Kenwood DNX571HD frozen
  • mbates14
    • May 2005
    • 169
    So, I have one of these kenwood units that freezes on the splash screen on powerup and wont advance further. doing some googling its kinda pointing to corrupt software which i suspected.
    Trouble is, besides finding an update file from Kenwoods website, i cant really find any info on how to reflash this thing.
    i saw some stuff on the 570 from @mixmansc, but the links are dead. Plus I dont know if it will work on a 571.
    Thoughts?
  • tibimakai
    • Jan 2012
    • 3680
    Re: Kenwood DNX571HD frozen
    I'm no expert, but I wouldn't exclude that the GPS CPU needs reheating/reflowing.
    I had the red LED w/fan on only, and by reflowing the daughterboard CPU, it turned on and working great.
    • petehall347
      • Jan 2015
      • 4426
      have you tried a reset ?
      • Scruit
        Does the Oak OTI067 have a splash screen / initialization message at bootup?
        by Scruit
        tl;dr ... Question: Does the Oak OTI067 have a splash screen / initialization message at bootup?
        More detail:
        Working on "Uncle Sherman", my Mitsubishi MP-3200 386 from 1988. Before I start up old computers I have a process where I disassemble, test for shorts, visually inspect, capture EPROM images etc.
        My T866II+ give me a "pins not detected" error on the EPROM from the Oak-based (OTI067 GPU but apparently a no-name card??) I assumed the EPROM was bad, ordered a replacement and figured I'd program a downloaded ROM image to it....
        04-17-2022, 06:03 AM
      • rccrasher65
        KENWOOD KA-701 POWERS ON, NO RELAY CLICK
        by rccrasher65
        I'm looking for some help, sorting out a protection circuit fault on my Kenwood KA-701 integrated amp. The amp does turn on , but the relay don't click. It usually ends up being, a transistor, or cap on the protection circuit, DC offset problem. I can't read schematics real well, and the ones I have are really bad quality. There are no good quality one's I have found so far. Looking for some professional help. Blue Midnight helped me a lot in the laptop forums, but It's been a few yrs, like 6 or so. I don't even know if he's on here or if anyone does the amps, but any help navigating throught...
        04-11-2025, 08:03 AM
      • VHAALNPATTET
        Suggestion On Where to Look. Kenwood KA-35000 amp
        by VHAALNPATTET
        I have a Kenwood KA-35000 amp. I've recapped all the electrolytic capacitors recently. When I first turn the unit on I get a few second hum and a small pop sound on speakers and then silence. I am able to play music, etc without an issue after wards. Because it occurs only at the initial powering up each time and only last a few seconds I am having trouble figuring out how to troubleshoot.
        The one other thing I noticed that during the powering off there is a slight hum and quiet pop sound. This I hadn't noticed before. The KA-3500 has a muting circuit that when unit is powered off...
        03-02-2025, 08:40 PM
      • dariuxzy
        Kenwood GE-87 disturbed signal on display
        by dariuxzy
        Hi, I have this spectrum analyser Kenwood GE-87 (EQ) and the displays are disturbed by a dirty signal as you see in the attach video...
        What could it be? I also attach the diagram wiring...
        06-28-2024, 03:06 AM
      • EazyBone
        LG 75UH8500 color static frozen
        by EazyBone
        Got a LG with color static frozen. Doesn't move just stays on this picture. I'd assume it's main board but I'm sure one of you has seen this before. Any data helps thanks...
        06-10-2024, 09:35 AM
