Sony STR-DN1030 Distorted audio when Volume adjusted
  • jason123
    • Oct 2015
    • 1068
    New to Audio equipment. Received this 7.2 Surround Sound system - had a blown channel and fixed that (0.22 ohm resistor, 2 transistors, and 1 100 ohm replaced)
    All channels now work. However, when I raise the volume with knob or remote, it doesn't work smoothly - you can heard distortion, and some speakers don't seem to work at max or somewhere in between..
    First thought was the actual audio switch - but then Remote volume control shouldn't have this problem, but it does.
    Second thought was the ribbon cable from front display to control board (V-Flex, 29 pin Cable) was pitched in the process and repaired it for testing. Though I can't seem to find a replacement for it anywhere.
    Any thoughts what to look for here?
  • CapLeaker
    Leaking Member
    • 8148
    Re: Sony STR-DN1030 Distorted audio when Volume adjusted
    maybe just an calibration issue. I'd do a factory reset and let it auto calibrate... see if it fixes your problem.
    • jason123
      • Oct 2015
      • 1068
      Tried both, reset and calibrate - no change
      • CapLeaker
        Leaking Member
        • 8148
        Try to bypass all digital processing. If it is still there, the problem has to be on the pre amp or amplifier stage. A oscilloscope would be almost a must here to see what is happening where. Then you can compare inputs and outputs of each individual stage.
        • jason123
          • Oct 2015
          • 1068
          Just to add more info.. this distortion upon volume up / down happens even with Bluetooth source and listening with the headphone on the front jack. Seems to be common to everything.
          • CapLeaker
            Leaking Member
            • 8148
            I figured that would be the case. See if you can find a service manual and an oscilloscope. Shotgunning things won’t help much here.
            • jason123
              • Oct 2015
              • 1068
              I have both.. what should I be looking for please??
              • CapLeaker
                Leaking Member
                • 8148
                first I'd do all of page 6. Read page 13 and make sure this thing is totally cleared of everything. The hard part is to figure out if that is an alignment issue or an actual hardware fault of some sort.
                I usually start from the back and work my way towards the front. Compare each amplifying stage in and output from the bad channel to the good channel. Check what comes out of the DAC. See what goes into the DAC.
                • CapLeaker
                  Leaking Member
                  • 8148
                  Look at the block diagram like page 19. It tells you all you need to know. Plus you can always pull up spec sheets of individual pieces to figure out the pinouts.
                  • jason123
                    • Oct 2015
                    • 1068
                    Will do.. just looking at diagram of page 17... if I apply input at SA-CD/CD Audio In then listen to audio Either front phones (page 19) or any of the speakers I hear the distortion. This tells me that the IC400 is the issue or IC2105 (Page 17)? I don't know how the volume control adjusts the gain?
                    • jason123
                      • Oct 2015
                      • 1068
                      Completed page 6 and 13...everything cleared. Problem persistes
                      • CapLeaker
                        Leaking Member
                        • 8148
                        Well, if that’s the case you need to go through all the amplifying stages. You may have to take transistors out too and measure the hfi gain. Also look at the input stages, make sure levels are equal.
                        • jason123
                          • Oct 2015
                          • 1068
                          Well, if that's the case you need to go through all the amplifying stages. You may have to take transistors out too and measure the hfi gain. Also look at the input stages, make sure levels are equal.
                          Could you please look at Post #10. Am I on the right track?
                          • CapLeaker
                            Leaking Member
                            • 8148
                            You should do more tests first. Try all inputs and also switch over to the not used ones. If you get bleed over, let’s say input 1 has a CD player on it and switch to input 3 that has notching connected and you still hear the CD player, then the input selector is at fault. You can read and old thread of mine with a Sony strd590 I believe. Try the tuner, the usb inputs etc. to get a better picture. Meanwhile I’ll check that service manual out.
                            Does the subwoofer out distort too? See if the video audio out is clean? That should bypass the amps PA stages.
                            This thing has a built in signal generator? Turn it on and see what happens.
                            Might be also worth checking the relays. I don’t think ic2105 is the cause.
                            • jason123
                              • Oct 2015
                              • 1068
                              You should do more tests first. Try all inputs and also switch over to the not used ones. If you get bleed over, let's say input 1 has a CD player on it and switch to input 3 that has notching connected and you still hear the CD player, then the input selector is at fault. You can read and old thread of mine with a Sony strd590 I believe. Try the tuner, the usb inputs etc. to get a better picture. Meanwhile I'll check that service manual out.
                              Might be also worth checking the relays. I don't think ic2105 is the cause.
                              First finding is that the subwoofer channel does not have the distortion - volume adjusts beautifully
                              Actually, all output speakers seem to work well, except the "FRONT A" Left and the headphone plug in the front of the unit (which makes sense, as Channel FL is the one the headphones are pulled from.) FL is the channel that was blown when I got the unit. So I don't know if I got bad parts or if there are more bad components on that channel.
                              Seems (in addition to distortion) as I go from low volume to high the headphones shift to right only and left seems to be shutting off.
                              Again for that channel, I had to replace Q703, Q704, R713, and R709 (see attached)
                              • CapLeaker
                                Leaking Member
                                • 8148
                                That tells you the problem is somewhere in the PA. Nice thing is that you can compare the left channel to the right channel and go through each amplifying stage. The subwoofer output bypasses the PA stage totally, which indicates there is still a problem of some sort in the PA.
                                • jason123
                                  • Oct 2015
                                  • 1068
                                  There are only slight impedance differences between the channels. Only thing i can think of the large transistors i bought on eBay, though listed as new, the leads were tinned. Guess i can replace those again?
                                  • frankusb
                                    • Apr 2015
                                    • 111
                                    One option would be to swap the new parts between the L and R channels.
                                    • jason123
                                      • Oct 2015
                                      • 1068
                                      Thanks.. certainly an option - these boards are so cheaply made though, it's very easy to lift a pad and I'm trying to avoid that if I can.
                                      • CapLeaker
                                        Leaking Member
                                        • 8148
                                        The only other thing I can think of is that the replacement didn’t have the exact part number. For example: A 2SA1164 has three different versions in which the gain rating is totally different. So a 2SA1164-GR has like three times the gain than a 2SA1164-O.
                                        • crackedprint
                                          Sony HCD-HX80R Amplifier Volume Control Problem
                                          by crackedprint
                                          I have a strange fault on a Sony amplifier. The volume control varies the display from MIN, then 1 up to 30 and then MAX as expected. At MIN there is no sound. However, at 1 it is quite loud and increasing above 1 does not change the sound level.
                                          I have tried a Cold Reset as per the service manual.
                                          I have looked at the I2C clock and data to volume control chip IC501 (BD3499FV). Data is only sent to IC501 when the volume is set to MIN or 1. At any other setting no data is sent to IC501.
                                          I have looked all the way through the service manual and tried many online...
                                          01-21-2025, 12:18 PM
                                        • ajvpb
                                          Denon 3313CI Distorted Audio FL+FR
                                          by ajvpb
                                          Hobbyist repairman here so I've reached the end of my troubleshooting abilities. The audio out of the FL+FR speakers is very distorted and almost unintelligible. BUT! That only applies to digital audio; Analog plays through just fine. The distortion carries to headphones if those are plugged in with audio from a digital source. All other speaker channels play fine regardless of digital or analog.
                                          Previous experience with similar distorted audio has been bad resistors on the amp output - Could bad smd resistors on the hdmi board cause the same problem? My understanding...
                                          02-22-2023, 05:21 PM
                                        • samson7point1@yahoo.com
                                          Help troubleshooting an audio problem with an RCA SGT-250 CED Player
                                          by samson7point1@yahoo.com
                                          The Problem: This player has a toggle switch to select between Stereo, Mono R, and Mono L. Regardless of the setting it outputs the sound to both the L&R audio jacks. In the Mono R position, the audio output level is normal (from both the L and R audio output jacks), in the Stereo position the audio output is about half the volume, and in Mono L, it's about 3/4 the volume. Something about putting it into Stereo mode is causing the volume to drop significantly and I can't figure it out.
                                          The player processes the audio signal using two different reference frequencies. The "R"...
                                          04-30-2024, 11:22 AM
                                        • UserXP
                                          Vintage SONY Digital Clock Radio ICF-C12W no audio
                                          by UserXP
                                          Dear all,
                                          I have this old radio clock by Sony from the early 80s, I guess. The clock display works, but is dim, the function board appears to be OK - but the radio unit shows no signs of life. It doesn't produce a single noise, crack or anything from either FM or AM band. It's like it doesn't even power up.
                                          i opened the radio and it is full of some TRACON gray capacitors. They only have their negative strip printed, voltage and capacitace markings - no series, no temperature marking, nothing else.
                                          My question is, do you know of this brand of capacitors and how bad are...
                                          07-21-2025, 08:35 AM
                                        • karthur
                                          Vizio D65x-G4 Volume changes on its own
                                          by karthur
                                          On this Vizio D65x, the volume will change on its own. I don't mean like during commercials where the volume will increase. I mean its like the (+) volume button on the remote is pressed and the actual volume dialog is displayed on the screen going up. It will do this, then the volume may start going down. It might go all the way to "0"or it might stop at a different number, then start going back up. The whole time its doing this, the volume dialog is shown on the screen.
                                          It wont do it until it has been "ON" for 20 or 30 minutes, so it does seem to be heat related....
                                          06-05-2025, 08:13 AM
