Acer AL1706b - No Power
+ More Options
Posts
  • bw1
    • Sep 2010
    • 172
    Re: Acer AL1706b - No Power
    One last thing before I order the regulator (for the $3.50-ish it's going to cost, it's not worth it not to), is it possible that something past the regulator is pulling down a genuine 3.3v down to the 1.3 that I'm reading? In that case replacing the regulator wouldn't help, obviously. Is that worth looking into, or should I just order the darn thing and try it?
    • retiredcaps
      • Apr 2010
      • 9271
      I don't think so. The datasheet is very specific about outputting 3.3V DC from "internally" inside the chip.
      If you are hesitant in ordering due to cost, put the monitor aside and wait for more things to order from digikey?
      --- begin sig file ---
      --- end sig file ---
      • bw1
        • Sep 2010
        • 172
        No, from what I can see, the part is around .70 and shipping around 2.49. I'm actually only a few hours from Digikey - too far to pick-up, but close enough to have been to the town a few times. Too bad that doesn't really affect shipping :S
        Oh well. I can deal with <$4 to try it.
        • retiredcaps
          • Apr 2010
          • 9271
          If you really don't want to spend that money, scrounge around some old boards. You will be suprised to see how often this chip is used.
          • hoadle
            • Jul 2010
            • 174
            I had 4 Al1706B monitor get same problem like you, T/S find VGA board is bad, that why had no power turn on monitor. I replace the good VGA board is working final
            • PlainBill
              • Feb 2009
              • 7034
              It's a legitimate question, and one you can answer by several methods.
              The first is theoretical. Does the regulator feature 'foldback current limiting'. If it does, what is the foldback voltage? The information is available on the datasheet.
              An second possibility can be checked within minutes. Does the regulator overheat? This should be tested carefully. More than one incautious tech has found themselves with a mirror image of a logo in their fingertip.
              Another approach would be to use a bench supply to pull the output pin of the regulator up to 3.3 volts. In a pinch a pair of 'D' cells in series should produce very close to 3.3 volts. I'd apply AC power first, then apply the battery power to the regulator output. Make sure you observe polarity!!!
              Ideally check the resulting voltage and current draw from the batteries before drawing any conclusions.
              Oh, don't take my word for the output voltage of two 'D' cells, check the open circuit voltage. A meaningful test could be made by inserting a diode in series with the batteries to reduce the output voltage by about .7 - 1.0 volts. You do NOT want to supply more than 3.35 volts to the IC.
              PlainBill
              • kc8adu
                • Nov 2003
                • 8832
                • U.S.A!
                #27
                read this when you have acers that are dead.
                https://www.badcaps.net/forum/showth...=max810&page=3
                very common issue.
                bet hoadle could fix all 4 of his cheap!
                • hoadle
                  • Jul 2010
                  • 174
                  #28
                  very common issue.
                  • PantherDave
                    by PantherDave
                    Hi all!
                    05-29-2024, 02:01 PM
                  • Destroyer-Br
                    [HELP] Acer AN515-55 (LA-J871P Rev: 1B) – Board won't power on after GPU investigation – Suspecting Super I/O or PCH
                    by Destroyer-Br
                    I'm working on an Acer Nitro 5 unit with the following specs:
                    • Motherboard: LA-J871P Rev: 1B
                    • Model: Acer AN515-55-59MT
                    • S/N: NHQ7JAL00403906A973400
                    • SNID: 03902728734
                    Initial Issue
                    The laptop initially presented graphic issues and driver failure (Code 43) for the GPU.
                    After preventive maintenance (cleaning, thermal paste, etc.), it powered on normally. We disassembled it again to inspect the GPU, reassembled...
                    04-17-2025, 08:18 PM
                  • GLISIT
                    by GLISIT
                    01-16-2025, 02:29 PM
                  • Victor Moreira Silva
                    Acer Nitro 5 LA-L181p power LED turns on by 5 secs (Short on PCH rail?)
                    by Victor Moreira Silva
                    I'm trying to repair my old Acer Nitro 5 (AN517-54-55T5). I've already bought a new laptop, so this is more of a learning project. For the experience, with no high expectations of success.
                    Well, my decice specs are the following:
                    Model: Acer Nitro 5 AN517-54-55T5
                    CPU: Intel Core i5-11400H
                    GPU: NVIDIA GeForce GTX 1650
                    Motherboard: GH51G LA-L181P Rev:1c
                    The symptom:
                    When pressing the power button, the power LED lights up for about 5 seconds and then turns off. Initially, the issue was intermittent: sometimes...
                    05-26-2025, 10:49 AM
                  • Bonaventure Vigil
                    ACER ASPIRE A515-52G CAN ON BUT NO DISPLAY, NO POWER AT VCC_GT
                    by Bonaventure Vigil
                    Dear All,
                    Please really2 need Help on this Acer A515-52G Motherboard Compal EH5AW LA-G521P Rev: 1A.
                    At first this laptop can on, keyboard light on but no display. Open the motherboard, found out the PQZ3 Mosfet and PUZ3 ic near it burn. Refer picture below. Then I replaced both. All the power rail 3.3,5,1.2, 1.35, 0.8V have power back after i turn on the laptop except for the VCC_GT rail. Voltage at Power Supply showing 0.000A before turn on, after turn on it became 0.5 0.6A. Seem cannot boot and still no display. Then I replaced the PUG1 and mosfet, but the VCC_GT still no power....
                    12-12-2024, 10:22 AM
