LCD Monitor w/ Vertical Lines
  • Ritalin
    • Sep 2010
    • 194
    So I've done some searching online to see if anyone has an idea of what this issue is and for the most part I've seen that it's a "T-Con" board going bad, but yet again, no definite answer... I have 2 LCD monitors that are doing this... First one is a Dell SP2208WFPt and the second is a Soyo Topaz S series...
    Basically what is happening is that I'm getting faded vertical lines all across the monitors like a certain color pixel is stuck on, the Dell has a white color while the Soyo seems to have a red'ish color. (Did a color test and only notice it on certain colors)
    I picked both of these monitors up for free and they were not working at, so I got them to at least turn on... Now it's just the vertical line issue....
    Any thoughts?
    (Pictures to come once I put them back together)
  • Wrog
    • Oct 2009
    • 472
    Re: LCD Monitor w/ Vertical Lines
    Usually vertical lines are a sign of a bad panel. Are they grouped, random or follow a set pattern (every X pixels)? A reddish tint could be attributed to a failing CCFL bulb. Also, LCD monitors usually don't have a "T-Con" (Timing Control) board, these are found in LCD TV sets.
    • kbrletic
      • Nov 2010
      • 9
      • Croatia
      If when you press the upper part of the LCD panel lines respond (usually disappear), then you have a defective display. Repair is not possible.
      • Ritalin
        • Sep 2010
        • 194
        So finals are over and my fiance's sister's wedding is over, so back to 'projects'.
        Here is what the monitor looks like turn on. Sadly I'm thinking it's a bad panel
        • Rtech
          • Jul 2010
          • 1095
          The picture suggests the panel is shot, and no repair.I have seen Screens with total whitish fading colouring etc, and they can sometimes be down to Badcaps(particularly with Proview),or a badly fitting connector between Logic and Screen Board.
          • jetadm123
            • 2169
            I agree with Rtech. The welds between the LCD control board ribbon cable and the LCD panel are starting to fail. No fix for this.
            • Laurent
              • Jan 2017
              • Taïwan
              I had the same problem with a ASUS screen.
              It was a bad connection on the panel. I fixed it with a little plastic to press on the place the connection was not good and now it is working well.
              • Davi.p
                Hobbist
                • Sep 2009
                • 4258
                • Italy - Milan
                Check also caps, i think in these cases there's something bad at elettrical level, the connection get damaged.
                Debug Information
