MacBook Air (2017, A1466, No power/orange-green light on)
  • joeoffice12
    • Dec 2023
    • united states
    I have a 13 inch MacBook Air 2017 that does not show any life, however, there is activity from the MagSafe light going from green to orange and staying. Normally, this battery works perfectly fine and it can actually charge the battery as if I were to leave it alone it would change to just green, however, this thing does not boot up at all, I was told the computer was at 30% and then it randomly shut off.
    Some voltages:
    PPBUS_G3H - 8.5V
    SMC_PM_G2_EN - 3.42V
    PP3V3_S5 - 3.32V
    PP3V42_G3H - 3.42V
    PPDCIN_G3H - 15.18V
    PP5V_S5 - 5.04V
    PP3V3_S5_REG_R - 3.32V
    PP3V3_S5_AVREF_SMC - 3.30V
    SMC_RESET_L - 3.11V
    SMC_ONOFF_L - 3.39V
    PM_SLP_S4_L - 0v
    SMC_S4_WAKESRC_EN - 0v
    nothing looks out of the ordinary that might be burning or blown. Everything looks perfectly fine besides those 0v discoveries I made, please leave any suggestions!!
    This is when using the official OEM 45 W MagSafe 2 charger.
  • reformatt
    • Feb 2020
    • 1398
    Test board on the bench with only LIO board connected with no battery. Board should auto-start when magsafe is connected. From what you've got above, you are getting to S5 state. PM_SLP_S4 needs to go high to advance.
    So with these boards, you first need to establish whether you aren't getting PM_SLP_S4 at all, or whether you're getting it pulse high once or twice when power is first connected. If you get nothing, then you need to go through the PM_SLP_S4 pre-requisites. If it's pulsing once or twice that is another matter.
    Use the power sequence for PM_SLP_S4.
    https://logi.wiki/index.php/G3_to_S3..._and_Broadwell
    • joeoffice12
      • Dec 2023
      • united states
      Board doesn’t start at all that’s the thing, even if it’s just stripped completely with the IO only being connected it does nothing.
      i saw mentions of that checking for pulse but I’m still not too fully aware of that, could you let me know of more detailed steps, I’m still kinda new to this so bare with me haha.
      thanks for your reply, looking forward to your response.
      • reformatt
        • Feb 2020
        • 1398
        Pulse simply means that it changes state from 0 to it's nominal voltage briefly. Most multimeters won't react fast enough to show the nominal voltage however, what you're looking for is some change in voltage from 0, hence 'pulse'. To see what level the signal or rail gets to, you need an oscilloscope.
        If you are getting no activity on PM_SLP_S4_L, then you look at your pre-requisites. This page has a good write up.
        https://www.it-tech.com.au/mac-q-a/pm-slp-s4-l-timing/
        A common fault of these boards will have all power rails up to CPU Vcore pulse twice, then return to S5 state. Need to eliminate if this is the case as it's not fixable outside of reballing or replacing the CPU.
        • kevingill
          • Jun 2013
          • 152
          • England
          Is there any corrosion on the board especially around the clock circuitry?
          • joeoffice12
            • Dec 2023
            • united states
            I’ll definitely try that out, I did notice just the slightest bit of corrosion but it wasn’t really near any chips, I didn’t notice much of anything really.
            • jheunne
              A1466 macbook no boot green to orange light help
              by jheunne
              i have macbook a1466 board id 820-00165 with power fan spin green to orange light not booting no image or light i tried to fix its leak chip number U1930 but sad it has been damage due of corrosion here i attach the image of board. possible there is a jumper ways for it can't find parts for it to buy.
              in first image there is 0v out for lcd
              https://ibb.co/5XppmpkH
              in 2nd image U1930 chip is damage is there any jumper solution or parts can be compatible for it
              https://ibb.co/fdJkbJs8
              06-10-2025, 10:52 PM
            • sherifu
              Macbook Air A1466 Emc 3178 No light charger after spilling liquid
              by sherifu
              Hello guys, i have an Macbook Air A1466 Emc 3178, board number 820-00165-A and i encountered following problems. At first no light, no power..after opening and cleaning the LCD socket(Red dot under LCD plug and also Orange dot near wifi card)..got light on charger, fan working and chime...Tried several times and working, then short time after dead...next day work again for short time...after removing the board and cleaning the back(rust on components) with alcohol and soft brush, one of the resistor is gone and no power ..I want to change 5 (buy from China) of them (1 missing and 4 bot looking...
              03-26-2024, 04:54 PM
            • ACS-Repair
              MacBook Air A1466 2017 Operating Very Slow
              by ACS-Repair
              I'm hoping someone can help me with a 2017 MacBook Air A1466 820-00165 that is running very slow. This is a board that I picked up on ebay recently.
              This is not being caused by a sensor issue. All sensors report normal operation and the fans run at normal speed. Geekbench gives me a single core CPU value of 124, when it should be closer to 400. I was unable to complete an install on the SSD without putting it into a different computer first.
              The board appears clean with no sign of liquid damage. I have done a PRAM and SMC reset, and I have done a reflow of the SMC. I have inspected...
              08-18-2023, 02:30 PM
            • sircastor
              Macbook Air A1466 No light on charger
              by sircastor
              I have a MacBook Air 2015 (820-00165-02) that had some liquid damage. It was working for a while only on Adapter power, but that stopped working. Thunderbolt (external display) did not work. There was a bit of corrosion on the board, and I've cleaned that up. The adapter light does not turn on when I plug it in.
              PP3v42_G3H: 3.42V
              PPBUS_G3H: 0V
              PPDCIN_G3H: 16.4V
              PPDCIN_G3H_INRUSH: 0V
              A lot of this is new to me, but following the schematic, I think that Q7180 is not producing the PPDCIN_G3H_INRUSH voltage, which in turn drives...
              02-20-2024, 02:42 PM
            • sofles
              Macbook a1707 2017 model 820-00928 GPU issue
              by sofles
              Hello there
              I have problem with Macbook Pro 15" 2017, model 2017, MB code 820-00928.
              I bought it as broken with some artefacts on the screen, first I thought that this is problem with ribbon cable but after inspectiing ribbon cable I know it is fine. I tried to reinstall macOs and then I figured out that this must be something with GPU as installation freezes at the end (when drivers are loaded). I installed Windows and was able to install every each of drivers except GPU driver, as soon as I tried to install GPU driver - black screen and restart.
              11-21-2024, 05:25 AM
