Acer AL1916W LCD Monitor Power Problem
  • incradibles
    • Feb 2011
    • 43
    I got Acer al1916w LCD monitor when i give supply only yellow color light up and nothing. back light off no logo is coming only yellow power light is on.
    Silence Like Dreams
  • alexanna
    • Mar 2010
    • 1346
    Re: Acer AL1916W LCD Monitor Power Problem
    Acer monitors are notorious for using several different power supplies.
    There is no way anyone can make suggestions without seeing yours.
    Please include some photos of top and bottom of all boards, using the managed attachments feature you will have to resize to a maximum of 2000x2000 pixels Try to get as clear and detailed photo as you can.
    • EGuevarae
      • Nov 2008
      • 1336
      I agree. Most likely a 700G(900G in this case) style PSU/Inverter board on the inside. Most of the time there are cap problems only.Follow Alexanna's suggestion (and PlainBill's instructions) and post pics of your boards.
      • ASUS ROG Maximus IX Code
      • Intel Core i5-7600K 3.8GHz
      • Windows 10 Pro x64
      • GeForce GT1050
      • incradibles
        • Feb 2011
        • 43
        Hi here are the pics of power and graphics card boards from back and frond side.
        Silence Like Dreams
        • EGuevarae
          • Nov 2008
          • 1336
          Never seen this one before!
          • GeForce GT1050
          • jsog
            • Feb 2011
            • 220
            U106 looks weird on pins 1 and 4, and there's a black blob above it.
            • retiredcaps
              • Apr 2010
              • 9271
              1) If you hookup a working computer to the Acer displaying your favourite wallpaper, can you see it if you shine a flashlight on the lcd?
              2) Check the voltage regulators on the logic board. They are U101 and U102.
              3) When you press the on/off button, what is the voltage on pin 4 on the connector between the power and logic board? Does it change when you presse the on/off button?
              --- begin sig file ---
              --- end sig file ---
              • PlainBill
                • Feb 2009
                • 7034
                Red herring. U106 contains the firmware. The mark the ICs with colored paint to identify what firmware is on them.
                PlainBill
                • eurestereyes
                  • Jan 2011
                  I have the same power board and I am having a hard time getting the schematic for it, I was hoping that you would be kind enough to send the part number information that is stamped on top of IC802.
                  • mashburn
                    • Dec 2008
                    i have the same monitor and same problem...
                    orange led only, when plug to the outlet its stays orange light.
                    i cant turn on and off even i press the power button.
                    • Destroyer-Br
                      [HELP] Acer AN515-55 (LA-J871P Rev: 1B) – Board won't power on after GPU investigation – Suspecting Super I/O or PCH
                      by Destroyer-Br
                      I'm working on an Acer Nitro 5 unit with the following specs:
                      • Motherboard: LA-J871P Rev: 1B
                      • Model: Acer AN515-55-59MT
                      • S/N: NHQ7JAL00403906A973400
                      • SNID: 03902728734
                      Initial Issue
                      The laptop initially presented graphic issues and driver failure (Code 43) for the GPU.
                      After preventive maintenance (cleaning, thermal paste, etc.), it powered on normally. We disassembled it again to inspect the GPU, reassembled...
                      04-17-2025, 08:18 PM
                    • usbdevice
                      Acer X223HQ (Version Bbd) on/off-power-cycling
                      by usbdevice
                      Hi all
                      There's two other threads about this monitor with seemingly the same problem. The problem was resolved in one case by replacing the entire PSU board and in the second one by replacing an unknown IC.
                      https://www.badcaps.net/forum/showthread.php?t=50657
                      https://www.badcaps.net/forum/showthread.php?t=40512
                      The first one has pictures of the pcbs and I noticed that there's one IC and assorted caps not populated on mine (but the PCB itself looks identical) so I thought that'd warrant a new thread.
                      It's my dad's old monitor. He...
                      08-05-2022, 02:21 AM
                    • theone111
                      by theone111
                      3. Problem: TV shuts down
                      07-22-2024, 10:36 AM
                    • Duranitron
                      Asus x512dk rev 2.1 power on problem
                      by Duranitron
                      When I reflash again the bios of hoaca388 the unit powers on and the unit lives!!! Hooray!! All voltage in the coil 3.3v, 5v and 6.7v indicate charging are all present. including the cpu voltage , EEPROM and GPU voltage the unit is now alive, normal screen booting to windows and log in screen until I power it off. Then the unit never goes on even when pressing the power button in the keyboard.. Voltage reading 19v main , 3.3v VCC in IT8225E-128 and EEPROM VCC 0 volt and the charging voltage 0 volt.
                      Try to trace the power switch button goin to the power switch IC PU8803 (APL3533AQBI-TRG)...
                      11-26-2024, 10:22 PM
                    • Bonaventure Vigil
                      ACER ASPIRE A515-52G CAN ON BUT NO DISPLAY, NO POWER AT VCC_GT
                      by Bonaventure Vigil
                      Dear All,
                      Please really2 need Help on this Acer A515-52G Motherboard Compal EH5AW LA-G521P Rev: 1A.
                      At first this laptop can on, keyboard light on but no display. Open the motherboard, found out the PQZ3 Mosfet and PUZ3 ic near it burn. Refer picture below. Then I replaced both. All the power rail 3.3,5,1.2, 1.35, 0.8V have power back after i turn on the laptop except for the VCC_GT rail. Voltage at Power Supply showing 0.000A before turn on, after turn on it became 0.5 0.6A. Seem cannot boot and still no display. Then I replaced the PUG1 and mosfet, but the VCC_GT still no power....
                      12-12-2024, 10:22 AM
