How hot does it get in there?
  • mathog
    • Mar 2010
    • 2655
    As I'm sure this forum's readers are painfully aware the typical LCD display puts all of its electronics inside what is essentially a narrow rectangular metal box with just a few holes on the top or back for ventilation. There is no fan, the only cooling is from convection, and from conduction through the box itself to the back of the display. This heat source lives within a narrow plastic case which itself tends to have only narrow slits for ventilation, and again, no active cooling. The back and top of an LCD display case tends to be warm to the touch, but not uncomfortably so, maybe around 110F.
    Have any of you ever measured the temperature inside the inner metal box?
    How hot was it?
    Electrolytics do not like heat...
  • PlainBill
    • Feb 2009
    • 7034
    Re: How hot does it get in there?
    That is an interesting question, and one which I had never checked. I'm using a 23" KDS wide screen monitor. The ventilation isn't very good in the area it sits. I just took a few measurements. Since this IS a scientific study, I will report the temperatures in Celsius.
    My glass of ice water reads 0°C
    The room temperature according to a thermometer about 3' away is 30°C
    That same thermometer reports the outside temperature is 36°C
    The air on the desktop is 30°C
    The air above the case is 36°C.
    The temperature just inside the top of the case is 35°C
    With the probe contacting the shield around the electronics I read 44°C
    Now I have to get a fresh glass of water.
    For those Americans who still think in °F, the formula is (°C x 9/5) + 32 = °F
    PlainBill
    • mathog
      • Mar 2010
      • 2655
      Thanks for checking.
      That gives us a lower limit for the temperature under the shield. I'm going to guess that the average air temperature inside is probably close to that, but a few spots could be a lot warmer. For instance, on the Viewsonic VX922 which is sitting open next to my desk at the moment on the PS board there is an L shaped heat sink with 3 pin voltage regulators (or power transistors?) bolted to it. This forms a sort of metal tunnel 2cm x 2cm x 7cm with the metal shield and the circuit board. Those active components are bolted to the inside of this tunnel, along with most of the (bloated) capacitors. There are holes in the shield right above it, but the total area of those holes is at most 1 square cm., so ventilation is pretty minimal.
      • smason
        • 1652
        Dude. My opinion of you (which was already very high) just went up a bunch more points.
        I saw a map the other day which showed countries who haven't gone metric in red.
        The U.S. and 2 tiny little specs somwhere else were the only red.
        • PlainBill
          • Feb 2009
          • 7034
          What can I say? There was a concerted push to switch to metric in the 70's. Manufacturing concerns were opposed because 'it would result in the US being flooded by cheaply made foreign products.'
          Of course, since then they have been rushing to shut down their factories in the USA and switch production to foreign companies. Anything to obsolete old products and make a bigger profit. Now they are wondering why nobody can afford to buy their products.
          PlainBill
            master hoarder
            • May 2008
            • 12175
            How hot was it?
            Never measured it, but I did perform a highly-scientific finger test on the heatsinks of a few LCDs . I think most run a lot hotter than 40C - probably closer to 50-60C. If the PCB has discoloration, I wouldn't be surprised if things got up to 70 or 80C, maybe even 90C. Sure would be nice if I actually had a thermometer to confirm this, though.
            A few months ago I fixed a Daewoo L700C monitor for a friend of mine. Now that monitor is HOT! Literally.
            Just within 5 minutes of use, the heatsinks were already unbearably hot. And after 10 minutes... no way you can even touch them without burning yourself. PCB underneath was discolored, of course. Then again, that's what you get for using linear regulators for pretty much all the rails.
            And then if you think that's bad, the PSU board for this monitor has the caps right under the heatsinks (oh, and the caps were rated for 85C). They were Samxon GS, which are supposed to be blue in color - but half of mine were almost completely black due to heat damage.
            If there's a hell for caps, this monitor has to be it.
            • boomer400
              • Jan 2011
              • 12
              Has anyone ever bothered to mount a small 12vdc cpu style fan in a chassis? where would you even put the power connections? I suppose it's easier for most people to just use a desktop fan and point it at the back of the monitor.
              • Th3_uN1Qu3
                Believe in
                • Jul 2010
                • 6031
                All monitors have a 12v rail so if you really want to it's a no-brainer.
                A working TV? How boring!
                • showmemule
                  • Jan 2011
                  • 16
                  Yup had a 52 inch plasma I repaired bad caps go figure, but one thing I notice was the lack of heat dissapation parts. Soooo I installed a 4 inch computor fan in the back. 12 volt choices are pretty good in other monitors, and t.v's as well. Iam sure its money 1. They dont want the extra cost in the unit, and 2.they want it to burn up early, so as to get you to help them rotate there retail inventory, by buying another. Only problem you fix it instead.
                  • BarrelRoll
                    • Jan 2011
                    • 34
                    Interesting. I was working on a 50" SONY Plasma (Actually a Pioneer) and it had 5 fans in it, all with rotation sensors in case a fan stopped which would kill power to the set. The 42" SONY Plasmas (actually LG) didn't have anything IIRC.
                    • Flaku_34
                      Acer Nitro XV273 and Predator XB273, look inside and disassembly guide.
                      by Flaku_34
                      Introduction:
                      Hello everyone, this topic is more of a knowledge sharing and look inside type of post, but for someone working on this model of display it might be useful. Recently I bought Acer Nitro XV273 XB MIIPRZX with busted electronic, but screen was intact, price was incredibly low, so I took a gamble and bought the unit and try to fix it. As I dug inside, I found out that my motherboard was not responding, although all voltages seemed fine. I wasn't able to find any reliable information about this monitor on the web (only some pictures of motherboards from Ebay). By some research...
                      04-18-2024, 12:47 PM
                    • CapLeaker
                      AcuRite 5 in 1 temperature sensor replacement repair
                      by CapLeaker
                      Got a new victim:
                      AcuRite 5 in 1 Iris outdoor weather station not updating the temperature / humidity anymore. The original sensor is a SHT21. Also there are identical other sensor manufacturers. I chose the HTU21D to replace the original SHT21. Both have identical specs. I've had two failure modes with these sensors.
                      A: outside temp stuck at -40? It's cold here at times in Canada, but not that cold!
                      B: stuck at some temperature and maybe updating once in 12 hrs or so.
                      Easy solution is to go to AcuRite website and purchase the sensor. Right?...
                      04-15-2025, 01:32 PM
                    • asdas09
                      Temperature to remove chips from motherboard
                      by asdas09
                      What temperature with the heat gun should be use to remove large and small chips from the laptop and mobilephones motherboard? My problem is that the chips not easily remove from the motherboard, example 380°C degrees. I don't know if there is a difference with the devices that the temperature is not stable with them even it shows the right temperature, what should it be? I don't know if I should use higher temperature but the risk of destroying other components?
                      I have device Sugon 202. I'm used also normal flux and rosin flux.
                      09-12-2023, 12:44 AM
                    • Dreigas
                      ISL95880HRTZ desoldering temperature
                      by Dreigas
                      I bought from China ISL95880HRTZ (3+1+1 Voltage Regulator with Expanded ICCMAX Register Range Supporting IMVP8 CFL/CNL CPUs) chip, which I think is not the original one, but anyway, I tried to resoldering it with a 380C hot air station. Seems soldering is pretty good, but the laptop doesn't work (it worked before, but still had some problems with power delivery).
                      Is there any big chance, that they sent me two fake ISL95880HRTZ chips or did I just use too big temperature for desoldering? I will try with another chip, but I can't find any info about the maximum desoldering...
                      09-13-2024, 10:59 PM
                    • jm1234
                      9V relay temperature 40C
                      by jm1234
                      Hi, I'm seeing one 9V relay having temperature 40C on its 9V (primary) side. Does that seem right? I switched 2 relays on that board and the temperature was the same (on the same position), so I'm sure it's not a faulty relay. I measured voltage on that relay and it was 9.5V DC, so that looks good. I don't see any other relay on that board having that kind of temperature and they have 9V on them too.
                      I thought maybe the transistor that is switching this relay keeps switching on/off, so I also checked for AC and there was almost none: 0.3V using mV range. No steady frequency was shown, but...
                      05-09-2024, 03:03 AM
