Dell E172FPb
  • ratdude747
    Black Sheep
    • Nov 2008
    • 17136
    Dell E172FPb
    my first lcd to fix...
    symptoms: powers on normally for 1 sec, then no picture. green power light stays on. a quick power cycle make it work for another second.
    no VISIBLY bad caps.. but a mix of lelons and elite make me wonder.
    no odd noises that i remember
    any advice other than a recap? places to check?
    edit- slight heat browning in one of the 2 cfcl inverter areas. seems centered around a transformer, diode, and PI coil (i think) area. It also has little jamicon caps.
    sigpic
    (Insert witty quote here)
  • retiredcaps
    • Apr 2010
    • 9271
    Re: Dell E172FPb
    "2 seconds to black" can be
    1) bad caps
    2) bad ccfls or bad wiring
    3) bad inverter transformer
    4) bad inverter sense circuitry
    1, 2, and 3 are documented at starting with post 13 and 14.
    https://www.badcaps.net/forum/showthread.php?t=10419
    Pictures always help since it possible that Dell used a different power board and kept the same model number.
    --- begin sig file ---
    --- end sig file ---
    • retiredcaps
      • Apr 2010
      • 9271
      Re: Dell E172FPb
      I forgot to add that these Benq style boards have really poor soldering on the inverter transformers. You must resolder all the inverter transformer pins.
      • alexanna
        • Mar 2010
        • 1346
        Re: Dell E172FPb
        Something I have learned on these monitors. And I am assuming there are 4 inverter transformers?
        The symptoms you describe sounds like a shorted or open transistor for on one of the inverter transformers.
        Unplug all the CCFLs and then plug one back in at a time [only have one CCFL plugged in at a time], power on the monitor, do you see a flash of light with each CCFL?I really suspect 2 of the transformers will not light the CCFL,Check the transistors associated with that transformer for a shorted or open condition.
        And as is recommended resolder the transformers.
        • smason
          • 1652
          Re: Dell E172FPb
          Hey, who let Rat in here?
          Welcome to the wonderful world of LCD repair.
          Definitely check for shorted transistors, transformer soldering, resistance (if you have a ring tester, use it) and
          probably re-cap if the transformers are ok.
          • ratdude747
            Black Sheep
            • Nov 2008
            • 17136
            Re: Dell E172FPb
            resoldered all the transformers... the soldering looked shoddy...
            i put it back together most of the way and tesed it. no lamps, blocks on screen, blinking green power light.
            I opened it up again and found a solder bridge on one of the CFCL transformers. I fixed that and verified that it was the only bridge (that was on two normally disconnected pins). still gives me the same symptoms...
            any advice still? i hope i did not blow something... no smoke, noises, or smells.
            sigpic
            • retiredcaps
              • Apr 2010
              • 9271
              Re: Dell E172FPb
              any advice still?
              Post some pics so we can suggest test points. There could be multiple revisions of the power board inside a Dell.
              • hoadle
                • Jul 2010
                • 174
                Re: Dell E172FPb
                Here the website for you Dell E172FPb
                http://syscon.wordpress.com/2007/07/...klight-repair/
                go to ebay buy the repair kit
                http://cgi.ebay.com/REPAIR-KIT-E172F...item3355ff735c
                • ratdude747
                  Black Sheep
                  • Nov 2008
                  • 17136
                  Re: Dell E172FPb
                  I don't do ebay repair kits. too many scams.
                  my camera died so no pics for now... I think i will start with a recap.
                  sigpic
                  • ratdude747
                    Black Sheep
                    • Nov 2008
                    • 17136
                    Re: Dell E172FPb
                    first faiure found
                    one of the 4 inveter area transistors is shorted out. the other 3 pass fine. i tested them out of circuit.
                    the part no. is c5707.
                    i had a sanyo 2SC4106 in my junk bin. popped it in, success.
                    I DONE FIXED IT!!!
                    i will run it a while to see if it holds.
                    sigpic
                    • ratdude747
                      Black Sheep
                      • Nov 2008
                      • 17136
                      Re: Dell E172FPb
                      spoke too soon.
                      it is now a case of 20sec to black... what now? caps?
                      sigpic
                      • seanc
                        • Nov 2008
                        • 1319
                        Re: Dell E172FPb
                        Change all the 2SC5707 after having double checked the transformer soldering and other solder joints.
                        Transformers, 2SC5707 and a pico fuse is all that's *usually* needed in these.
                        • ratdude747
                          Black Sheep
                          • Nov 2008
                          • 17136
                          Re: Dell E172FPb
                          the trannies already have been resoldered and checked.
                          3 of the 5707's were tested good. one was replaced.
                          sigpic
                          • alexanna
                            • Mar 2010
                            • 1346
                            Re: Dell E172FPb
                            Did you see if the transistors that you installed have not failed again? You do not have to remove from circuit.
                            Something I don't see mentioned often on these monitors. Is to check and or re solder, the gray poly capacitors that sit right between the C5707 transistors. I have notice on more than one occasion loosens on the solder pads.
                            • alexanna
                              • Mar 2010
                              • 1346
                              Re: Dell E172FPb
                              I don’t know for sure but these transistors may need to be replaced in pairs.
                              • PlainBill
                                • Feb 2009
                                • 7034
                                Re: Dell E172FPb
                                Originally posted by alexanna
                                I don't know for sure but these transistors may need to be replaced in pairs.
                                Considering the application, they should ALWAYS be replaced in pairs, and with the proper part numbers.
                                PlainBill
                                • ratdude747
                                  Black Sheep
                                  • Nov 2008
                                  • 17136
                                  Re: Dell E172FPb
                                  PlainBill
                                  i think you are right. I feel stupid as all this time later, my failure to do things the right way may be why it still is dead.
                                  I still have the unit in my possession and I tried it again.
                                  it is good for maybe 10 sec before the backlights go out. after the test i smelled burning electronics near the transistors.
                                  the 1 transistor that fried and i swapped for the larger transistor is a c5707. is it recommended that i replace all 4 with the exact same transistor or is there a compatible one that is less prone to failure? it seems they fail a lot and I would rather not have to replace them all the time (it belongs to a buddy who had it in his closet).
                                  I thought that as long as I had the pnp/npn part good and it was the same or bigger all would be ok. i guess that and the fact I only replaced one may be why it still goes 10 sec to black?
                                  sigpic
                                  • PlainBill
                                    • Feb 2009
                                    • 7034
                                    Re: Dell E172FPb
                                    This design uses a circuit called a Royer Oscillator. It requires two transistors with similar characteristics. With some care, it would be possible to select suitable transistors, but pulling some NPN transistor out of the drawer isn't going to cut it.
                                    The root problem is not the transistors, it's the crappy solder job on the transformers.
                                    PlainBill
                                    • ratdude747
                                      Black Sheep
                                      • Nov 2008
                                      • 17136
                                      Re: Dell E172FPb
                                      i resoldered the transformers already. as in desoldering the transformer, removing it, and soldering it back in. the new solder should have fixed that.
                                      sigpic
                                      • PlainBill
                                        • Feb 2009
                                        • 7034
                                        Re: Dell E172FPb
                                        Yes, now they won't cause the transistors to fail. However, you must still have suitable transistors or the oscillator won't start.
                                        My point was 'better' transistors aren't necessary, the originals are quite adequate. It's the poor job of soldering that is doing the damage.
                                        PlainBill
                                        • Bowline
                                          by Bowline
                                          06-11-2025, 10:13 AM
                                        • Akhlz001
                                          by Akhlz001
                                          09-20-2025, 07:15 PM
                                        • master3112
                                          by master3112
                                          07-29-2025, 01:55 PM
                                          Dell Thunderbolt Firmware
                                          by SMDFlea
                                          Dell thunderbolt firmware, extracted from dell firmware update exe. Padded to 1MB.
                                          Some models have a choice of 2 different firmwares, it depends on the dell SKU.
                                          The SKU is in brackets (****)
                                          EDIT: NVM65...
                                          01-26-2025, 06:22 AM
                                        • F R 2568
                                          Dell Latitude 5420 does not start (no post) need help to find the reason why
                                          by F R 2568
                                          Hello all,
                                          this is my first post, so if I make mistakes please do not hesitate to point them out, thank you in advance.
                                          I got a Dell Latitude 5420 (Service Tag: 7RFM6D3, Motherboard: GDF40 LA-491P Rev.: 2.0 (A01)) which does not start and I want to repair it. These are the symptoms:
                                          If the laptop is only connected to the AC adapter (battery removed):
                                          When I press the power button, the keyboard backlight and the display backlight are turning on. Caps key light is lightning, but key does not respond to pressing it.
                                          The power/battery...
                                          01-08-2025, 05:45 AM
