HP LP1965 - Power light green, no image
  • badandy
    • Nov 2010
    • 25
    Hello all, new to the forums here.
    I have a HP LP1965 that has no image.
    When you press the power button the green light turns on.
    The backlights turn on as well. There is no image at all.
    I have pulled the power supply and video boards and all of the
    caps look good. They are a mixture of suscon's and capxons.
    ( i know c823 on the PS looks like its bulging on the top but
    its flat)
    Should I just go ahead and replace them or is there another
    direction that I should take.
    Thanks,
    Andy
  • jetadm123
    • 2169
    Re: HP LP1965 - Power light green, no image
    Is the screen just plain white? If yes, it could be a blown fuse on the LCD control board.
    • retiredcaps
      • Apr 2010
      • 9271
      I agree with jetadm123.
      --- begin sig file ---
      --- end sig file ---
      • badandy
        • Nov 2010
        • 25
        By white do you mean that it would be the same as a normal functioning monitor displaying white fullscreen?
        OR
        Do you mean white as in the backlights bleeding thru the monitor?
        • jetadm123
          • 2169
          Normal functioning monitor displaying white fullscreen.
          • badandy
            • Nov 2010
            • 25
            Its completely dark, if you press the menu button nothing happens. If you press the input button, the backlights turn off for a second or two and then turn back on.
            • jetadm123
              • 2169
              Usually, there's a 5V and 12V output from the power supply. The 12V drives the inverter/backlight section and the 5V drives the logic card and LCD panel. Sounds like the 12V is good, since you're getting backlight.
              Looks like you'll have to piece everything back together to take voltage readings. Measure for the 5V at the wiring harness of the power supply (hopefully, the voltages are silkscreened on the board. Look on top and bottom of board).
              In your photo, I circled what I think are voltage regulators. What are the part numbers?
              • Rtech
                • Jul 2010
                • 1095
                ""Its completely dark, if you press the menu button nothing happens. If you press the input button, the backlights turn off for a second or two and then turn back on"".
                I am still slightly confused !! from your statement above if the Screen is Dark, then are the Backlights really on ????.....only time the screen is dark normally is if there is NO backlights on ??/
                • badandy
                  • Nov 2010
                  • 25
                  I have powered it on outside the case and I can see that the backlights are on.
                  It looks like when you have your screensaver set to blank the screen but not power off the monitor.
                  • mockingbird
                    • Dec 2008
                    • 5484
                    Change the capacitors. All of them. If the primary capacitor is Capxon, keep it. If it's a Suscon, toss it and replace it too.
                    • badandy
                      • Nov 2010
                      • 25
                      Mockingbird, do you want me to change caps on both video and power supply boards?
                      • badandy
                        • Nov 2010
                        • 25
                        Sorry for the delay getting back to you guys, XMAS has been busy.
                        I tested 3-5 volt legs for voltage, yellow-orange-red are 5v legs, they tested at 5.24 volts each.
                        the part numbers for the regulators are as follows, according to your picture top to bottom
                        AIC1185 top
                        33 PM
                        274IB
                        1187 middle
                        -18PE
                        948D2
                        1185-33PY bottom
                        775IB
                        • mockingbird
                          • Dec 2008
                          • 5484
                          Yes, the video board too. Especially the larger ones. Be careful not to rip out the pads. It's somewhat difficult with the logic board and the tiny caps. If your soldering skills aren't that great, then just replace the larger ones on the logic board.
                          • jetadm123
                            • 2169
                            AIC1185 top
                            33 PM
                            274IB
                            1187
                            -18PE
                            948D2
                            1185-33PY bottom
                            775IB
                            Can you please take a voltage reading for each leg of the above devices?
                            • badandy
                              • Nov 2010
                              • 25
                              I took the following readings in circuit assuming that you are looking
                              directly at the IC with the legs facing down. Backlights were not connected lcd was not connected to video board.
                              for AIC1185 33 PM 274IB
                              left leg & center - 5.23vdc
                              right leg & center - 3.29vdc
                              for 1187 -18PE 948D2
                              left leg & center - 3.28vdc
                              right leg & center - 1.802vdc
                              for 1185-33PY 775IB
                              left leg & center - 5.22vdc
                                master hoarder
                                • May 2008
                                • 12175
                                • Bulgaria
                                for 1185-33PY 775IB
                                The first and third ICs (1185-33) are 3.3v linear regulators (as indicated by the "33" in the name). The second IC is a 1.8v regulator, so the reading you got for all 3 are good.
                                The problem could also be on the panel board (the one permanently attached to the LCD screen), most likely with one of the boosted voltage rails. If possible, post a few pictures of the panel board. The areas of particular interest are near the LVDS connector and around the inductor/coil.
                                • jetadm123
                                  • 2169
                                  There appears to be 4 fuses, F301-304 on the logic board. Please check them for continuity. I've marked them on the photo.
                                  • badandy
                                    • Nov 2010
                                    • 25
                                    Here is a pic of the panel board.
                                      master hoarder
                                      • May 2008
                                      • 12175
                                      • Bulgaria
                                      Check the 4 fuses that jetadm123 circled. If they are good, check fuse F5 on the panel board and also measure voltage between ground and the test point labeled "AVDD1". Should be around 10~13v I think. Post back what results you get.
                                      • badandy
                                        • Nov 2010
                                        • 25
                                        All 4 have continuity.
                                        • techrepairheide
                                          MacBook Pro (A1502 / 820-3476-A) - No orange/green light and no power
                                          by techrepairheide
                                          Hello again,
                                          got an MacBook Pro from 2015, model A1502 and motherboard version 820-3476-A.
                                          Device died over night on charger.
                                          Currently I did the follow things:
                                          1. Checked visuell the board, test with another MagSafe-Charger and with another DC-IN-board too
                                          2. Measured 16,5V on ​PP18V5_DCIN_FUSE but 0V on ADAPTER_SENSE and 0V on PP_3V42_G3H and 0V on PPBUS_G3H but 16,5V goes to U7090
                                          3. Because of corrosion and bad resistor values I changed these components: U7090 / C7094 / C7095 / R7095 / R7096 / L7095 / C7099 -> But further...
                                          01-26-2025, 05:37 AM
                                        • ipatch
                                          troubleshooting microsoft surface pro 4 no power no led charge light
                                          by ipatch
                                          hello, �� i have been sitting on some microsoft surface pro 4 tablets for a while now. i was originally tasked with replacing the battery in one of the tablets, and ended breaking the screen and logic board in the process. decided to buy another tablet with the same specs. got that screen off successfully of the second tablet. the logic board appeared good, but i guess i shorted something out in the installation process of the logic which i've read is a common issue if there is no barrier between the logic board and battery pins. all that said, i ate costs of the repair and have...
                                          10-05-2023, 11:59 AM
                                        • russpall
                                          LG 39ln540v - red light flashes twice, no power to LED driver?
                                          by russpall
                                          Hi there,
                                          I've got a 39" LG 39LN540V that's just spontaneously stopped working! The symptoms are - when I plug it in, the red light will flash on twice, then go out, there's no visible picture, and I couldn't see anything using a torch on the panel either. If I press the power button (either remote or on TV), the red light comes on continuously. If I press power again, the red light flashes twice.
                                          The TV is using a power board EAX64905301. I've attached a diagram of the power output, I've tested the voltages with a multimeter and I'm getting the following:
                                          08-27-2024, 01:07 PM
                                        • joeoffice12
                                          MacBook Air (2017, A1466, No power/orange-green light on)
                                          by joeoffice12
                                          I have a 13 inch MacBook Air 2017 that does not show any life, however, there is activity from the MagSafe light going from green to orange and staying. Normally, this battery works perfectly fine and it can actually charge the battery as if I were to leave it alone it would change to just green, however, this thing does not boot up at all, I was told the computer was at 30% and then it randomly shut off.
                                          Some voltages:
                                          PPBUS_G3H - 8.5V
                                          SMC_PM_G2_EN - 3.42V
                                          PP3V3_S5 - 3.32V
                                          PP3V42_G3H - 3.42V
                                          PPDCIN_G3H - 15.18V
                                          PP5V_S5 - 5.04V
                                          PP3V3_S5_REG_R...
                                          12-15-2023, 04:00 PM
                                        • lcdcaps1
                                          820-2610-A Sys onewire help, no green light. Please help from the gurus
                                          by lcdcaps1
                                          Hi
                                          I have an 820-2610-A motherboard that has no green light.
                                          I have noticed is when I do a SMC reset the light on the Magsafe blinks.
                                          From My understanding, the sys onewire circuit is responsible for the green light on the magsafe
                                          The sys onewire circuit on this model and others is more involved
                                          I was hoping if anyone knows about this and how it works, can reply and let me know
                                          I know this is an old model but I am sure there are people who still works on these or knows about them
                                          I get 1.1v on the C7771 capacitor and will replace...
                                          11-06-2023, 01:28 PM
