Dell E172FPb
  • ratdude747
    Black Sheep
    • Nov 2008
    • 17136
    Re: Dell E172FPb
    i found the for sure problem
    my "replacement" transistor's ground plate thing is discolored... that tramsistor toasted itself.
    sounds like i need to buy the right transistors.
    this look ok:
    a LONG url
    I can't find that transistor or the other one in the kit anywhere else...
    i never checked the fuse but it looks as if I better get a multimeter (my old one is in somebody else's possession right now). does the fuse in the kit look ok (same specs other than the voltage, the stock one is 250v, this one is 125)?
    sigpic
    (Insert witty quote here)
    • PlainBill
      • Feb 2009
      • 7034
      Re: Dell E172FPb
      this look ok:
      a LONG url
      Wow!!! Lots of things to cover. As you have discovered, the best source of the transistors is on eBay. If you examine the board, you will see each transformer has it's own pair of C5707 transistors and FU9024N transistor. Definitely replace both C5707s for this transformer, and I would urge you to replace the FU9024N also, it took a current surge. It shouldn't be necessary to replace the other set if they aren't shorted. And unless the fuse is open, there is no point in replacing that.
      By the way, the voltage rating of a fuse is the voltage it can interrupt. This circuit handles 12 volts, so either a 250V or 125V fuse is more than adequate.
      PlainBill
      • ratdude747
        Black Sheep
        • Nov 2008
        • 17136
        Re: Dell E172FPb
        PlainBill
        the kit was cheap enough as it is; at $5 a kit, since this is only one unit I am servicing, the cost is negligible. without my trusty multimeter I am kinda helpless to test things...
        I will order the kit and see what i can do.
        sigpic
        • ratdude747
          Black Sheep
          • Nov 2008
          • 17136
          Re: Dell E172FPb
          the kit came in today.
          I didn't fuss with the fuse. otherwise, I replaced all 6 transistors.
          it works again.. knock on wood.
          lesson: with transistors, replace like with like.
          i guess that makes my first LCD job a success?
          edit- video quality isn't too shabby. my friend will be happy that he gets his monitor back in working condition
          sigpic
          • ratdude747
            Black Sheep
            • Nov 2008
            • 17136
            Re: Dell E172FPb
            still running well... no issues.
            sigpic
            • flacox2
              • Aug 2011
              #26
              Re: Dell E172FPb
              este tipo de monitores siempre se le queman esos transistores npn, la solucion mejor es cambiarselos todos, los transistores de monitores de 15 puden servir, los que son 5706 funcionan perfecto, ya los he probado
              • ratdude747
                Black Sheep
                • Nov 2008
                • 17136
                Re: Dell E172FPb
                in english?
                sigpic
                • Bowline
                  by Bowline
                  06-11-2025, 10:13 AM
                • Akhlz001
                  by Akhlz001
                  09-20-2025, 07:15 PM
                • master3112
                  by master3112
                  07-29-2025, 01:55 PM
                  Dell Thunderbolt Firmware
                  by SMDFlea
                  Dell thunderbolt firmware, extracted from dell firmware update exe. Padded to 1MB.
                  Some models have a choice of 2 different firmwares, it depends on the dell SKU.
                  The SKU is in brackets (****)
                  EDIT: NVM65...
                  01-26-2025, 06:22 AM
                • F R 2568
                  Dell Latitude 5420 does not start (no post) need help to find the reason why
                  by F R 2568
                  Hello all,
                  this is my first post, so if I make mistakes please do not hesitate to point them out, thank you in advance.
                  I got a Dell Latitude 5420 (Service Tag: 7RFM6D3, Motherboard: GDF40 LA-491P Rev.: 2.0 (A01)) which does not start and I want to repair it. These are the symptoms:
                  If the laptop is only connected to the AC adapter (battery removed):
                  When I press the power button, the keyboard backlight and the display backlight are turning on. Caps key light is lightning, but key does not respond to pressing it.
                  The power/battery...
                  01-08-2025, 05:45 AM
