Scenic
    o.O
    • Sep 2007
    • 2642
    Re: LG 1953 Dead
    you can replace the 33uF 50V with a 47uF 25/35/50V, as it's on 12V. (i've checked the max. supply voltage of the SMPS controller IC. maximum was 20V IIRC)
    the PSU/Inverterboard looks identical to the LG L1952HQ that i recapped a while ago (thread is on here somewhere, including service manual)
    damn those mosfets are toasty
    i bet this thing was running at full brightness its whole life..
    also check TH1 (below the primary cap legs).. these are supposed to be dark green.. yours is pretty much black..
    http://bambooz.pytalhost.net/badcaps...u-inverter.jpg
    edit: my old thread https://www.badcaps.net/forum/showthread.php?t=10078
    • smason
      • 1652
      Re: LG 1953 Dead
      I was considering a 47uf but wasn't sure how critical it was, until I look a bit closer and figure out what the cap is being used for.
      Thanks for the link to the service manual. Love the engrish, and how they tell you to dissassemble:
      1. Pull the front cover upward.
      2. Then, let the all latches are separated.
      3. Put the front face down.
      It's just that easy. Just let all the latches are separated, then all your base are belong to us
      Not sure what the heck the PWM controller is in mine it's labelled:
      LAF0001
      VH14
      Haven't found it online yet. Wonder if it's close to the Fairchild in the parts list.
      • smason
        • 1652
        Re: LG 1953 Dead
        Update:
        U303 - both FETs are shorted, measured out of circuit definitely toast
        U304 - not shorted, can't test in circuit too well, will replace both. IF I can find them...
        • Th3_uN1Qu3
          Believe in
          • Jul 2010
          • 6031
          • Romania
          Re: LG 1953 Dead
          Had a similar one in last year - fortunately the MOSFETs were still good but the burn marks on the board were about as obvious as yours. They received some heatsinks after replacing the caps.
          A working TV? How boring!
          • retiredcaps
            • Apr 2010
            • 9271
            Re: LG 1953 Dead
            These ones?
            http://search.digikey.com/scripts/Dk...=4511%20mosfet
            --- begin sig file ---
            --- end sig file ---
            • smason
              • 1652
              Re: LG 1953 Dead
              I'm considering those, I could make them work, but they're surface mount, mine are old style thru-hole 8 pin dips.
              • sofTest
                • Aug 2008
                • 361
                Re: LG 1953 Dead
                LG seem to use this MOSFET on many of the 19xx-series monitors. I recaped one a couple of years ago, and it's still going strong, after donating it to my brother. LittleDiode in the UK seem to be able to ship the MOSFET. You have to enquire for the price, though.
                Is the 33uF at C103? If so, be sure to replace it also, as it has been known to create trouble.
                Be a mensch
                • smason
                  • 1652
                  Re: LG 1953 Dead
                  Thanks, have emailed them.
                  • smason
                    • 1652
                    Re: LG 1953 Dead
                    LittleDiode has stock, £6.99 seems a bit steep. I ordered a couple, will be here in about a month the way my luck with shipping is these days...
                    • smason
                      • 1652
                      Re: LG 1953 Dead
                      Well they just shipped them today. That's service!
                      I probably should have grafted in a surface mount device, or just slapped in some plain 'ol FETs. Oh well, do it right or don't do it at all, right?
                      • smason
                        • 1652
                        Re: LG 1953 Dead
                        Got the parts today. Replaced both, and fired it up. Works fine.
                        While cycling through the "picure modes" any of the dimmer looking modes produced an arcing sound.
                        Subbing in my known good CCFL assy. it's one of the top lamps, or wiring to them. Actually I'm guessing wiring, as the light looks pretty even.
                        Maybe I'll take it to work and disassemble the panel. Too hairy and dusty at home.
                        • Behemot
                          • 4845
                          • CZ
                          Re: LG 1953 Dead
                          I got just the LG 1953T power board from guy to repair. From what I have discovered so far, at least one Saxon GF is bulged (nothing spectacular), but also the ZD101 zener diode near power transistor seems shorted. Tester reads 0 over diode and 3 over resistor nearby. This baby needs replacement I guess.
                          Both APM4546 dual FETs seem fine, no short or strangely low readings. It is not darkened arround, these seem better than the 4511GD.
                          EDIT// unsoldered zener and it reads fine. There must be short somewhere because now both sides would be on ground.
                          EDIT2// it is fine I guess, resistor reads 0 but is actually 0,56 ohms so thats it
                          • double_DD
                            How can I be sure that my EC chip is dead?
                            by double_DD
                            As the title suggests, how can I be sure that my EC chip is really dead?
                            I've recently gotten into this hobby of laptop repairs, and have successfully brought back to life a couple with some easy fixes, mostly shorted caps.
                            Now I'm working on HP Probook 455 G8, that had some "devil" run around on 3V line, burning a bunch of stuff. Luckily I have a dead 455G7 (for spare parts) so I managed to fix it (swapped burned parts) to a point that it will charge (both on barrel jack and usb-c), but it doesn't want to turn on. There is a 3V3 on a keyboard...
                            03-12-2025, 07:47 AM
                          • disorder
                            ps5 edm-033 dead after hdmi/usb ports destroyed
                            by disorder
                            hello guys,
                            i need help to repair a edm-033 ps2
                            history : as always hdmi port and usb ports destroyed after unplugged
                            after change them, ps5 dead too : 1 beep, no blue light. after inspection 1.8v power was shorted, and because of dead panasonic chip. after remove it : no short anymore
                            so i changed it
                            now i have got 5v stby,, 3.3v stby, 3.3v power, 1.8v power and no short on them
                            but the ps5 is dead again : 1 beep, near 10 seconds with power lines and then off, no blue light ...
                            i don't see any projection of liquid metal on pcb.
                            01-14-2025, 12:48 PM
                          • zunasthegreat
                            Chieftec GPS-450-AA with dead 20N60C3
                            by zunasthegreat
                            Hello everyone hope all doing well!
                            I have this PSU (GPS450-AA delta oem) around for like 4-5 years and I had it recapped early 2020 or 2021 with mostly UCC KY and Nichicon PW's. The bulk was and still is fine, the original Ltec's were bloated and empty. The previous issue was some major coil whine noise and at times random shutdowns when going idle. Today it started tripping the mains breaker and I think I have dead APFC mosfets (20N60C3). Right now upon checking I have the Q1 and Q3 FETs dead so far and I guess those are responsible for the PFC circuit. The only thing I care is If there...
                            09-01-2024, 07:12 PM
                          • Beton
                            Finding a dead short component
                            by Beton
                            Hi guys!
                            I searched for the term "dead short" in the forum but no specific thread came up however if I'm just blind and couldn't see the thread talking about this please forward me to that direction.
                            So my problem is I don't know how to find the source of a dead shorted voltage rail. Dead short = ~0 ohm resistance.
                            I have two VGAs (HD 4850 and HD 4870), both dead shorted to ground on the memory rail. I have the boardview file for the 4870 and the memory rail consists around ~7892346 capacitors...
                            I have a bench PSU and if I try to inject voltage the voltage...
                            12-10-2021, 01:05 PM
                          • FiguringITout
                            MSI Raider GE75 - Not posting, probable dead CPU
                            by FiguringITout
                            Hello, today I'm working on this lovely MSI Raider GE75 gaming laptop which I bought to flip. Unfortunately, I believe the CPU is toast but I wanted a second opinion before I chucked it into my spare parts bin. I will not have most tools with me today as I'm away from my workbench but I have the basics (a good multimeter, a horrible iron, a solid screwdriver, and my trusty thermal cam). I do not have the original 230w charger, but I have a Dell 180w which was sold with the device and reportedly "worked fine for them".
                            Specs: I7-10750H, RTX 2060, 32GB RAM (unknown manufacturer)...
                            07-25-2024, 07:27 AM
