Benq fp531 monitor q5t3
  • rkawa
    Richard
    • Nov 2010
    • 10
    hi all! Greetings!
    1 .- I do not ON, nor led stanby.
    Check in tl1451acn ic751
    no voltage pin 5
    pin 10 is 14 volts ...
    any information on this
    I would appreciate each other, help
  • LCDCAPS
    • Sep 2009
    • 3
    Re: Benq fp531 monitor q5t3
    I just got the same lcd with the same problem, I see nothing bad on the board so I expect its something with the ic chip or the fets. Please reply if you have found the problem because I dont want to throw out a nice lcd screen.
    • smason
      • 1652
      If you search this forum you'll find some info on this model.
      It's famous for blowing the pico fuse, due to shorted transistors, usually caused by bad solder joints on the transformers.
      • cpp
        • 9
        try change and re-program the 24c04 (not sure the same model) on the logic board.
        I have one benq fp537 with same problems, now repaired.
        you can search the "firmware" for the 24c04 on internet or any member of this forum.Or, try this:
        http://dump.elektroda.pl
          by momaka
          03-15-2023, 10:17 PM
        • keepread
          Dell monitor PSU vs Dell laptop PSU
          by keepread
          Hi there!
          Someone gave me their old monitor, it's Dell S2715ht.
          The owner was using it when his PSU began to smell and then to smoke. It literally began to melt. He turned the monitor off, pulled the PSU, and ditched it because it was smelly even after it cooled. So I got the monitor but not the plug.
          Now, I tried to bring the monitor back to life, by plugging one of my many Dell laptop PSUs. They are of the same 19.5V, and the wattage of the laptop PSU is higher than that which the monitor is rated for. Visually, the socket on the monitor seems compatible, and the plug plugs...
          10-30-2025, 04:45 PM
        • bembeno
          Benq T902DHA monitor turns off after 5 minutes
          by bembeno
          Benq T902DHA monitor when press power button its work good but turns off after 5 minutes ( power led off ) just when i plug any display source
          07-27-2024, 09:55 AM
        • wattage
          AOC AG493UCX 49-inch monitor - Firmware request
          by wattage
          Hello Badcaps Community,
          The problem is that it will not display a picture on any of its inputs. And the on-screen menu does not appear. The power button works properly. It powers on with the remote as well. But the on-screen menu does not appear, even when not connected to any...
          07-13-2025, 04:41 PM
        • ant3202
          HP 27es - LED monitor - Monitor Flashing On - Off
          by ant3202
          Hi Everyone
          Lately I am experiencing the deja-vu incident on one of the led monitor like this.
          https://www.badcaps.net/forum/troubl...lashing-on-off
          The monitor is HP 27es LED Monitor
          https://h30434.www3.hp.com/t5/Deskto...e/td-p/6804692
          The monitor will randomly blackout and display no signal and will recover again.
          Sometimes need to power and off again to restore the display but...
          03-20-2025, 07:30 PM
