Hanns-G HG281D, LCD Monitor no power
  • fightforlife
    • Mar 2015
    • 11
    Re: Hanns-G HG281D, LCD Monitor no power
    Hey Guys,
    i just found this Thread via Google. I read some of the pager here and hope you can help me with my HG281D.
    Today after updating and restarting my computer it just stopped recognizing any inputs.
    Ive tested 2 Computers over HDMI and 1 over VGA. It seems to recognize when a connection is made, because it shows the green box "No signal....". But after that it doesnt show any picture and just goes back to sleep.
    I never had any problem wit this monitor before!
    Did somebody here have this problem before, or knows which parts/boards i have to check?
    Thanks in advance!
      "Did somebody here have this problem before, or knows which parts/boards i have to check?" The power supply board and the logic board. more likely they need to be recapped.
        master hoarder
        • May 2008
        • 12168
        #743
        ^ What budm said.
        Usually C80 and C83 are the caps that fail most often on the logic board. They are known to cause all sorts of issues when this happens.
        You can find more info and some useful links I collected from other people in the second half of my post here:
        https://www.badcaps.net/forum/showpo...&postcount=604
        • fightforlife
          • Mar 2015
          • 11
          Originally posted by rspendl
          The other two did turn on and +5VSB was stable, but did not get the signal (displayed "no signal" message). Replacing capacitors C61 and C69 on the main board (100 uF / 16 V next to a regulator) fixed them. Just a hint for other people looking for a quick fix and not wanting to spend more than a dollar for spare parts :-)
          Thanks guys,
          Ive just read through all posts here and came to the one above with exactly the same problem. I will change all of the caps and hope for the best!
          • fightforlife
            • Mar 2015
            • 11
            So, i just changed all the Caps on the Mainboard (not the Powerboard) and the monitor is still giving me the "no signal" message.
            Any ideas?
            Should i replace the caps on the Powerboard?
            • fightforlife
              • Mar 2015
              • 11
              Changed all Caps on the powerboard.
              Problem persists.
              • fightforlife
                • Mar 2015
                • 11
                I hope somebody is still reading this
                Problem: Always get "no signal" message when connecting or disconnecting hdmi.
                I already changed all the caps on both boards.
                Here are some high resolution pics:
                1
                2
                3
                4
                • Lumberjack777
                  • Dec 2010
                  • 464
                  #748
                  You could check the 2 voltage regulators on the top left (in your picture 3)
                  Here's a good video explaining it - https://www.youtube.com/watch?v=cNFzBJELFoU
                  • fightforlife
                    • Mar 2015
                    • 11
                    Hey, thank you for your suggestion!
                    i just measured the two voltage regulators. But nothin seems off to me...
                    The bigger one has an input of 5.1V and an output of 3.3V.
                    The smaller one has an input of 3.3V and an output of 1.8V.
                    All voltages are stable when connecting something on HDMI or pressing on/off.
                    Edit: PS_On (the black cable between power and main) measures 0.02V when amber led and 2.84V when display on.... somewhere in this thread was said that it had to be over 3V?!
                    Edit 2: It seems the powerboard is working fine. For the short time the display is on, the 24V/12V and 5V are stable.
                      "PS_On (the black cable between power and main) measures 0.02V when amber led and 2.84V when display on.... somewhere in this thread was said that it had to be over 3V?!" >2.5 = ON, <1V = OFF.
                      At this point it seems to me that the logic board is not sensing the Video signals (you have already verified that the PC and the cable are OK), you will have to use the scope to find out if the Video and sync signals get all the way to the processor or not and to do that you will need the diagram also.
                      • fightforlife
                        • Mar 2015
                        • 11
                        Yeah, i checked the cable and laptop on another monitor. There they are working fine.
                        Thank you very much. I think verifiyng the videosignals and processor is something i cant do with my limited electrical supply and knowledge.
                        I will wait another week if someone has another idea. After that its going into the trash if no one is interested.
                        perhaps i should mention that this problem did start after rebooting the pc.
                        • _BtB_
                          • Mar 2015
                          Hello, have a question about this monitor.
                          When it is turned on, the blue light would come on but it would take a long time for the picture to show. I guess once it is properly heated, the picture would show and everything would be good until windows puts the monitor in sleep mode or I turn off the monitor.
                          Does this sound like a capacitor problem? I do not see any bulges in the caps, but the caps could be dried causing high esr correct? I will get some pictures when the sun is out later on today.
                          Also I remember this forum having a tutorials section where one could learn basic electronics through the links provided, is this still a thing? Maybe it was another forum or something... But if you could recommend books or video tutorials for the absolute beginner I would appreciate it, thanks
                          • Marauder2003
                            COBOL 4ever
                            • Feb 2015
                            • 6
                            My problem is similar to BtBs problem
                            Not sure which board in my HG281D needs caps. For a long time it took many presses of the on button before the screen came on. Then one day the power went out and when it came back on the monitor did to. Apparently the on-off system remembers the last state. This lead me to use a power cord with an on-off switch so I did not have to use the monitors switch.
                            The monitor takes over 15 seconds to come on. And the longer it is off the longer it takes to come on. But once on it is fine. All inputs work. No flickering.
                            Any idea which board needs caps?
                            • Lumberjack777
                              • Dec 2010
                              • 464
                              #754
                              To both of you. It sounds like the caps on the power board. If your power board is the same as this attached picture, replace the 3 circled in red. Those 3 are known to dry up. If after the power board is working, you notice any fuzziness or pixelation; replace the 2 caps on the main/logic board. (in the 2nd picture)
                              On this power board the manufacturer tended to bend the legs of the caps completely over on the pads. Making them a little harder to remove without lifting the pads. You'll want to remove the solder with desoldering braid, then heat the area with the tip of the iron and take a very small screwdriver and bend the pins up a little. The goal is to remove the cap without lifting the pads.
                              For BtB - There's some great videos on youtube on how to solder properly. I'd practice on an old spare board first. Then solder the new caps on the power board. Good luck
                                master hoarder
                                • May 2008
                                • 12168
                                #755
                                1
                                2
                                3
                                4
                                Are these pictures after you changed the caps? If so, I see one potential problem: you used Teapo capacitors (or so it appears to be by their vents) - those are known to be quite unreliable. You might also have used the wrong series of Teapo (i.e. not low ESR or not low enough).
                                The voltage on the regulators you measured appears to be fine, but bad power/excessive ripple due to faulty caps (or caps not adequate for the job) could still cause issues. I had one LCD monitor where all voltages came up properly and appeared "normal". However, the image on the display would not always display properly - sometimes, I would just get a bloack screen, other times random pixels. I replaced just a few of the output caps on the power supply with proper caps and that got the monitor working perfectly afterwards. So it is important to use good caps.
                                What qualifies as good caps? - The major Japanese brands: Panasonic, Nichicon, Rubycon, and United Chemicon. And you also have to get the right low ESR series. So...
                                Panasonic: FC, FM, and FR
                                Nichicon: PW, PS, PM, HE, HD, HW
                                Rubycon: ZL, ZLH, ZLJ, ZLG
                                United Chemicon: KY, KZE, KZN, LXV, LXY, LXZ\
                                Do NOT use eBay if you are new to buying capacitors - there are way too many counterfeit capacitors on there, especially from China/Hong Kong. Local shops likely won't have what you need either. The best place to get capacitors is online through some of the better-known part suppliers, such as Digikey, Mouser, RS Online, and Farnell/element14.
                                • TVRepairNoobie
                                  • Feb 2015
                                  • 158
                                  Does anyone think the low solder on this chip might be a problem?
                                  • fightforlife
                                    • Mar 2015
                                    • 11
                                    I just saw your answer, thanks!
                                    i got all the capacitors from Conrad here in Germany. Sadly they only provide one cap for a special rating (V and F). So there wasnt really a choice.
                                    But shouldnt there have been at least a slightly change in symptoms after changing the caps?
                                    Most of the people with bad caps in this thread first did have only little problems and with time they got bigger up to total failure of the monitor.
                                    But my monitor just stayed black after reboot, it was perfectly fine before!
                                    So my guess is that it isnt a problem with slowly drying caps rather than something that broke because of short hight voltage burst or something similiar. (Probably the monitor-cpu?)
                                    If i find the caps mentioned by you, I probably will try them out!
                                    • fightforlife
                                      • Mar 2015
                                      • 11
                                      What is the best way to make sure these soldering points make a correct connection?
                                      Ive read that some guys put their graphicscard into the oven for a short time. Can i use this method with the mainboard or will the caps get damaged from the heat?
                                      My problem is that i only have a rather large soldering iron. So I cant really solder on this small pins. i would only try to heat them i little without fully melting to give them a better connection...
                                      • _BtB_
                                        • Mar 2015
                                        hey thanks for the help
                                        the pics posted of the power board are not the same as mine, I managed to snap a few pics but they are not of the best quality. Its the best I could do without buying a camera.
                                        So I will just recap the entire 2 boards and see how that goes. here is the cap list
                                        logic board:
                                        3 x 470uf 16v
                                        12x 10uf 25v
                                        5x 100uf 16v
                                        power board:
                                        2x 1000uf 35v
                                        2x 680uf 25v
                                        4x 10uf 50v
                                        1x 33uf 35v
                                        2x 1000uf 16v
                                        1x 100uf 16v
                                        1x 220uf 10v
                                        1x 220uf 25v
                                        and here is the digikey cart sharing (i think this will work)
                                        http://www.digikey.com/short/7rb0vr
                                        Is everything in the digikey cart accurate?
                                        thanks
                                          master hoarder
                                          • May 2008
                                          • 12168
                                          #760
                                          Interesting find. The solder does look quite ugly indeed. However, if the chip doesn't run too hot (under 60C), then the chances of the solder cracking due to temperature changes is fairly small. But if you tried everything on your monitor and it still doesn't work, then this might be worth a try. I will say, though, that manually soldering those pins with an iron is quite tricky. Hot air should be somewhat easier... but if you don't have a hot air tool, it's not worth getting one just for the monitor.
                                          Not necessarily.
                                          The performance of the new caps, if they have the wrong ESR, could still render the same problem.
                                          Think of this as an expriment. You need to eliminate all sources of "uncertainty" before going to the next step.
                                          Well, the caps going dry overtime could have caused something else to fail too.
                                          Try this: get either a laptop or a second working monitor to hook up to your desktop (and hopefully, your desktop video card has two monitor outputs).
                                          For laptop: after laptop boots, connect your Hanns-G monitor (try both VGA and HDMI if the laptop has one). See if the computer "recognizes" the monitor (Right Click on desktop and go into "Sceen Resolution" [W7] or Properties>Settings [XP]).
                                          For desktop PC: let it boot to you desktop screen with the working monitor. Now connect the Hanns-G monitor, and repeat same procedure as above.
                                          Basically, you're trying to see if the PC "sees" the monitor as connected.
                                          Electrolytic caps will certainly get damaged from the heat. You have to remove them all before trying this.
                                          • Tynan Dill
                                            by Tynan Dill
                                            Assuming...
                                            11-22-2024, 01:46 PM
                                          • PantherDave
                                            by PantherDave
                                            Hi all!
                                            05-29-2024, 02:01 PM
                                          • GLISIT
                                            by GLISIT
                                            01-16-2025, 02:29 PM
                                            03-31-2024, 02:12 PM
                                          • mikey5791
                                            Philips 196V3L monitor power led off
                                            by mikey5791
                                            Hi, i was given this lcd monitor last week with the issue of power led blinking. Upon checking the power board, i found 2 pieces electrolytic caps bulged and replaced them.
                                            Later, when i switched on ac power and detected 5v and 15v dc at output pins. But as soon as i pressed on the front power button, the led on power button lights for 1 second and it turns off.
                                            So, i tried disconnect the flex ribbon cable from t con board. But all i got is a white screen with nothing on. I suspect there is something short somewhere that prevent the display being turned on. Can someone with...
                                            01-25-2024, 07:52 PM
