Pascal S-Pro2 amplifier module
  • Thabto
    • Oct 2009
    • 32
    Hi
    I was using this module in a Professional Audio Subwoofer. One day it blew and certain small components were burnt such that they cannot be identified by their part numbers. I am a certified Electronics Technician and would like to have the chance to repair my module, if you have a part list for this module, that would be great. I need to know the values of the following components:
    TRANSISTORS
    T503, T506, T509, T511
    DIODES
    D502, D504, D506, D508, D520, D522
    IC'S
    IC501, IC505
    RESISTORS
    R500, R507, R511, R520, R527, R576*, R573*
    CAPACITORS
    C138, C205, C229
    Thank you for reading. Let me know. TIA
  • CapLeaker
    Leaking Member
    • Dec 2014
    • 8351
    Re: Pascal S-Pro2 amplifier module
    I found this thread. Hopefully it helps you out a bit. https://forum.speakerplans.com/jbl-p...pic101326.html
    • Thabto
      • Oct 2009
      • 32
      Many thanks for that. I now only require ID of these:
      TRANSISTORS
      T503, T506, T509
      DIODES
      IC'S
      IC501
      RESISTORS
      R500, R511, R520, R527, R576*, R573*
      CAPACITORS
      C138, C205, C229
      • AlexVG
        Replacing the WiFi module on a vacuum cleaner iROBOT i7
        by AlexVG
        I have had an iROBOT i7 with a camera error (error 68) version REV M, year 2018.
        I bought a liquid damaged Mainboard with WiFi module, from the same vacuum cleaner, but a different year and a different version (REV G).
        (This board does not respond, only the LEDs light up in a circle.
        The liquid damage is catastrophic and restoration is impractical).
        (I bought this board to get the WiFi module and camera).
        The boards are completely different in the installation of elements, even the connector for the WiFi module is different.
        If...
        10-22-2024, 07:20 AM
      • repair-it
        TOSHIBA DLP 52HM95 How to reset timer module on bulb
        by repair-it
        I replaced the bulb only on my Toshiba DLP The bulb is a TB-25. This is the first time I've done a bulb only replacement. Supposedly there is a timer module that needs to be re-calibrated or reset. I don't know where the module is located. I see some vendors selling the bulb with the housing stating module included which leads me to think the module is located inside the enclosure the bulb mounts in, but I didn't see it. Maybe it's inside the plug attached to the bulb?
        Anyway - I am seeking information on how to reset this so called module so that the lamp will operate. Apparently...
        10-11-2023, 07:18 PM
      • m1ch43lzm
        70mai Dash Cam A510 - help identifying connector on camera module
        by m1ch43lzm
        Hi everyone
        I have a 70mai Dash Cam A510 which failed after about 3 months of being installed in my car, likely due to heat, i got it from aliexpress so no point in trying to return it for warranty (and shipping it back would cost me almost the same as a new one from ali)
        The camera would boot loop showing 70mai logo on the screen, sometimes it would boot fine then the live view would freeze or display purple lines
        I already took it apart, and found out that the camera boots fine if i unplug the camera module from the main PCB, sometimes "playing" with the connector...
        05-11-2025, 06:02 PM
        Light that has a bug zapper in bottom section of light fixture the LED light module took a crap but the zapper still works
        So I got the bright idea to remove the LED light module from the fixture and put it on top of another enclosure and keep using the zapper
        The removal of light module was a successful and now I just have to cut a hole in the enclosure and put a power cord that has an on and off switch on it
        You are lucky to get about two years of service out of one before the LED module starts flicking and just stops working because it is mounted on an aluminum plate and these are hard to solder on it and it is not worth messing around with them and especially this one because it has line...
        09-07-2024, 07:26 PM
      • DriversScrew
        Omnitronic TUNA-NET Internet Radio - M1088 Module - any information or software?
        by DriversScrew
        I've got an Omnitronic TUNA-NET internet radio with an all in one module built around an esp32. The module must be a M1088 from ALD Ltd.
        The device shows only a white display screen pulsing every second. Seems to have some kind of boot issue. All voltages and the pcb thermal signatures look good.
        Any information about the M1088 module, schematics or firmware would be helpful....
        10-04-2025, 04:33 PM
