Noxon iRadio 300 Internet Radio server closed
  • shybear
    • Jan 2010
    • 105
    hi,
    I have this nice Internet Radio and until few days ago it worked properly.
    It connect correctly into my local net and works with Pnp features but when I select Internet Radio option it give me a connection error.
    I contacted Noxon support and they said that for security reason producer took offline server for these old models.
    From menu there isn't a way to set the URL server where the radio pick the list of channels, but I think this info its stored in the BIOS.
    Actually I don't have a backup of file BIOS but here there are still original files:
    http://terratec.ultron.info/NOXON/NOXON_iRadio/Update/
    On radio there is the firmware update option but if I make a manual check it says that the firmware is up to dated.
    Version software is: ir-mmi-FS2026-0200-0143-V.2.1.11.EX13068-83.
    Its really shame to trash a device that still works!
    Any help would be appreciated a lot. Thanks
    ps if it may help I can dismount radio a look for BIOS chip to make a backup copy of file!
    • 31214
    Re: Noxon iRadio 300 Internet Radio server closed
    did you install the version from the BETA folder?
    it's newer and fixes some bugs
    • shybear
      • Jan 2010
      • 105
      nope, the radio worked always fine so I really didn't care a lot about firmware and I just set to make automatic firmware update.
      I try now and I'll let you know.
      • shybear
        • Jan 2010
        • 105
        It seem that in this model its impossible to update BIOS via web interface.
        In the link:
        there is a subfolder of all models also iRadio 300 but inside there are just PDF documents.
        There is also Noxin iRadio subfolder where there are a lot of infos and also firmware updates and Bootloader so I supposed it was a folder for alls iRadio models but Noxon iRadio is a specific model.
        I tried anyway all firmware manager but my model is not compatible with it and firmware update is just trough the radio menu.
        There is also a webpage that manage Noxon devices:
        http://www.radio567.com/setupapp/rad...Err=sp1&sAuth=
        but if I enter the Mac of my radio it says is not correct.
        There is this 3rd part software:
        https://www.youtube.com/watch?v=vhyT7dAMeMM
        but I can't find anywhere the firmware of my model
        • surfRadio
          • Sep 2022
          • Italy
          i have a noxon 300 too, noxon support said to me the same.
          did you find any fix ?
          you think this is the right forum where to post about this issue
          • NAUD Benjamin
            • Sep 2022
            • france
            Same problem.
            Planned obsolescence. we should attack them :pleurs:
              • 31214
              i wonder if it's "normal" data and you just need to change the web / IP address to a different server??
              a router may be able to redirect that!
              i just found this on my GITHUB
              https://github.com/mr-sm1th/noxon-gateway
              • Soldiaz
                • Jul 2022
                • 6
                • Deutschland
                I thought to replace target gateway to another within the Firmware and reflash. For this I guess u need window-enabler
                  • 31214
                  what is "window-enabler"??
                  if you can flash the firmware then i think you may just need a hex editor
                  • magnum2
                    • Oct 2022
                    • italy
                    It takes time but you can flash a new firmware with the software they provide.
                    It is all online but you have to search for it, the correct path is http://terratec.ultron.info/NOXON/
                    I did it today for a NOXON Iradio 2 that was sitting from 2007 and it is back to life!
                    • giova_k
                      • Nov 2022
                      • Italy
                      Hi All
                      Magnum, can you explain me how you flashed your radio firmware? I have an iRadio 300 but I can't find anything useful at the link you posted...
                      • sigot
                        • Dec 2023
                        • Slovakia
                        [SOLUTION 2023 and forever ]
                        Hi All, I have found way, how to use our dead Noxon iradio. It is not perfect, but it is better than having this radio like a furniture. I have iRadio 300. Here is how I am using it:
                        1. On pc, which is in the same local network as iradio, install X-DLNA, it is freeware.
                        2. Make sure your noxon is connected. If you are on wifi, you have to click "internetradio", it connects to wifi, but shows network error, but it is OK.
                        3. In X-DLNA click on webglobe:
                        4. Navigate to direct stream link like this one: http://s2-webradio.rockantenne.de/rockantenne or try other. Some radios you can find here: https://github.com/schreibfaul1/ESP3...Webstreams.txt
                        5. It plays automatically on PC, but you can stop it.
                        6. Click "Cast via" button:
                        7. Click on play.
                        8. Now It plays from iradio. You can now close X-Dlna, it will play forever, until you do not turn off radio.
                        OPTIONAL:
                        I am using bookmarks, so I have saved radio stations I am listening:
                        KNOWN ISSUES:
                        After some moments, device disconnects like this:
                        Then you just Click "Rescan". Point your mouse there, It appears.
                        ENJOY
                        • Guest
                          7. Click on play.
                          OPTIONAL:
                          KNOWN ISSUES:
                          ENJOY
                          Connected directly to my home network, X-DLNA doesn't show up my I300 in the available devices list.
                          How can I solve this issue ?
                          Thanks.
                          • shelby5041
                            clock radio / radio lifespan?
                            by shelby5041
                            hi
                            ive got a modern digital clock radio approx 15yrs old
                            my question is how long can a clock radio or a simple radio last ss farcas operating hours?
                            since elec components have limited hour lifecspan i would imagine the radio or clock radio would eventually fail.
                            the reason i ask is because i have my clock radio on radio function 24/7 for the past 7 years and its still working fine....i leave the radio on ..never turn off past 7years...thats approx 60000 hours
                            it uses very little power just a few watts i would imagine that may have something...
                            09-14-2024, 03:30 AM
                          • zklgfs
                            Anker SoundCore 2 Bluetooth Speaker Turns Off After a Few Seconds (Possibly Firmware Issue?)
                            by zklgfs
                            I have an Anker SoundCore 2 (A3105) that I saved from the trash (well, I guess there's a reason why it was supposed to go into the trash...). The problem is that it always turns off after a few seconds (sometimes it stays on a bit longer, between 30 and 60 seconds, but it still turns off). The power light turns on and the bluetooth light starts blinking, but both abruptly turn off again. The "turn off sound" is still played after the lights turn off. Sometimes, it also loops the on-off cycle several times without me pressing any buttons. If I connect an AUX cable, music...
                            08-11-2025, 02:14 PM
                          • TheUser
                            Thinkpad Docker G2 Type-C 40AS - Firmware Unknown
                            by TheUser
                            Hello to everyone ,
                            This is my first post here, and i would like to share with you a small story in case you can help me.
                            Docker Type-C Gen 2 - Model 40AS. Was given to me by a friend for free ,but with the problem that you cannot use the video output ports.
                            All ports work , USB , Ethernet, Type C ... but HDMI + Display Port don't work
                            I searched on reddit and google for problem similar to that, and a LOT of people had fixed this problem by updating the firmware. So i tried , i searched and found 1.1.13 utility and 1.1.20 utility that can help...
                            02-10-2024, 02:07 PM
                          • UserXP
                            Vintage SONY Digital Clock Radio ICF-C12W no audio
                            by UserXP
                            Dear all,
                            I have this old radio clock by Sony from the early 80s, I guess. The clock display works, but is dim, the function board appears to be OK - but the radio unit shows no signs of life. It doesn't produce a single noise, crack or anything from either FM or AM band. It's like it doesn't even power up.
                            i opened the radio and it is full of some TRACON gray capacitors. They only have their negative strip printed, voltage and capacitace markings - no series, no temperature marking, nothing else.
                            My question is, do you know of this brand of capacitors and how bad are...
                            07-21-2025, 08:35 AM
                          • gurj1979
                            Ubiquiti firmware help. US-8-150W POE
                            by gurj1979
                            Hi guys.
                            I've got a Ubiquiti US-8-150W POE switch which has issues with updating the firmware.
                            Turned out to be a bad EEPROM chip. It would read the firmware and work as normal, but failed to write new firmware to it.
                            So I took off the chip and read on EEPROM and saved it. Wrote to old chip and failed to write
                            Got New chip and writes good.
                            THE PROBLEM...
                            It fails to fully load the firmware, POE lights fail to work during g firmware test during load. I'm suspecting bad EEPROM Read.
                            Does anyone have a Good Firmware I can have?...
                            07-22-2024, 05:13 PM
