Philips PHP x19
  • sabre504
    • May 2010
    • 449
    • United Kingdom
    Philips PHP x19
    HI all have a philips php x19 wide screen that i am working on.
    Came to me with a lovely pink screen so changed the ccfls thats all ok now ,
    but still had a shut down problem the usual 2 sec to black power led solid blue .
    Changed all the caps for Rubycon yxg and noticed scorching to the board just behind the transformers (pic 1 ).
    Still has 2 sec to black and suspect that these may be at fault (pic 2 )
    but i cant find a spec sheet for these as the only markigs are 3055 at the top and 6G bottom right hand corner but no manufacturer name .
    Has anyone dealt with these before or have any idea what i can use to replace them .
    Also there is no buzzing or hissing noises coming from the transformers but will check them when new meter comes (broke my analogue one by treading on it ) only have my digital that does not have x1 resistance scale.
    Any suggestions welcome
  • sabre504
    • May 2010
    • 449
    • United Kingdom
    Re: Philips PHP x19
    Sorry forgot to mark picture 2
    • jetadm123
      • 2169
      Re: Philips PHP x19
      It's a N-channel mosfet made by several manufacturers. For info purposes only, go to digikey.com and type in "3055 mosfet" in the search window. You'll get several manufacturers. Match one of those manufacturer's part number to what's avaliable to you in the UK.
      • Rtech
        • Jul 2010
        • 1095
        Re: Philips PHP x19
        Try PHD3055E
        • sabre504
          • May 2010
          • 449
          • United Kingdom
          Re: Philips PHP x19
          Thanks guys not having much luck tho
          Will have to search for some other alternatives
          • jetadm123
            • 2169
            Re: Philips PHP x19
            You can go on ebay and search for 3055 mosfet. Some of the sellers will ship to the UK. A possible substitute is IRLR014N, 55V, 10A, 140 mOhm
            • seanc
              • Nov 2008
              • 1319
              Re: Philips PHP x19
              Where did you source your CCFLs from?
              I was trying fix one where the wire had become disconnected, instead I managed to crack the end of the tube just where the wire connects - to a little pin that's inside the CCFL and it has come out.
              I can put it back in, but I don't think it'll work.
              • jetadm123
                • 2169
                Re: Philips PHP x19
                In the States, some members recommend ccflwarehouse.com. Don't know if they ship to the UK.
                • retiredcaps
                  • Apr 2010
                  • 9271
                  Re: Philips PHP x19
                  Their ebay account might ship worldwide?
                  http://stores.ebay.com/plazmo-industries
                  --- begin sig file ---
                  --- end sig file ---
                  • seanc
                    • Nov 2008
                    • 1319
                    Re: Philips PHP x19
                    Indeed their website says international shipping is $12.95 which is ~£8.00.
                    I'll take measurements tomorrow.
                    • sabre504
                      • May 2010
                      • 449
                      • United Kingdom
                      Re: Philips PHP x19
                      I had some spare ones on another unit that had a cracked screen
                      what ones are you after ( what model monitor )
                      • seanc
                        • Nov 2008
                        • 1319
                        Re: Philips PHP x19
                        2009 20" LG widescreen monitor. I've forgotten the model, will check tomorrow.
                        • sabre504
                          • May 2010
                          • 449
                          • United Kingdom
                          Re: Philips PHP x19
                          Oh sorry mate only got 19" wide screen but your welcome to try them
                          i tend to keep back panels from cracked screens for future use as some units are a mare to take the bulbs from its easier to swap the lcd overlay as long as its a match
                          Also there is this company Uk based
                          backlightweb.co.uk
                          • triumph
                            • Oct 2010
                            Re: Philips PHP x19
                            Hi Sabre504. Personally, I would have put Panasonic caps in as they are top quality. Also if they were, for example, rated at 25v, put in 35v caps. Always go for 105 degree caps too. A higher voltage cap wont cause any damage, a higher capacitance will. Also using overrated components will help long term reliability. But your panel looks like it was getting well hot!!! This can be partially relieved with a computer fan blowing cool air up the back of the monitor or drawing hot air out. ANY air movement is helpful . Hope this helps.
                            • sabre504
                              • May 2010
                              • 449
                              • United Kingdom
                              Re: Philips PHP x19
                              The caps i used are what i have but am replacing slowly with pannys when i need stock .
                              The mosfets arrived and have fitted them and is working ok now just waiting for some new lamps and all done , thanks all for your input
                              • smason
                                • 1652
                                Re: Philips PHP x19
                                Have you measured the resistance of the inverter transformers?
                                I'd measure each one, and compare. Of my last 4 "2 seconds to black" monitors, 1 was caps, 1 was a bad ccfl, and 2 were bad transformers.
                                • sabre504
                                  • May 2010
                                  • 449
                                  • United Kingdom
                                  Re: Philips PHP x19
                                  I am replacing the lamps with newer ones because i have found some new complete sets ready made quite cheap.
                                  But have had another of these come in red screen (lamps) and a buzzing transformer.
                                  I bought extra mosfets on the last one so i will test transformers and change all caps,lamps and mosfets and if it still buzzes i will get some new transformers
                                  • sabre504
                                    • May 2010
                                    • 449
                                    • United Kingdom
                                    Re: Philips PHP x19
                                    Well looks like the new lamps have finished the first one nicely ,
                                    brightness down on 22 and contrast down to 40 .
                                    Thanks for all the input and advice
                                      Acer Extensa EX2540-3055 + Pack Gold 15.6'' Notebook 15 Specification for Upgrade or Repair
                                      This specification for the Acer Extensa EX2540-3055 + Pack Gold 15.6'' Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the EX2540-3055 + Pack Gold 15.6'' boardview and EX2540-3055 + Pack Gold 15.6'' schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties...
                                      09-06-2024, 06:06 AM
                                    • G33RT
                                      Philips 8200 series 65PUS8204/12 stuck at Philips Logo
                                      by G33RT
                                      Philips 8200 series 65PUS8204/12 stuck at Philips Logo, it does not reboot it just stays on the logo.
                                      It does power up when pressing the power button.
                                      I already try the power button while plugin the plug with no result.
                                      Also put the latest firmware autorun-TPM191E_R.001.004.100.000.upg on a MBR/FAT32 USB stick at USB port2 with no result either.
                                      Could this be an PSU or eMMC issue ?
                                      07-19-2025, 03:43 AM
                                    • janos6662000
                                      Philips 47PFS7509/12 LCD TV problem
                                      by janos6662000
                                      Hi
                                      I have here a Philips 47PFS7509/12 LCD TV which came to me with a weird problem : without signal i could access menu, make a factory reset, access menus, etc.
                                      When i applied cable signal to check image, i had normal picture, but TV was restarting.
                                      I downloaded original firmware and applied the update, but the problem remained.
                                      From a colleague i received a "factory package software" which is a lot bigger.
                                      I made another firmware update, but still did not solve the problem.
                                      Somewhere on the way the error got worse, because at the moment the...
                                      08-12-2025, 12:54 PM
                                    • aidanmo
                                      Philips 43PUS7506/12 - Loud blown out sound
                                      by aidanmo
                                      I've got a really strange issue with the speakers on my Philips 43PUS7506/12. It makes this awful loud buzzing now. It happened after it was attempted to be wall mounted - I think the back got squeezed and something broke.
                                      I thought maybe the speakers got damaged, so I replaced them - no dice.
                                      • Using the internal speakers, it always happens.
                                      • Using the headphone jack, it never happens.
                                      • Using the digital/optical out with a soundbar - it happens after about 2h/movie runtime - it's never as drastic, it just pops in and out, but I didn't want it to damage the sound bar
                                      02-28-2025, 03:13 PM
                                    • Cornito
                                      Philips 50PUH6400 bad color and gosting / slow motion on one side
                                      by Cornito
                                      Hello Team,
                                      New issue on LCD panel where I need to find out the cause and the potential solution.
                                      This is on the Philips 50PUH6400, the LCD panel is an INNOLUX V500dk2 xrs1.
                                      I have image, on the right side, the image is more or less normal even if there is a small blur on edge, on the left there is an issue.
                                      When moving up and down in the menu on the right the image is slow to disappear, and is darker, like red/brown.
                                      I've checked voltages, no issue found comparing right and left side of the panel driver.
                                      VHG VGL CKV... are the sames on...
                                      03-08-2024, 06:41 AM
