RXD26L Kenwood hi-fi schematic / advice please
  • zen
    • 511
    Hi all , just embarking on my next project .
    Shuts down into protect mode shortly after power up .
    Audio output devices measure good ,plus no DC voltage at speaker terminals before protect kick in .
    There is evidence of cap leakage on the power / audio board , which might be a good place to start .
  • zen
    • 511
    Re: RXD26L Kenwood hi-fi schematic / advice please
    My money is on caps
    After leaving unit for a while , then making several attempts , it finally powered , without protect kicking in .
    • zen
      • 511
      Checked through the board & replaced any suspect caps .
      The two main culprits were C29 & C30 ( 100MF , 16V ) , which had leaked out .
      They are red in colour & remind me of the same , or similar types that used to fail on Toshiba CRT sets , on the frame circuitry .
      Now powering , but won't have bench space to test till tomorrow .
        • 31218
        red caps?
        the only old red caps i know are Dubillier,
        • redwire
          • 3912
          Never seen red "hi-fi" caps from Japan, maybe Rubycons? "A Class Amp" marked on the board so it might have had some.
          You won't read anything at the loudspeaker terminals when the prot relay is not pulled in. You have to measure DC offset at the plate emitter resistors.
          If the DC protect is false tripping, I'd replace the negative feedback caps they get damaged if there ever was a lot of DC (shorted O/P transistors).
          Couldn't find the schematic but the amp section board looks cut'n'paste on other Kenwood gear.
          • lti
            • May 2011
            • 2557
            The red caps look like the Elna "long-life" caps that were used in some power supplies in the early 1990s. They were known to leak.
              What DC V do you get with ref to the circuit ground on the middle pin of the white power resistors of both channel AFTER the protection kicks in?
              • zen
                • 511
                Here you go guys ( see picture )
                Main cause of issue ,the 2 red caps . Hi-fi now working on test .
                85 degree types .
                • zen
                  • 511
                  Next issue with this thing is that CD player not functioning .
                  Disc will spin , but no TOC .
                  Replaced the reader KSS210A , but same issue remains .
                    • 31218
                    did you scope the eye pattern and adjust the laser?
                    • zen
                      • 511
                      Just swapped laser as i had one in stock.
                      Can't really afford to spend more time on it till i speak to customer .
                      • zen
                        • 511
                        If i had a surplus of hair ,would have pulled it out by now .
                        What an absolute pain in the ass .
                        First thing that threw me was the fact that the brand new laser i had fitted was faulty .
                        After i had finished swearing , continued with repair .
                        Turns out original laser was ok .
                        Issue with the turntable motor , which i swapped out from another deck .
                        Then started to play , but something was rubbing .
                        Initially i suspected turntable height not correct , but turned out to be spot on .
                        The CD mechanism sits on another plate & between these two are rubber dampers which had become brittle .This had caused CD mechanism to sit lower onto the plate , hence further away from turntable clamp , which was causing the rubbing .
                        Took me ages to find substitute rubber dampers that would work well .Pretty much exhausted my entire collection of scrap mechanisms .
                        • R_J
                          • 9594
                          Did you unsolder the protection shorting pad on the new laser?
                          • zens electronics
                            • Jan 2021
                            • 31
                            Certainly did RJ
                            Sometimes supplier gets a bad batch of lasers
                            • zen
                              • 511
                              Well , this is the repair that just keeps giving .
                              Next problem , CD play very sensitive to external vibrations .
                              To solve this issue i adjusted pot next to empty connector almost fully clockwise .
                              • Byte_76
                                Looking for schematic and advice for EVGA GTX 1050 ti
                                by Byte_76
                                Hello, I bought a faulty EVGA GTX 1050 ti. for a very low price. (To use as a graphics card repair / learning project)
                                The card does not give any display.
                                I connected it as secondary and ran MATS with the result that both B0 and B1 are indicating 999040 write errrors.
                                The ony other memory banks are A0 and A1. They don't indicate any errors.
                                To me it seems strange that both B modules indicate the exact same number of write errors. Could that be a bad solder joint or is the memory controller on the GPU likely to be dead?
                                Can anyone advise on where...
                                04-03-2024, 05:53 AM
                              • TinkerTron
                                Schematic vs. Reality: Where Are the Resistors on My Sharp Clock Radio? Model FY-70CH
                                by TinkerTron
                                Hey everyone,
                                I'm currently working on a mid-70s Sharp Electronic Digital Clock Radio, Model FY-70CH. I found the service manual online, printed it out, and have been studying it for a while. My main reasons for tackling this are: (1) I want to learn electronics and figured I'd start with something I had on hand, and (2) I want to fix its issues. Right now, the radio sounds awful, has about 5V DC at the speaker terminals, and the alarm time setting doesn't work. But I'm not asking how to fix these problems.
                                Instead, here's what's been bugging me so far:
                                The schematic...
                                03-06-2025, 02:03 PM
                              • atunguyd
                                Acer x163w Monitor PSU schematic
                                by atunguyd
                                Ii wonder if anyone can help me. I have a Acer x163w monitor which is not powering up. The PSU main capacitor's one leg had completly come off - I replaced it but the PSU is still not outputting DC. I found the monitor in questions service manual here on manuals lib but the schematic in there is a completely different - the schematic shows no mosfet to drive the transformer while the one I have does use a mosfet - also the schematic shows only one optocoupler but mine has two.
                                The PSU board is labelled FM-20A02-AAA made by APD as per the image below. I am trying to find a schematic for this...
                                03-05-2025, 02:08 PM
                              • zen
                                Sunfire sub true sub woofer EQ signature schematic /advice please
                                by zen
                                Discovered that input to left or right channel will instigate a rumbling noise from sub , which is still present when signal removed.
                                Also discovered that if i monitor the plus 173V across one of the main smoothing caps, which is stable with no signal , but when input provided voltage can fluctuate 152V - 168V . Replaced the cap , which made no difference .
                                The minus 173V across the other cap is fine .
                                Could really do with some help trying to isolate this issue.
                                https://youtu.be/MSwIRZFfPc0
                                04-05-2023, 09:26 AM
                              • DrDos
                                Kenwood KR-6030 vintage stereo ,Old Man Trying to Save a Buck
                                by DrDos
                                Hello all. I'll try to keep this short. I have no knowledge of electronics. I can use a multimeter and am familiar with caps to some extent. I bought a Kenwood KR-6030 vintage stereo. It need work and so I thought I would recap the thing since I get power to the on switch but nothing else is working. No lights, no sound and so forth. I went to Mouser to order caps and I find I am way over my head. I not only do not know the type of capacitors I need but Mouser and digikey do not accept Kenwood part numbers. I have the info such as 220uF 63v and such but no place to put it. I could buy a recap...
                                08-08-2025, 03:16 AM
