Kenwood GE-87 disturbed signal on display
  • dariuxzy
    • Mar 2023
    • 44
    • italy
    Hi, I have this spectrum analyser Kenwood GE-87 (EQ) and the displays are disturbed by a dirty signal as you see in the attach video...
    What could it be? I also attach the diagram wiring
  • CapLeaker
    Leaking Member
    • 8352
    Open it up and post high resolution, straight shot pictures of the boards. I assume that is happening with nothing hooked up to the EQ?
    • dariuxzy
      • Mar 2023
      • 44
      • italy
      No, the video is an example with the signal. With zero signal, nothing happens.
      • dariuxzy
        • Mar 2023
        • 44
        • italy
        As you can see in the first picture, even the non-involved bands are slightly illuminated, like a ghost effect. In fact, only the bands/frequencies produced should light up, not all of them.
        In the second picture (i take it online), there's an example of what it should look like, the frequencies/band not involved are totally black, there's no "ghost" effect
        • CapLeaker
          Leaking Member
          • 8352
          Does it do that on both sides, Left and Right channels, or just one?
          I would go over all the power supply rails and see that all voltages are correct. You can poke around with an oscilloscope and see what happens. Maybe with the FIP Driver IC's, a display issue, or maybe something has gone conductive, bad ground solder joint, etc.
          • redwire
            • 3912
            Always start troubleshooting by checking the power supply rails. Don't slip with your probe.
            +/-14V, +6.2V IC9, VFD -30V, +5.6V
            It seems to be an analog drive and mux to the VFD. There are some VFD annunciators always on, so they are dim as well which might mean it's not the driver IC.
            Is it my browser of that PDF schematic clipped off on the right side? I can't see the mux portion.
            • AstutePauciloquent
              Requesting Help For GA-970A-DS3 rev. 1.0, No Post code, no RSMRST# signal
              by AstutePauciloquent
              Hi everyone, over the past few months i have taken a deep dive into motherboard diagnostics and I love the challenge. Currently im trying to learn all about the signals that travel around the motherboard, such as frequencies, enable signals High and Low logic states etc. And i have been learning to read and using the Schematics for this board that i requested here on Badcaps forum, from a few months ago, this is such a great place for these.
              I’ve been working on a GA-970A-DS3 (rev. 1.0) that does not post. This motherboard has been my main learning board. I would like share...
              11-23-2023, 11:02 PM
            • CoinCoin88
              Garage door RX unit (Cardin S38C) does not short relay to send opening signal
              by CoinCoin88
              I'm turning to the Badcaps community to help me troubleshoot the radio Rx card from my (old) garage door opener. While I could just ditch that card and replace the whole system, I first would like to understand "why" it suddenly stopped working, because that's just how I am wired...!
              Some basics: the receiver works on a 30.875 Mhz frequency. Yes, I'm aware this is not in use anymore in a looot of places. It does not use any rolling code, it's just a regular dip-switch code that you have to set up on both the receiver and transmitter. The receiver...
              09-15-2025, 03:36 AM
            • howardc64
              Vizio M65Q7-H1 Red Vertical Strips fixed by tape blocking LC1 signal to half of the panel
              by howardc64
              Failure Symptom
              No picture, just red vertical stripes. Google search shows quite common problem for these recent Vizio M series although red vertical stripe pattern may differ. Some call it "Netflix" boot screen haha.
              Where is the short?
              Panel has 4x buffer boards. Quickly found the 1/4 panel buffer board with the problem by selectively disconnecting buffer board flex cables.
              Having recently fixed another Vizio with similar symptoms that was a shorted ESD diode array ( link ) Probed the ESD diode array but...
              05-27-2025, 02:56 PM
            • JayPoorJay
              Converting +/- 5v to a Usable Hz Signal
              by JayPoorJay
              Good morning.
              I have posted here before and have gotten AMAZING advise (thank you!). I'm back for more. This BCaps Sub Forum is so well attended I thought I would post here.
              This question is for an automotive application but has to do with what are essentially electrical questions and problem solving... If this is inappropriate I get it. Feel free to delete it or move the question.
              The V 12 Jaguar XJS is notorious for overheating in stop and go traffic in hot weather... Y'all will be potentially helpinh a LOT of people. The solutions and directions...
              08-07-2022, 08:35 AM
            • supravit2000
              PS4 fat has inconsistent signal after HDMI replacement
              by supravit2000
              Hi, guys!
              I am not a professional, all I can do is solder stuff on the boards, so I would really appreciate it if someone with knowledge shares his experience/thoughts on a problem I have with a PS4 console.
              My friend gave me an original fat PS4, board model SAB-001, with WLOD, that has been previously opened. I changed the HDMI port, couple of pads on the board were ripped, which I connected to the corresponding caps/resistors? Just did so as in a shown diagram (one of the ground pads I ripped off and left it not connected). However, there was still no signal, so...
              12-19-2022, 08:08 PM
